October 02, 2026, 16:07:38 pm
Clutch tech
6
7
8
Topic: Clutch tech (Read 245396 times)
Silversoar
Re: Clutch tech
Reply #180 on:
April 19, 2016, 21:58:34 pm »
Thanks for reply!
Thomas H
Barbapapa Racing
broen messiaen
Re: Clutch tech
Reply #181 on:
April 21, 2016, 17:56:16 pm »
Got my clutch management installed and bleeded.
Let's hope it works good
Verzonden vanaf mijn iPhone met behulp van Tapatalk
Typ3racing
Re: Clutch tech
Reply #182 on:
January 15, 2017, 17:43:23 pm »
No clutch news anymore?
As i switched to an new engine, and had to make a new flywheel,
why not a new clutch also?
After a lot of problems its working now.
Re: Clutch tech
Reply #183 on:
January 15, 2017, 22:51:59 pm »
All this talk about custom clutches..
My stage 4 + thick Black Magic (and CMS) went 1.441 60-foot at SCC2016. Full steel car. 215/65-15 DOT's.
No need to make it custom or difficult
Re: Clutch tech
Reply #184 on:
January 16, 2017, 09:38:46 am »
Quote from: Erlend / bug66 on January 15, 2017, 22:51:59 pm
It will be when you want to go fast
and I thought you had day moulding wings on that car?
Trond Dahl
Re: Clutch tech
Reply #185 on:
January 16, 2017, 12:44:46 pm »
Quote from: richie on January 16, 2017, 09:38:46 am
Thats probably why he wenter 0.07 faster ... :-D
Race car 9.49/236kmt@SCC 2017
Typ3racing
Re: Clutch tech
Reply #186 on:
January 16, 2017, 13:02:36 pm »
The goal is to reach 1.3..
With 2500lbs car(and driver)
1.7l Turbo engine.
IMHO its better to have more rotating mass to get the car launch properly.
In comparison to the Subaru/AP Clutch-flywheel crankshaft assembly now i got 15kg more weigt.
Basti
Re: Clutch tech
Reply #187 on:
January 16, 2017, 13:08:26 pm »
15 kg???
- black 62 cal look beetle
- Pro Mod Race car
Typ3racing
Re: Clutch tech
Reply #188 on:
January 16, 2017, 14:10:11 pm »
Quote from: Basti on January 16, 2017, 13:08:26 pm
15 kg???
Yes.
+8kg Crankshaft
+7kg Clutch/Flywheel
Re: Clutch tech
Reply #189 on:
January 16, 2017, 14:42:39 pm »
Ok. Heavy steel car but day mouldings.. and a heavy steel 6-point cage. And real glass!
I even have a roof!
Re: Clutch tech
Reply #190 on:
January 16, 2017, 16:55:15 pm »
Quote from: Erlend / bug66 on January 16, 2017, 14:42:39 pm
Ok. Heavy steel car but day mouldings.. and a heavy steel 6-point cage. And real glass fiber !
I even have a roof!
I have a roof on my 67 to, similar car to yours as well
only went 1.45 60ft though, maybe with some C/M it will go quicker
Re: Clutch tech
Reply #191 on:
January 16, 2017, 17:18:24 pm »
Quote from: richie on January 16, 2017, 16:55:15 pm
I even have a roof!
1,45!!! That's slow man
Re: Clutch tech
Reply #192 on:
January 16, 2017, 17:39:51 pm »
Quote from: Erlend / bug66 on January 16, 2017, 17:18:24 pm
Yep but ok for a cable and no tricks or fancy stuff like C/M
, and still went 10.42 so something works
Re: Clutch tech
Reply #193 on:
January 16, 2017, 22:27:52 pm »
Quote from: richie on January 16, 2017, 17:39:51 pm
You should bring the white car to SCC! Then we could have a big power adder '67 matchup!
Torgeir, you and me. Closest one to 9.99 wins a cup of tea?
Re: Clutch tech
Reply #194 on:
January 17, 2017, 09:52:16 am »
Quote from: Erlend / bug66 on January 16, 2017, 22:27:52 pm
So if I go 9.80 and you run 10.05 you win? doesn't seem right
Wont be this year as Drag week will take all my budget up
Jyrki
8.88 & 251
Re: Clutch tech
Reply #195 on:
January 17, 2017, 10:02:53 am »
So it must be the fiberglass that makes all the difference
My old '65 street car with fiberglass body parts ran a best of 1.29 on dot tires, stage 3 + black magic. The chassis car has a tricky clutch and real slicks, but is slower to 60ft. BUT it is 100% steel
Jyrki
Re: Clutch tech
Reply #196 on:
January 17, 2017, 23:45:11 pm »
Quote from: richie on January 17, 2017, 09:52:16 am
Haha, well.. Best ET wins
Re: Clutch tech
Reply #197 on:
January 18, 2017, 11:00:40 am »
Quote from: Jyrki on January 17, 2017, 10:02:53 am
Jyrki
Very good 60ft for DOTs on your old car, this year your steel car should 60ft better than that though
kraftkaefer
Re: Clutch tech
Reply #198 on:
December 06, 2017, 06:27:24 am »
Hi clutch experts
Want to use the McLeod 8" clutch cover with B/M Disc for my 3.0 Pauter (hoping for 300hp
For the clutch setup i have a steel pressure ring made by Pauter and a aluminum ring (Picture) here. Which one would you use, some experience with distortion on the light one?
