September 21, 2026, 02:38:23 am
Latest Member: Bad Habit
| | |-+  The messiest job ever!
Author Topic: The messiest job ever!  (Read 5002 times)
« on: August 02, 2012, 20:13:50 pm »
I had the great idea to sandblast my bay window at home.
So, I borrow a diesel air compressor from my uncle and a sandblaster from a friend.
I expected a huge mess, but it was beyond expectations...  Shocked
I have now a true surfer van  Grin
johnl
« Reply #1 on: August 02, 2012, 21:08:55 pm »
Surfs up....................    Roll Eyes Roll Eyes Roll Eyes Roll Eyes Roll Eyes
rick m
« Reply #2 on: August 03, 2012, 14:38:29 pm »
Did mine at home too but out in my large driveway.  Definitely was a mess. I made sure I closed my garage doors before the blasting started.
Rick M
Rick Mortensen
Driving Hot VWs since 1970
Fritter
« Reply #3 on: August 03, 2012, 18:04:13 pm »
I blasted my '64's entire body in my friends very large rural backyard.  I created a small beach.  Cheesy
Mike F.
'64 Indigo Blue sunroof Bug
« Reply #4 on: August 03, 2012, 18:51:57 pm »
I blasted it also outside in the driveway of our trucks park. Luckily this is a gravel driveway.
Neighbor still didn't come complaining  Roll Eyes
It doesn't work as quickly as a thought. Compressor blow air like hell, but the blaster is a hobby type. The bus had been painted 3 times. Original paint come out quickly but the last layer is a thick paint and they used a bondo style primer. I will blast the inside, door jambs and I will did the flat large exterior surfaces with bristle discs.
hotrodsurplus
« Reply #5 on: August 03, 2012, 22:50:07 pm »
It always sounds like a good idea until you do it!  Grin
Make sure you ALWAYS use a painter's-style respirator when working with true sand, even when working outside. A dust mask will not protect you. Silicosis is permanent and painful.
