September 22, 2026, 07:09:36 am
| | |-+  Type I to Type III Engine
Author Topic: Type I to Type III Engine  (Read 4235 times)
« on: March 15, 2013, 04:31:59 am »
Building a 82X94 motor, using a Autoleania alum case. What tricks  do you use to pull the dip stick tube out??
Ted
« Reply #1 on: March 15, 2013, 19:48:38 pm »
Ted
alot of heat, propane torch or similar seems to work,the ally expands more and the glue/sealant softens up,still a bitch to get them out though
Fredy Kucmocht
« Reply #2 on: March 15, 2013, 23:52:56 pm »
Why to you want this, I always use Typ1 style case's in my Notchback. You can use the Typ 1 tipstick with Typ3 cooling or you can use the tipsticktube for a tipstick-tempsensor
« Reply #3 on: March 17, 2013, 08:54:03 am »
i had one removed and regretted doing so. i just fit a rubber which is blocked off at the top over it with two clamps and that is it. easy to remove and you won't see a thing when you put the type3 cooling on it.
