October 13, 2026, 04:38:18 am
| | |-+  That Red Fiat at EBI.
Pages: 1 [2] Print
Author Topic: That Red Fiat at EBI.  (Read 36888 times)
« Reply #30 on: October 04, 2014, 17:51:24 pm »
Very cool Grin
« Reply #31 on: October 04, 2014, 18:38:38 pm »
Nice!
Congratulations!
« Reply #32 on: October 04, 2014, 20:14:42 pm »
the fiat sounds good IAN , nice to see the car running again ,
just a question , will run the car without front windshield ??
Martin Greaves
10.88@128.58
« Reply #33 on: October 04, 2014, 20:29:53 pm »
Still with the 1804cc Ian.
melvin
OFF/83
« Reply #34 on: October 04, 2014, 23:21:04 pm »
sounds good Smiley
OFF/83
DaveN
« Reply #35 on: October 05, 2014, 09:33:52 am »
I think Ian s engine is  94 x 72 . 1998cc lots of rpm!
Martin Greaves
10.88@128.58
« Reply #36 on: October 05, 2014, 14:05:32 pm »
You sure Dave was thinking it was 65X94.
DaveN
« Reply #37 on: October 05, 2014, 14:44:27 pm »
im not sure now , i thought the crank was able to be reused after the other engine broke?  Ian will know.
spanners
« Reply #38 on: October 05, 2014, 15:27:15 pm »
[/quote]
It's 72 x 94 = 1999cc @ 11.5:1 so it runs on pump gas. German Mag case. Wedgemated welded/CW offset ground to chevy journal VW crank and flywheel (8lbs) with modified (lightened) aluminium Bill Miller 5.2"rods and JE pistons/Mahle barrels with nearly 3/4" cut off the bottom! Nice and narrow so short pushrods..260mm. Good 'ol FK89 (a Raptor is on the wish list for the next motor) and some old ARPM heads 44 x 37 Ti valves that Lee 'the funky head' Maynard did some major work to (obviously he comes highly recommended and is happy to work on anyones heads for race vouchers!!$$).....we kept the inlet ports small tho' and I spent ages getting everything dowelled/match ported with a very accurate valve job (on a Newen machine) and tapered seats etc......Lots of used old parts in there but good quality stuff and alot of hours fettling etc....
It's got the old 48's fuel reg and Vertex mag off my '52....one of the carbs had a dead moth in it...it's been that long!
It should pull 9000rpm....I was being gentle at EBI....6.5-7maybe....so we'll see what it sounds like then.....  Smiley
Ian
[/quote]
Tells all here.
Best regards, spanners.
DaveN
« Reply #39 on: October 05, 2014, 15:44:51 pm »
Thats the one that broke.
Brian
« Reply #40 on: October 05, 2014, 17:26:22 pm »
Nice car! Could you tell me more of your suspension setup? I have a 600 that I need to set up a little better. What size torsion bars do you have?
Thanks.
« Reply #41 on: October 05, 2014, 18:06:25 pm »
Thanks.
Ian will obviously know more, but its a tube chassis car so does not have torsion bars
Lee
« Reply #42 on: October 05, 2014, 18:34:01 pm »
here's the front suspension
« Reply #43 on: October 05, 2014, 18:42:08 pm »
 Wink
GASBNR
« Reply #44 on: October 06, 2014, 01:05:53 am »
COOOL STUFF Ian
SUPPORTING CAL-LOOK DOWN UNDER
« Reply #45 on: October 06, 2014, 01:27:57 am »
 Shocked
That thing would weigh less than my lawnmower!
Thank you for the pics, very cool.
 Cool
WPS
« Reply #46 on: October 06, 2014, 17:49:21 pm »
Yeah thanks for reminding me Dave... Roll Eyes
Those aluminium rods were a bad idea...no history and had been extensively lightened.... but I was seduced by their lightness!! They broke.... Sad
Anyway it's still 72x94 as before just with some steel rods and abit more compression as I could close up the deck as ali rods need more room to expand.
Martin...The 65mm crank will be used for the cars next engine.....eventually....
Fabs....We made a windscreen...I say we, I mean Pete did hours of cutting and filing (his favourite pastime) then when I moved it dissappeared!! So this happy accident has made the car all the more thrilling to drive and halved the frontal area I reckon....it may get a torneau cover,it may get a hood and the screen remade (if it doesn't turn up)....It'll probably get left as is....112mph felt like 150!! more bang for ya buck!! Shocked
Brian...The rear suspension is 4 link with some period Koni coil overs....but for the 600 a simple ladder bar set up would work great. The std fiat rear end is good for fiats and massive wheelies but you'll need a massive wheelie bar ala Big Pete's 600 to make it off the line quick....so simple ladder bar and coil over adj dampers etc (rear spring rate depends on power and overall weight etc etc).
I just need to drive it some more!!!
Ian
   WolfsburgPerformance.co.uk
      Instagram:  wpsengines
             07880-311850.
Martin Greaves
10.88@128.58
« Reply #47 on: October 06, 2014, 20:51:46 pm »
Thanks Ian had it in my head you was using the 66mm.
What the spec of the motor that is in the Fiat at the moment.
Pages: 1 [2] Print
