May 21, 2026, 00:08:52 am
Latest Member: mvptkfjb
| |-+  Wanted
| | |-+  912/356 top pully
Author Topic: 912/356 top pully  (Read 11561 times)
Garrick Clark
« on: September 01, 2013, 12:22:07 pm »
Hi guys.
I'm looking for a top pully off a 912/356 to fit my bug alternator.
It comes in 3 pieces.
Thanks   G
Air cooled Engine builder
« Reply #1 on: September 01, 2013, 17:38:40 pm »
Pelican parts still sell new OEM pulley pieces for the 912/356.
http://www.pelicanparts.com/cgi-bin/ksearch/pel_search.cgi?SUPERCAT_FLAG=&make=&please_wait=N&forumid=&threadid=&command=DWsearch&description=pulley&I1.x=9&I1.y=8&FILTER_356M=ON&FILTER_TECH=ON&FILTER_SUPP=ON&FILTER_ACCE=ON&FILTER_CARE=ON&FILTER_STUF=ON&FILTER_PERF=ON&FILTER_MISC=ON&FILTER_GADG=ON&FILTER_TOOL=ON
« Reply #2 on: September 01, 2013, 19:17:16 pm »
They are junk. I highly recommend finding an original.
Garrick Clark
« Reply #3 on: September 01, 2013, 20:45:51 pm »
anyone got an original one in the uk
Thanks G.
« Reply #4 on: September 02, 2013, 17:50:00 pm »
What makes you claim they are junk? I bought the 3 pieces and it is high quality unit. The fit and finish are what I would expect from Porsche.
« Reply #5 on: September 02, 2013, 18:36:04 pm »
They do look nice but I've seen 3-4 of them end up spinning a pulley half (in a very short time). My guess is the pulley isn't made out of the correct steel. I've yet to see an original do that.
Airspeed
« Reply #6 on: September 19, 2013, 18:56:17 pm »
Hi guys.
Thanks   G
I have an original set that I am not using anymore.
Are you covered or still wanting one? (PM?)
Garrick Clark
« Reply #7 on: September 20, 2013, 21:51:27 pm »
Hi airspeed.
I haven't bought one yet.
Been busy with other things,
How much would you want for it.
Thanks G
Airspeed
« Reply #8 on: September 21, 2013, 16:45:41 pm »
I'll send you a PM.
Garrick Clark
« Reply #9 on: September 22, 2013, 21:54:22 pm »
Hi Airspeed.
Got your pic.
I have a question.
I'm going to run this to get more cooling to the heads.
I run a type 4 with up right cooling.
The standard top pulley is fitted to the alternator in a back to front manner so as to align the top pulley with the bottom.
would this 912 pulley you have fit on to the keyway as I have described above.
If you could try this for me and it fits without interfering with the alternator i'll buy it.
Thanks G
Airspeed
« Reply #10 on: September 23, 2013, 07:06:09 am »
Not sure what you mean by that, but I have a stack of original porsche shims with it as well and you can use this under the first pulley halve to shim out both halves forward to align something. Thats how I used it also for my modified crank pulley trigger set-up.
I don;t think you should (or can?) reverse mount it, but there's no need either imo.
axam48ida
« Reply #11 on: September 23, 2013, 07:09:03 am »
Try NLA in Reno. They specialize in 356' 912's
The ultimate source for Porsche 356 and Porsche 911 ...
Most Extensive 356 Parts Inventory NLA Limited : Everything for the Porsche Enthusiast and their Porsche
www.nlaparts.com
« Reply #12 on: September 23, 2013, 08:41:10 am »
Walter (airspeed),
If you use a type 1 upright cooling on a type 4 engine the pully s (on the generator) don t line up, so that why they sell a 'reversed set up' for a type 4 engine. they switch the inner and outer pully halves (normally the inner is welled to the hub) on this set up it is loose, so they switch the outer to the inside and because off different offset off the they than line up.
But as you said I think the 912/356 pully is already in 3 peaces (not welded to the hub) so if you shim them they will line up. Right?
Airspeed
« Reply #13 on: September 24, 2013, 20:52:14 pm »
Exactly!
Tourist
« Reply #14 on: September 26, 2013, 05:10:55 am »
Good morning Garrick,
The parts are still available directly from Porsche in the UK to order, I got quoted a two/three day turnaround from ordering.
Found the part numbers from here:
http://www.porsche.com/uk/accessoriesandservice/classic/genuineparts/originalpartscatalogue/
Main Group 9: Electrical Equipment- page 512, items number 6, 7, 8, 10 and 11
http://www.porsche.com/all/media/pdf/originalparts/en/E_911-1_KATALOG.pdf
item 6:   (quantity 1 off.)   547 09 304 hub
item 7:   (quantity 1 off.)   539 09 315 pulley I (inner)
item 8:   (quantity 1 off.)   539 09 326 pulley II (outer)
item 10: (quantity 19 off.) 539 09 314 spacer
item 11: (quantity 1 off.)   547 09 303 nut
547 09 304 - x1          =£21.82 inc vat
539 09 315 - x1          =£25.93 inc vat
539 09 316 - x1          =£25.93 inc vat
539 09 314 - x19        =£32.15 inc vat
547 09 303 - x1          =£19.67 inc vat
Hope this helps, at least you have another option. Smiley
All the best,
Martin. Cool
Garrick Clark
« Reply #15 on: September 29, 2013, 19:28:51 pm »
Hey Martin thanks for the info on the pulley.
I'm still unsure if the main hub part will fit the alternator in reverse order as described above by Eddie.  This way I could just get the hub 1st an see if it fits then get the other parts.
Thanks G
« Last Edit: September 29, 2013, 19:30:22 pm by GARRICK.CLARK » Logged
Tourist
« Reply #16 on: October 02, 2013, 20:55:56 pm »
Good evening Garrick,
Do these pics. help you a little more? The inner half as far as I am aware, would be the notched half under normal circumstances.
I would offer to stick them on my engine, but am about to go on holiday shortly Grin so wouldn't be able to do it for a good few weeks.
(Don't know if this will help, http://www.thesamba.com/vw/classifieds/detail.php?id=1199564 , it's an alternator conversion kit for a 356/912 that uses a type 1 alternator, so at least you know the pulley has a chance of fitting in it's regular configuration).
All the best,
Martin. Smiley
Garrick Clark
« Reply #17 on: October 28, 2013, 14:00:24 pm »
Walter.I've done the payment .Should be clear in 3 or 4 days
Airspeed
« Reply #18 on: October 28, 2013, 16:19:59 pm »
Thanks! When the transfer clears, I'll let you know!
Regards,
Walter
