July 01, 2026, 23:54:45 pm
Latest Member: bigsiembowski
| | |-+  Engine-puls type 4 heads flow numbers ?
Author Topic: Engine-puls type 4 heads flow numbers ?  (Read 16886 times)
Kiel
« on: August 19, 2012, 11:03:44 am »
I need flow numbers on the engine-plus type 4 heads ?
Best regards
Thomas kiel
http://www.engineplus.de/html/de/main/zylinderkoepfe/typ-4.html
« Reply #1 on: August 19, 2012, 13:21:29 pm »
I would say it depends on who has done the porting
Griebel
« Reply #2 on: August 19, 2012, 14:12:15 pm »
mail til dig..
Instagram: c.griebel
       "BEYOND 4 INCHES"
          MIB,DENMARK
Airspeed
« Reply #3 on: August 19, 2012, 15:05:25 pm »
I think those have been published once somewhere. IIRC it was 250-270 cfm on the intakes with their stock valve arrangement.
Pity they seem not able to deliver these heads for some strange reason.
« Reply #4 on: August 19, 2012, 15:23:45 pm »
JPM Flow bench.
Numbers are from my first set of heads.
Yes, I do like them and I just bought my sceond set this spring.
This latest one is a second hand set from Jake Raby. I am building a 2411.
« Reply #5 on: August 19, 2012, 15:30:32 pm »
Do you need a good level of compression like me?
Then Jorge at EMW has the CAD for doing custom pistons as we did for my last set of heads. I took the cost to do this and just go ahead and take advantadge, if you need it.
These are manufactured from doing a cylinder head mould and then made the drawing at JE.
Kiel
« Reply #6 on: August 19, 2012, 20:42:14 pm »
thanks frallan
« Reply #7 on: August 19, 2012, 21:47:28 pm »
almost a shame to put those in  an engine!
« Reply #8 on: August 20, 2012, 00:13:26 am »
Yeah, I call them piston porn in another circle track forum.
Amazing but maybe 10-15 years ago, this was F1 technology.  Now available to me.
Just like the DTA S60.
Is it not fun?
« Reply #9 on: August 20, 2012, 00:55:10 am »
...and my heads.
Jake Raby coated them with black heat spreading special on the outside and other stuff in the intake and then ceramiic of some kind in the chambers.
On the dyno with some kiind of wild cam he could not control the valves, so he ordered special Crower Beehives and these worked up to.xxxxxx ? much higher rpm.
I was contemplating to swap them with a set of OTEVA 75 but then decided to give them a try. I love the retainers. 3 gram.
Unfortunately only single spark but who knows, I might change that one day.
Got a set of Pauter new gen rockers with bushings.
Will be nice if they do work well. I do think so.
didi
« Reply #10 on: August 20, 2012, 17:32:56 pm »
Hi Frallan
Realy nice pistons. Why this high CR? E85?
Didi
Didi - Aircooled VW
http://didivw.blogspot.com/
« Reply #11 on: August 20, 2012, 19:29:13 pm »
Hi Frallan
Didi
[/quote]
YES
If you want to take advanatadge of the E85 more than cooling, Compression should be bumped in comparison.
GetBackOnTrack
« Reply #12 on: August 29, 2012, 18:05:57 pm »
Hi Frallan..
Just outta curiosity, would you be willing to post some pictures of the ports of your heads? and maybe the size of the intake (manifold end)  The ones you posted flow numbers on!
Im currently running 48 intakes in my type 4 heads, they flow 233 cfm at 16 mm lift. Im going to change the valves for 52 mm and 6 mm stem and do some more porting.
Regards, Jakob
Check: gbot.dk
« Reply #13 on: August 29, 2012, 18:56:51 pm »
Sure!
I will post whatever I have and then in three weeks when me and my EP heads are physically together, I can take some measurements.
Ahh, I do have a set of manifolds in my apartment that I can share port size with you.
« Reply #14 on: August 29, 2012, 20:17:00 pm »
These are the heads that Johannes flowed.
Different manifolds´
This is the only one I have that shows the porst of my "new second hand" heads.
Pictures and dimensions of the IDf manifolds will be posted tonight my time. You can see it tomorrow morning.
« Reply #15 on: August 30, 2012, 04:25:40 am »
 I measured 44 x 37,5 mm
Hope it helps.
GetBackOnTrack
« Reply #16 on: August 30, 2012, 06:46:49 am »
Thanks alot for taking you time to post these pics Frallan. The heads look great so does the manifolds.
Regards, Jakob
Check: gbot.dk
holmsen
« Reply #17 on: October 30, 2012, 20:33:02 pm »
before and after a visit @ JPM
from aprox 170 cmf to 231 cmf when done
Elnef
« Reply #18 on: October 31, 2012, 06:43:50 am »
Realy nice heads saw them last friday at jpm Smiley
What about put up some photos from intake and the extra welding
John
holmsen
« Reply #19 on: October 31, 2012, 07:29:56 am »
« Reply #20 on: October 31, 2012, 12:48:39 pm »
I like those original heads . but still the wrong manifolds :-)
« Reply #21 on: November 01, 2012, 22:22:30 pm »
Whooo.... those inlets look big  Shocked
I see a lot of 'unshrouding' done to those type 4 heads, does this benefit a lot..
holmsen
« Reply #22 on: November 01, 2012, 22:47:49 pm »
Remains to be seen, really hope so, need some more oomph to get my bay under 14 sec.
