September 24, 2026, 03:42:17 am
| | |-+  Info about this splitwindow?
Author Topic: Info about this splitwindow?  (Read 25294 times)
Jordy/DVK
« on: July 28, 2007, 13:51:02 pm »
 Hey Guys,
 Does anyone of you know whose car this is? I'd like to know more about it.
 I'm working on my own split at the moment and I'd like to know what needs to be modified to fit later parts (gearbox) to a split pan.
 I'd like to do it all without too much cutting/grinding and that's why I'm looking for some practical info regarding splits on this topic.
 And those wheels, does anyone know what make they are. I was planning to use exactly that style of wheels (including the patina) for my split...
 Oh and this is my wreck!!! Grin     (the trailer bitch  Grin)
  "The Full-Throttle Cruisers"
jmarkha1
« Reply #1 on: July 28, 2007, 14:02:00 pm »
Ian Clarke (Wolfsburg Performance) owns the car - ercos that have been media blasted...
Olaf A./DFL
« Reply #2 on: July 28, 2007, 14:13:42 pm »
to fit a synchronised gearbox you have to get a T1 bus nose cone and hockey stick (or modify a normal hockey stick from a synchronised gearbox) and the matching mount -you can get all of that stuff at csp-shop.de -it's just plug 'n play  Smiley
if you need more info just send me a pm and we can chat about it.
« Last Edit: July 28, 2007, 14:15:31 pm by olaf » Logged
« Reply #3 on: July 28, 2007, 17:26:13 pm »
jordy i send you by mail the report from the volksworld nov 2000  Wink
Martin Greaves
10.88@128.58
« Reply #4 on: July 28, 2007, 17:30:04 pm »
That well of of date it has a berg 5 speed in it now.
Black Sheep
less is more
« Reply #5 on: July 28, 2007, 17:32:50 pm »
Ians car is top notch  Cool, wheels are ercos I believe with a subtle amount of detailing I just love em  Smiley, as for bolting up later bits and bobs what do you need to know as I'm running a 2007 on a 5 speed 901 box with a slightly narrowed front end on my 49 . any mods are much the same as any work you should want to do on a later car , its just when you want any pre 53 bits the prices triple  Cry Shocked!
If I can be of any help feel free to pm me  Smiley
13.03 @ 98mph
Jordy/DVK
« Reply #6 on: July 28, 2007, 17:37:13 pm »
 Thanks for the replies! Those media blasted ERCO's look very cool!!  Cool
 I'm looking forward to recieve the volksworld feature!!  Cool
 Allthoug it might be a bit outdated, I'm sure it'll contain a lot of info I could use...
 Olaf, are all T1 nosecones the same or do I need a nosecone of particular years?
 I'd be happy to learn more about modifying an old wreck for the strip...  Cool
Jordy/DVK
« Reply #7 on: July 28, 2007, 17:41:47 pm »
 Cool  Cool  How much did you narrow the front axles? When I mount a slammed oval front beam (I wont use the split one with the small towers) I don't think there's much more room left to narrow. Do you use dropped spindles?
Black Sheep
less is more
« Reply #8 on: July 28, 2007, 18:20:23 pm »
I used a 56 beam , and took 3" out of it to allow for the dropped spindles and the fact that I was running on 6" fuch's , these are now going in favour of some 4.5 so i will need another beam to do the business to this should only need about 1"3/4 -> 2" out of it this time . Don't really like to narrow if i can get away with it ( not very old school you see ) but i need the car to sit right with the dropped spindles
13.03 @ 98mph
Martin Greaves
10.88@128.58
« Reply #9 on: July 28, 2007, 18:23:45 pm »
Oh my god the rag top open the wrong way on that car.
Black Sheep
less is more
« Reply #10 on: July 28, 2007, 18:25:10 pm »
Bugger off you  Angry
lol glenn
13.03 @ 98mph
Olaf A./DFL
« Reply #11 on: July 28, 2007, 19:17:28 pm »
you'll need this one and a screw that fits in the hole for the reverse light. i don't know if they were all the same but i think so.
speedwell -could you please also send me that article?
Martin Greaves
10.88@128.58
« Reply #12 on: July 28, 2007, 19:47:31 pm »
I'm sure you will be albe to get one from over here if not vee dub parts sell them new. I think this is the right one may be someone on here will tell us.
http://www.vwparts.net/VW211301205H.html
Black Sheep
less is more
« Reply #13 on: July 28, 2007, 20:18:10 pm »
You still got cable on that old split cos you don't want to be going any place above 50 kph on those . Might be worth looking into running a later pan on it say post 64 to avoid any too early beetle problems ie gear box front mount no bump stops on the rear end and cable brake mods to accept hydraulic etc {been there done that}. I switched the rear end of mine over to a later unit even had to weld in later rear body mounts because I wanted to use shock absorbers , not the leaver shocks they came with .
 You will also need to remove the engine bay side trays and lower fire wall and replace with later items as a 25 hp engine is shorter than the stoker motor you will want to put in these can be obtained from Steve Hooke at   http://www.hookyspanelshop.com/   he also does some great side panel's for access to those 48's I'm sure you will want to fit .
13.03 @ 98mph
« Reply #14 on: July 29, 2007, 03:03:32 am »
[/quote]
report send olaf  Wink
« Reply #15 on: July 29, 2007, 03:44:31 am »
The Nose cones are easy to get its the hocky stick that is hard to find they are no longer made and  very hard to find used..  on my 58 I change the front trans frame mount to 61 and later type Wolfsberg west sells them for about $30.00  then you can bolt your trans right in without changing the nose cone easy to change cut off the old weld on the new it simple to do.
Olaf A./DFL
« Reply #16 on: July 29, 2007, 11:02:56 am »
thanks for the article speedwell!  Wink
and the hockey stick -yes they are hard to find but you can close the original hole on it and drill a new one (you'll need one from a synchrone gearbox)
« Reply #17 on: July 29, 2007, 11:51:31 am »
no problems friends  Wink
cal-look.net
« Reply #18 on: July 30, 2007, 16:49:00 pm »
I was there when Ian made the cuts for the 5 Speed - scarey job on such an original split!
Ian's split has some serious attitude, I even reckon they look like each other Wink
Matt Tobias
« Reply #19 on: July 31, 2007, 06:03:22 am »
I remember seeing that car at Bug Freeze many many years ago(11/12?) and it blew me away then.  I sure had fun living in England.  Bug shows there are so much different than here in the states.
H67bug
« Reply #20 on: August 01, 2007, 08:16:04 am »
what mods are requird to make a Berg 5 strong enough for those times?
Joe_G
« Reply #21 on: August 01, 2007, 12:42:24 pm »
Give Pete at CogBox a bell, i'm sure he put the 5 speed together or just bell Clarky. Smiley
benssp
www.callookvw.com
« Reply #22 on: August 02, 2007, 15:15:09 pm »
I'm pretty sure the mainshaft is the weak link on a Berg 5 Smiley
www.vwheritage.com  My Job
YMCA
71CALRIPPER
« Reply #23 on: August 02, 2007, 15:43:02 pm »
will change soon when the berg 5 speed 091 bus box comes out
« Reply #24 on: August 02, 2007, 19:50:49 pm »
The mainshaft of a Berg 5 is no weaker than that of a 4 gear.
The Berg Bus 5 is based on the earlier 113/002 Bus 'box.
« Last Edit: August 02, 2007, 19:53:52 pm by Bruce » Logged
