November 02, 2026, 20:31:59 pm
type 4 200mm aftermarket flywheel problem
Topic: type 4 200mm aftermarket flywheel problem (Read 17361 times)
Eddie DVK
July 07, 2013, 10:39:02 am »
Hi,
Do people who have a type 4 200mm aftermarket flywheel run in trouble with eating up cranck-flywheel seal.
I am driving the engine about 2 year (about 6000km) with this flywheel and it is the 3th time that the flywheel seal starts to leak.
Are the measurements off this flywheel off? especially the radius, which I can t measure?
I tryed both versions off seals normal and vitton one, but the result is the same after about 2000 km it starts to leak (and slipping of the clutch).
Help appreciated
Regards Edgar
Last Edit: July 07, 2013, 10:40:51 am by Eddie
Regards Edgar
spanners
Re: type 4 200mm aftermarket flywheel problem
July 07, 2013, 10:55:48 am »
Most folk fit the seal wrongly and only flush with the case, it must seat right down in the case bore.
Best regards, spanners.
Eddie DVK
July 07, 2013, 19:55:07 pm »
ok, I did that to, but that s how it is written in most manuals..
You say I have to put it in till it will not go futher?
Edit: If you putt it whole in, won t it block the oil galley that lubricates the flywheel seal if I remember correctly?
Regards Edgar
Last Edit: July 07, 2013, 20:26:08 pm by Eddie
Regards Edgar
JIMP
July 08, 2013, 06:43:35 am »
Eddie
you mean the chinese version that comes directly for 200mm clutch? If this is the case maybe the flywheel is the problem, we used one on our drag car beleiving that is a true forged one as they told us. I understood that something isn't 100% O.K. when we were making some test measurements and we had to put on and off the flywheel several times, in that time we didn't use the central washer with 5 holes for the bolts but we secured directly with bolts and not even in the specified torque but less. When we got the bolts off, the spots on the flywheel were like "milled" from the bolts heads, that soft it was. So wasn't any surprise for us when on the dyno after about 6-7 sessions ripped off altogether on the flange section, only 1 bolt remained tight and that saved the rest of the engine -and us- . We're supposing that being so soft some of the bolts loosed their preload and started getting undone, after this the disaster is not away, so what I want to say for your case maybe being that soft has already done some kind of "channel" like an aluminum would do so the seal can't do it's job any more, I would check it if I was you
Friendly
Dimitrios
karl h
July 08, 2013, 06:48:11 am »
only the porsche 914 flywheels are forged (like all type 1 Flywheels), stock type 4 is cast
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
Eddie DVK
July 08, 2013, 09:54:04 am »
Quote from: JIMP on July 08, 2013, 06:43:35 am
Eddie
Friendly
Dimitrios
Yes I mean the flywheel that accepts the 200 type 1 clutch stuff.
Ok that doesn t sound ok. I didn t notice the softness sofar. But will check.
Will have to look if the bolts are still on the torque spec. I can t remeber from the two times that I pulled the engine that those where off.
The endplay of the crank was not off, I measured those and that was still ok.
Just the seal is leaking, the last time I polished(scottsbride) the 'neck' of the flywheel a little. But without result.
Bought a type 4 215mm flywheel, I think I am going to use that one, and see if that one starts to leak after a few thousand km.
Regards Edgar
Last Edit: July 08, 2013, 09:55:36 am by Eddie
Regards Edgar
Eddie DVK
September 16, 2013, 10:04:00 am »
Bump,
somebody maybe got a solution on how to put the seal in correct, or some kind of special treatment for the seal or flywheel?
Regards Edgar
Last Edit: September 16, 2013, 11:33:28 am by Eddie
Regards Edgar
September 17, 2013, 11:18:24 am »
I have a brand new original 200mm flywheel for sale :-)
Did you messure if it does not go up and down ? some do not have the center of the crank at the flywheel
www.Udobeckertuning.de
spanners
September 17, 2013, 16:13:58 pm »
Fit the seal to the BOTTOM of the bore, not flush with the case, if you do it will leak, fit a new 'o'ring, ensure end float is to spec, lubricate lightly the flywheel radius and 'o' ring and fit the flywheel, my flywheel is Chinese made' European' one 200mm T4 type, its good quality and hard as it should be, i've raced it hard for years no problems.
Old Guy
Barrett Racing Pro Gas 10.75ET 123.18MPH
September 17, 2013, 16:20:42 pm »
All Chinese flywheels are not the same. I know the AA 200mm, 215mm and 215mm Porsche are all Forged.
Old Guy
JIMP
September 17, 2013, 17:19:23 pm »
Posted by: Old Guy
Insert Quote
Yes probably, the one I had it wasn't AA, it came in a white box with no writing at all on it, now that I see that lot of people are using them and mine being scrap already I will make some test to see material and hardness and let you know,
Friendly
Dimitrios
Eddie DVK
September 18, 2013, 09:23:48 am »
Quote from: Udo on September 17, 2013, 11:18:24 am
I don t know never measured that, I measured the outside diameter of the flange and that size was the same as a original type 4.
Udo you got PM
Last Edit: September 18, 2013, 09:40:16 am by Eddie
Regards Edgar
Eddie DVK
September 18, 2013, 09:24:30 am »
Quote from: spanners on September 17, 2013, 16:13:58 pm
Ok will try this. thanks
Regards Edgar
Regards Edgar
Typ3racing
September 18, 2013, 20:57:51 pm »
Like most of the cheasp aftermarket engine parts,
those flywheels are crap.
throw it as far as you can!
Erlend / bug66
Global Moderator
SCC Event
September 18, 2013, 21:17:13 pm »
DPR makes a 200mm flywheel with a german T1 core
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
Airspeed
September 19, 2013, 13:50:39 pm »
I used this flywheel (with custom bolts) and it holded 465 hp on my old 2,2ltr type 4 turbo engine with a twin plate Tilton clutch.
Its a nice forged flywheel imo and works well if you machine and install things corrrectly (as always).
Eddie DVK
September 30, 2013, 09:29:29 am »
I like to thank Udo (Becker),
He always comes to the rescue (when I have some sort off trouble with my engine) with advise or parts.
Real outstanding guy.
THANKS
Regards Edgar
Last Edit: September 30, 2013, 09:43:07 am by Eddie
Regards Edgar
