September 22, 2026, 23:32:39 pm
This is the gearbox going in my next floorpan..and project car....
Topic: This is the gearbox going in my next floorpan..and project car.... (Read 4021 times)
rick m
June 02, 2013, 04:24:33 am »
I have always wanted to put a 911 gearbox in my street VW and I will be doing it in the future. 5 tall gears made just for crusing...that nice long first that allows you to clear the intersection before shifting. It has been a long time but I am finally starting to gather parts. I have the straight VW pan (66), the gearbox is being finished up...and I am prepping the suspension parts. I will run Type 2 stub axles on this too. They are bullet proof on a car that is over 1,000 lbs lighter than a bus. Will be making custom hubs, narrowing the IRS arms, etc.
Rick M
Rick Mortensen
Driving Hot VWs since 1970
Re: This is the gearbox going in my next floorpan..and project car....
June 02, 2013, 20:16:57 pm »
Is that a 901 trans Rick??? -- I've got a 901 in the Ghia currently and I really like it -- the only things that suck are (1) where the clutch arm is located, bottom left side, I would recommend doing a 1" trans raise so that the clutch arm is away from the horns; (2) on the shifter first is dog legged to the left, reverse is away from you and 1st is right below it, so your 1st/2nd shift is like a normal 2nd/3rd (OH, no hard lauches on that 1st gear they are VERY weak) -- If you have a 901/07 or /13 they come with the ZD 5th gearing and 4th is also OD geared for making a really nice freeway cruiser --
I think I've got a spare set of /13 4th and 5th gears in the rollaway
You'll love it
Last Edit: June 02, 2013, 20:24:37 pm by Fiatdude
http://selvedgeyard.com/
rick m
June 03, 2013, 05:12:10 am »
Fiatdude....It is in fact the 901. I just want it for the cruising characteristics. The car it is going in has the trans raised so I know what you mean about the clutch arm. I have a lot of mods I am doing on my floor pan so the trans location is the easiest part of my set up. I got the idea from Steve Beecher in the DKP years ago. I am finally getting around to doing it. Thanks for the feedback. I may get ahold of you to see what gear combos you have.
Rick Mortensen
Rick Mortensen
