July 01, 2026, 09:02:59 am
bigsiembowski
Single port 1679cc type 1 engine... 90Hp.
Topic: Single port 1679cc type 1 engine... 90Hp. (Read 10348 times)
Crazy Mc.Stairs
August 28, 2012, 21:12:34 pm »
Hi all,
Today I've dynoed a 1679cc engine I've made for a customer, and it pulled 89.8Hp at 4550Rpm and 155Nm at 3200Rpm with stock size valves and single port heads.
This is a daily driven car, it's a vintage engine (Theo Decker) style, not a race engine!
Cheers,
Christoph
Last Edit: August 28, 2012, 21:24:04 pm by Crazy Mc.Stairs
Re: Single port 1679cc type 1 engine... 90Hp.
August 28, 2012, 21:36:14 pm »
Impressive. I have a 88 x 74 single port in my cabinet, 236' @ .050", .480" @ valve, someday going in a nice '66 Bug. This is encouraging.
Crazy Mc.Stairs
August 28, 2012, 21:51:44 pm »
Quote from: Jim Ratto on August 28, 2012, 21:36:14 pm
Thanks Jim, I 've used a 245° @ .050 and .480 @ the valve on the intake lobe!
Cheers,
Christoph
Joel Mohr
August 28, 2012, 22:31:23 pm »
NICE!!! Chassis Dynos can be deceiving though...you should try a quarter mile to back up the numbers...
SEE YA AT THE RACES!!!
dyno don
DGVA DZK (old school 70's)
August 29, 2012, 08:07:01 am »
Did someone say Single Ports?? Gentlemen step up to the bat and purchase MY heads from the 70's... 1600 s/p kadrons 15:01 @ 87 mph in Notchback. Freshened by the talented Fred Simpson and now just need a good home with Love. Sorry to jack the thread boys... Peace out, Dyno ps, BTW... Your engine looks sweet , makes good power, and will a blast to drive. Enjoy...
whirligig
August 29, 2012, 12:21:30 pm »
planing to build a 1641 with unknown cam (reground almost to base circle )single port with holly bugspray to go in my 66
old school racer-getting older-now crew chief
besserwisser
August 29, 2012, 22:02:42 pm »
Now we are getting down to serious bussiness. Will be putting my 1835 single port with Teo decker kit on the dyno at JPM in oktober. To give you a hint it wont start with the six volt battery so I have a 12 volt to get it started then I leave it to the magnet when i change to six volt. Drove it down to germany last spring for Maikäfertreffen with lots of power and great gasmilage. Would like to hit over a hundred but who knows.
freakpower
August 29, 2012, 22:41:19 pm »
Quote from: Crazy Mc.Stairs on August 28, 2012, 21:12:34 pm
Hi all,
Cheers,
Christoph
Hey, congratulations with a wonderful engine
Would you tell us a bit more: What kind of camshaft, exhaust and compression?
Crazy Mc.Stairs
August 30, 2012, 20:21:39 pm »
Quote from: freakpower on August 29, 2012, 22:41:19 pm
Hi all,
Cheers,
Christoph
The engine has 88mm thick wall Mahle cyl/pistons
Stock 69mm balanced cranck
Stock rods
PRO 001 SP heads with 35.5/32mm SS valves
8.7/1 compression ratio
34l/s of flow through the intake @ 10"
29.5l/s of flow through the 34mm PCIT Solex carb with 28mm venturies @ 10"
Scat HD single springs
Dual lobe Engle camschaft on modified lobe centre
12.2mm valve lift with 1.3 CB rockers
Modified 35mm exhaust with Sebring muffler
Best regards,
Christoph
Proformance
youngnstudly
September 03, 2012, 06:41:55 am »
I hope my 1915 SP makes some power similar to that! Sounds fun and looks very cool too! I like the car as well.
-Andy
Henrik Hagen
August 13, 2013, 13:49:33 pm »
hi
Is it possible to see some pictures of the heads??
How much porting did you do?
