July 01, 2026, 09:03:13 am
Latest Member: bigsiembowski
| | |-+  Single port 1679cc type 1 engine... 90Hp.
Author Topic: Single port 1679cc type 1 engine... 90Hp.  (Read 10352 times)
Crazy Mc.Stairs
« on: August 28, 2012, 21:12:34 pm »
Hi all,
Today I've dynoed a 1679cc engine I've made for a customer, and it pulled 89.8Hp at 4550Rpm and 155Nm at 3200Rpm with stock size valves and single port heads.
This is a daily driven car, it's a vintage engine (Theo Decker) style, not a race engine! Wink
Cheers,
Christoph
« Last Edit: August 28, 2012, 21:24:04 pm by Crazy Mc.Stairs » Logged
« Reply #1 on: August 28, 2012, 21:36:14 pm »
Impressive. I have a 88 x 74 single port in my cabinet, 236' @ .050", .480" @ valve, someday going in a nice '66 Bug. This is encouraging. Cool
Crazy Mc.Stairs
« Reply #2 on: August 28, 2012, 21:51:44 pm »
Thanks Jim, I 've used a 245° @ .050 and .480 @ the valve on the intake lobe! Grin
Cheers,
Christoph
Joel Mohr
« Reply #3 on: August 28, 2012, 22:31:23 pm »
NICE!!! Chassis Dynos can be deceiving though...you should try a quarter mile to back up the numbers...
SEE YA AT THE RACES!!!
dyno don
DGVA DZK (old school 70's)
« Reply #4 on: August 29, 2012, 08:07:01 am »
 Did someone say Single Ports??  Gentlemen step up to the bat and purchase MY heads from the 70's...  1600 s/p kadrons 15:01 @ 87 mph in Notchback.  Freshened by the talented Fred Simpson and now just need a good home with Love.  Sorry to jack the thread boys...  Peace out, Dyno       ps, BTW... Your engine looks sweet , makes good power, and will a blast to drive.  Enjoy...
whirligig
« Reply #5 on: August 29, 2012, 12:21:30 pm »
planing to build a 1641 with unknown cam (reground almost to base circle )single port with holly bugspray to go in my 66 Cool
old school racer-getting older-now crew chief
besserwisser
« Reply #6 on: August 29, 2012, 22:02:42 pm »
Now we are getting down to serious bussiness. Will be putting my 1835 single port with Teo decker kit on the dyno at JPM in oktober. To give you a hint it wont start with the six volt battery so I have a 12 volt to get it started then I leave it to the magnet when i change to six volt. Drove it down to germany last spring for Maikäfertreffen with lots of power and great gasmilage. Would like to hit over a hundred but who knows.
freakpower
« Reply #7 on: August 29, 2012, 22:41:19 pm »
Hi all,
Cheers,
Christoph
Hey, congratulations with a wonderful engine Smiley
Would you tell us a bit more: What kind of camshaft, exhaust and compression?
Crazy Mc.Stairs
« Reply #8 on: August 30, 2012, 20:21:39 pm »
Hi all,
Cheers,
Christoph
The engine has 88mm thick wall Mahle cyl/pistons
Stock 69mm balanced cranck
Stock rods
PRO 001 SP heads with 35.5/32mm SS valves
8.7/1 compression ratio
34l/s of flow through the intake @ 10"
29.5l/s of flow through the 34mm PCIT Solex carb with 28mm venturies @ 10"
Scat HD single springs
Dual lobe Engle camschaft on modified lobe centre
12.2mm valve lift with 1.3 CB rockers
Modified 35mm exhaust with Sebring muffler
Best regards,
Christoph
Proformance
youngnstudly
« Reply #9 on: September 03, 2012, 06:41:55 am »
I hope my 1915 SP makes some power similar to that! Sounds fun and looks very cool too! I like the car as well.
-Andy
Henrik Hagen
« Reply #10 on: August 13, 2013, 13:49:33 pm »
hi
Is it possible to see some pictures of the heads??
How much porting did you do?
