September 22, 2026, 18:38:52 pm
| |-+  For sale!
| | |-+  103mm x 84mm OXY boxer engine parts for sale
Author Topic: 103mm x 84mm OXY boxer engine parts for sale  (Read 9655 times)
« on: October 14, 2012, 23:12:41 pm »
2.1 vanagon waterboxer case,machined by Geers engineering
It has been set up for type1 style lifters,align bored for all type 4 mains,has rear bronze thrust conversion,water jackets removed & been decked etc[head stud inserts converted for 10mm head stud use] to use 4inch aircooled cylinders.Comes with narrowed modified german KS type 4 bearings to suit.
new:
84mm flange crank,all type 4 mains/chevy rod journals with matching flange flywheel
Scat 5.5 h beam rods[3/8 arp 2000 bolts]
Kennedy stage 1 cover
All match balanced
Flange seal
WBX pulley seal
Empi pulley modified for WBX case
New:
JE custom 103mm pistons[with pins/rings and clips]
AA 4inch cylinders bored to 103mm and match torque honed to the JE pistons
scat straight cut cam gears
scat lifters
WBX push rod tubes
Clevite rod bearings
mahle cam bearings
All sold together £3500
price reduced to £3250
Also
Can also be supplied with CB comp eliminator heads,modified for 4inch/WBX stud pattern,48/40 valves[ti intake/steel exhaust] ported for turbo use or with bare new angleflow 4inch heads.
ask for pricing on which spec you require
pictures to follow
cheers richie
« Last Edit: December 09, 2012, 19:42:41 pm by richie » Logged
« Reply #1 on: October 16, 2012, 02:10:22 am »
It wont seem to let me upload pictures at the moment,I get the message: upload folder full?
 so I will try again tommorow
cheers richie
Trond Dahl
« Reply #2 on: October 16, 2012, 08:15:28 am »
cheers richie
Fixed, sorry about that.
Race car 9.49/236kmt@SCC 2017
« Reply #3 on: October 16, 2012, 17:11:20 pm »
[ Attachment: You are not allowed to view attachments ] case half showing the lifter bore conversion,the thrust mods for flange crank [ Attachment: You are not allowed to view attachments ] some of the pieces for the engine [ Attachment: You are not allowed to view attachments ] the flange crank with rods and gears fitted
« Reply #4 on: October 16, 2012, 23:50:32 pm »
[ Attachment: You are not allowed to view attachments ] 103mm custom JE pistons [ Attachment: You are not allowed to view attachments ] comp eliminator chambers
« Reply #5 on: October 30, 2012, 19:41:53 pm »
I have had several enqiries about individual items, but as these parts are all machined and balanced together i dont want to seperate them, I have highlighted these items in red and added the price for them
I will sell either pair of heads on there own, the comp eliminators are £1600 complete, the angleflows are £650 bare
cheers richie
« Reply #6 on: December 09, 2012, 19:43:27 pm »
Price reduced on short block kit,see 1 st add for price change
thanks richie
« Reply #7 on: January 04, 2013, 08:58:51 am »
Lots of interest in 4inch engines at the moment,why wait months or even years to actually get your parts when you can get it all now in one go Wink
still for sale
