September 22, 2026, 03:39:24 am
| | |-+  New updated Salzburg pump available
Pages: [1] 2 Print
Author Topic: New updated Salzburg pump available  (Read 31753 times)
« on: July 30, 2012, 20:43:33 pm »
First prototype, this was sent back for a few additional mods [ Attachment: You are not allowed to view attachments ]
Final design:
Gears are larger than the original factory pump - 2 x 30mm on the engine and 3 x 26mm on the scavenge, the top side has more clearance to aid in fitting the pulley belt, the case scavenge union is set slightly lower & longer than the original works Salzburg pump to give more clearance to a standard type silencer box. Unions threads are 5/8" NPT.
tonybone
« Reply #1 on: July 30, 2012, 21:55:29 pm »
Very very nice.
Say hi to jim when u talk to him next.
Tony Thailand
bugnut68
« Reply #2 on: July 30, 2012, 23:38:23 pm »
What's it for?  Pardon my ignorance, but I've never seen a pump like that before...Grin
« Reply #3 on: July 31, 2012, 05:06:47 am »
Dry sump, I reckon.
« Reply #4 on: July 31, 2012, 08:22:44 am »
Dry sump, I reckon.
correct.
You might ask why you would want to use this pump?  Well it allows stock size pulleys to be fitted.
stretch
« Reply #5 on: July 31, 2012, 13:30:48 pm »
How much are they?
Thanks.
andy198712
« Reply #6 on: July 31, 2012, 16:09:31 pm »
Yh price?
At the moment I've got a D'S pump with 32mm pressure and 64mm scavange but I'm going to need about £400 of pulley system from speedshop to run it. Just worried about the smaller scavange?? But it worked for the slazbetg's.....
« Reply #7 on: July 31, 2012, 22:44:30 pm »
Yh price?
If you look at the spec its multiple gears so 78mm scavenge with 60mm pressure gears.
paul_f
« Reply #8 on: August 01, 2012, 08:08:39 am »
Out of interest, what size were the gears on the factory pump?
Paul
« Reply #9 on: August 01, 2012, 08:35:42 am »
This looks really cool, would it be possible to get the pressure side with axle support in both ends... and also the driven cog?
« Reply #10 on: August 01, 2012, 09:11:45 am »
Not sure what you mean exactly (will pass question on) but if you look at the last pic closely you can see the axle supports for the two outer gears.
« Reply #11 on: August 01, 2012, 09:33:37 am »
My question simplified, are all the gear axles supported on both sides? Or can they be for extra cost?
« Reply #12 on: August 02, 2012, 20:08:49 pm »
Paul
the original Salzburg pump had 2 x 26mm and 3 x 21mm
« Reply #13 on: August 02, 2012, 20:55:31 pm »
Yes all supported except the lower engine pressure gear which does not need a through shaft as it already has a long shaft.
« Reply #14 on: August 05, 2012, 07:12:07 am »
Sorry but 30mm is too small to get the oil out of the engine . we are now at 38 mm and that works with 26 on the pressure side
« Reply #15 on: August 05, 2012, 07:49:08 am »
Please explain.
This pump uses 3 x 26  = 72 if you use 2 x 38 = 76 no significant difference.  The 30 x 2 is on the pressure side.
« Last Edit: August 05, 2012, 10:23:40 am by Lids » Logged
kafercup
« Reply #16 on: August 25, 2012, 04:30:24 am »
How much?
Heorell
« Reply #17 on: September 02, 2014, 10:32:21 am »
Any forsale? Price?
« Reply #18 on: September 02, 2014, 16:49:57 pm »
You need to contact Stateside tuning to see if there are any left.
Martin
Cash Converter....
« Reply #19 on: September 05, 2014, 12:48:47 pm »
I have 2 more on the shelf if Jim as sold the ones I made him.
(you'll have to buy them though Jim though)
Martin
www.taylormachine.co.uk
OFF/500
andy198712
« Reply #20 on: September 06, 2014, 10:00:04 am »
its a good idea due to not having to faff with different size pulleys and also making exhausts fits also, which in fact would save a lot of money!
« Reply #21 on: September 06, 2014, 14:56:13 pm »
Where can I find more details on this? The website doesn't show anything.
Martin
Cash Converter....
« Reply #22 on: September 07, 2014, 08:31:32 am »
what do you want to know ?
Martin
OFF/500
« Reply #23 on: September 08, 2014, 00:41:51 am »
In short, everything! IMO, the design of this pump is brilliant as it allows the use of a standard size pulley. There's nothing else like it that I know of. But three prototype pictures and very little explanation of the design isn't going to be enough to get me to spend my money. What all is included? More detailed pictures of the pump by itself and mounted to a case, maybe even inside a car would be great so I can see what the clearance around exhaust systems, etc may be.
I'm curious to know why the engine pump gears are 30mm when 26mm works well in standard wet sump applications. I'm also curious to know why Udo thinks 30mm is too small. The original Salzburg pump utilized a factory 26mm pump on the scavenge (correct?), is this redesigned to streamline their design? I'm also trying to get my head around why there are 3 pressure gears and how they all work together. I can see that this product is in an entirely different league, but the CB 4 gear dry sump pump only uses two 21mm gears, and it also seems to work well.
In short, I have a conceptual understanding of dry sumps, but I'd like to know more about why this one is the way it is as I am seriously considering going to a dry sump for my next engine build.
« Last Edit: September 08, 2014, 15:59:20 pm by Zach Gomulka » Logged
NoBars
« Reply #24 on: September 08, 2014, 15:29:29 pm »
That is very clever.
kafercup
« Reply #25 on: September 09, 2014, 06:22:05 am »
And price?
« Reply #26 on: September 09, 2014, 22:17:50 pm »
Zach you have a pm.
brewsy
« Reply #27 on: November 16, 2018, 17:43:51 pm »
FYI I spoke to Jim at the Slough swapmeet and he said that they are now all gone and that he probably wont do them again as most folk didnt like the price!!
Shame as it looked like an awesome bit of kit.
Marc
JLaw
« Reply #28 on: November 17, 2018, 22:20:37 pm »
I would have been very interested in this product, shame it wasn't advertised or marketed at all before they are all sold, might have sold a few more to turn R&D costs into profit.
Bad bug
« Reply #29 on: November 25, 2018, 13:19:15 pm »
When i saw this post i was excited at the fact that a drysump pump was made and actually exist that would allow you to run the stock size crank pulley. Now all my excitement has gone to disappointment to hear the pump will not be made again i have a waterboxer to build and a T4 beast to build. To the original makers of the pump i would still make them but sell them in limited quantities to guys that really want them, this would mean that a waiting list system would exits, don't kill a good product because some people don't agree with your price.
Pages: [1] 2 Print
