November 03, 2026, 04:17:29 am
| | |-+  Two supposedly same cams
Author Topic: Two supposedly same cams  (Read 5902 times)
Chris bugster
« on: October 14, 2012, 14:04:34 pm »
We ran two Scat cams in the same engine- C85 and though they are supposed to have 287 degrees of duration at 50 thou checking, the first one came out at 280 and the second one at 292. I won't even go into the difference in lift- the smaller duration one had more lift. Anyway, I mainly use Scat cams and was wondering if everyone makes cams of such vastly different specs even though they are supposedly the same or if it's just Scat.
11.2@124mph
Erlend / bug66
Global Moderator
SCC Event
« Reply #1 on: October 14, 2012, 14:23:01 pm »
Maybe wrong markings? Do the specs match another scat cam?
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
Chris bugster
« Reply #2 on: October 14, 2012, 14:47:34 pm »
Well, the second one was close to a C75 (FK 98) on duration, but down on lift. I have a C75, but never checked what it ACTUALLY has and so am going by what the card reads.
11.2@124mph
« Reply #3 on: October 14, 2012, 19:20:11 pm »
Chris
is this lift at the cam? how old are the cams you are measuring?
cheers richie
dangerous
« Reply #4 on: October 14, 2012, 22:28:16 pm »
292 @ .050" at the cam is what I have dialled in the C85 as. I like the profile but it is a big sucker.
Perhaps the other one is a mis-marked C89.
fish
« Reply #5 on: October 16, 2012, 01:33:37 am »
280@.050 with higher lift sounds like C89 to me also
Chris bugster
« Reply #6 on: October 16, 2012, 07:35:34 am »
Sounds like that's the answer then, one is just badly stamped. Thanks Gents.
11.2@124mph