Thanks for helping!
Stefan
www.kraftkaefer.de
FULLA GROFFD Drag Racing
Airspeed
Re: Clutch tech
Reply #199 on:
December 06, 2017, 11:20:09 am »
I think a steel (rubbing) ring is usually used, in order to use an alu flywheel (not the other way around?)?
My recent update with two new and mostly thicker plates, which meant I could remove my steel ring alltogether (hence the small holes where the attachment screws were):
bedjo78
Re: Clutch tech
Reply #200 on:
December 06, 2017, 12:29:18 pm »
what dual discs ? where you bought them ?
Airspeed
Re: Clutch tech
Reply #201 on:
December 06, 2017, 14:27:22 pm »
Quote from: bedjo78 on December 06, 2017, 12:29:18 pm
Tilton.
As I use a G50 transmission, which has the same spline as Mendeola, these have 23x 1" spline.
Bought in the US online at one of the big race part shops, forgot the name atm, but will post it later for you
Re: Clutch tech
Reply #202 on:
December 07, 2017, 00:10:53 am »
Airspeed, that is a very light flywheel
is it a 200m?
Airspeed
Re: Clutch tech
Reply #203 on:
December 07, 2017, 14:10:26 pm »
Quote from: Eddie on December 07, 2017, 00:10:53 am
is it a 200m?
4,2kg; its a chinese chro-mo 200mm version, but the disks are only 177mm outer diameter (inch size converted), but the inside minimum diameter of the disks exactly fits the 200mm parth of these flywheels, which is pretty lucky/briljant if you ask me :-)
MeXX
Re: Clutch tech
Reply #204 on:
April 29, 2021, 07:45:47 am »
Hi volks...
Found a nice video of a TF clutch...
enjoy ....
http://www.youtube.com/v/1V6nBdiK118
Last Edit: April 29, 2021, 11:49:57 am by MeXX
Drag or Die
kraftkaefer
Re: Clutch tech
Reply #205 on:
April 29, 2021, 08:07:37 am »
Servus Martin,
looks good.
Do you use still the single clutch on your setup ?
Stefan
www.kraftkaefer.de
MeXX
Re: Clutch tech
Reply #206 on:
April 29, 2021, 08:22:08 am »
Quote from: kraftkaefer on April 29, 2021, 08:07:37 am
Servus Martin,
looks good.
Stefan
Hi Stefan...
Yep still single disc setup.... even more... to keep the package tight and light it is a double disc (6,5mm thick) used as a single disc...
Although higher launch RPM +9000.... is causing significantly more wear.... especially on unprepared tracks like Zerbst, where I had to slipp the clutch 1.52s on the last run.....
MeXX
Drag or Die
PPRMicke
Re: Clutch tech
Reply #207 on:
April 29, 2021, 15:02:23 pm »
Hi
The thing about the clutch on an NA car is more sensitive
Than on a car that has a boost
If you are going to use the clutch Infon in a VW, you should look at prostock what they do with it
After being C C in prostock (v8) (promod) o love Vw (pro stock about 1500 hp o 1066kg) When we started to use that knowledge in a NA vw the numbers went down to 60 and Et
What we started to do was go there with a heavy flywheel because the power on the engine is not enough to use the slip in the clutch
We went from 1.44 to 1.38 then with a lot of adjustment we were down to 1.34
Since you measure your slip pressure on the clutch, it is very important
Uploads a film of how we work with clutch in the prostock world
Seeing Topfuel is not right because you have too much effect so you remove type 8000hp on the starting line in the clutch Same with promod where we can remove 2000 hp in the clutch
/// Micke
https://www.youtube.com/watch?v=QggcByD3Njs&ab_channel=NHRA
Christiano
Re: Clutch tech
Reply #208 on:
April 29, 2021, 19:24:35 pm »
Quote from: PPRMicke on April 29, 2021, 15:02:23 pm
This!
You either go with a really light combo (aluminum flywheel+steel friction surface) on a true CENTRIFUGAL clutch, like the prostock ones, or you go with a heavier flywheel on a conventional setup.
This will give you more momentum and really help to launch. You can even start leaving with a lower RPM to take it easy on the tranny and everything else.
MeXX
Re: Clutch tech
Reply #209 on:
May 01, 2021, 08:10:56 am »
Some pix of my actual clutch setup...
Before and after service...
Drag or Die
6
7
8
