November 02, 2026, 16:43:06 pm
| | |-+  P38 BellyTank
Author Topic: P38 BellyTank  (Read 25423 times)
Frenchy Dehoux
« on: March 14, 2014, 19:44:40 pm »
  Anyone ever build a P38 belly tank with a VW engine and transmission. I just bought a Belly tank from a good friend and most of hot rodders install a flat head V8 60 or later V8.
Frenchy
Doctor Detail ( Retired )
« Reply #1 on: March 14, 2014, 19:52:47 pm »
Dick Beith's Pepco Supercharged VW Lakester
andy M.
« Reply #2 on: March 14, 2014, 21:37:27 pm »
is it an original ali one or fibre glass repop?  I always fancied building one of these but tanks are hard to find this side of the pond,
cheers
andy
L.B.C.R.
« Reply #3 on: March 14, 2014, 22:15:27 pm »
SCTA has so many rules now that it is impossible to get one cert'd to run -- there was a guy building one up in co or UT or KS somewhere and had a hard time getting it licensed to even make an exhibition pass -- -- There was a build thread on it somewhere from a few years ago
« Reply #4 on: March 14, 2014, 22:35:07 pm »
http://www.jalopyjournal.com/forum/attachment.php?attachmentid=481841&d=1218870027   LOL
« Reply #5 on: March 14, 2014, 22:46:47 pm »
Found another one. looks like it has motorcycle wheels & tires
Frenchy Dehoux
« Reply #6 on: March 14, 2014, 23:27:04 pm »
  Way cool I will post pictures next week. I will pick it up tomorrow sometime. I think with the VW engine and running gear would be simpler.
Frenchy
Frenchy Dehoux
« Reply #7 on: March 15, 2014, 00:27:06 am »
  Is there some type of blue print somewhere that I can see how the chassis was build to accept the vw engine and trans.
Frenchy
« Reply #8 on: March 15, 2014, 04:53:43 am »
Most the ones I've seen Frenchy. seemed like they just split the tank and then put the engine and trans in there where it would fit/work and then fab'd the chassis to work -- -- the last one I saw needed a midget or a contortionist to drive it --
« Reply #9 on: March 15, 2014, 15:08:12 pm »
frenchy watch this  Wink
https://www.youtube.com/watch?v=Zu6qMH6m8p8
« Reply #10 on: March 15, 2014, 16:01:12 pm »
here's a topic on the jalopy journal   the engine isn't a flat 4 but may be the build is very similar
http://www.jalopyjournal.com/forum/showthread.php?t=314787&showall=1
« Reply #11 on: March 15, 2014, 16:17:59 pm »
http://www.volksrods.com/forum/showthread.php?t=20449
« Reply #12 on: March 15, 2014, 17:45:32 pm »
Really looking forward to this build and the ideas that I know you'll put into it Frenchy -- Something I've always wanted to do -- but at 6'4"  260 lbs kind of figured my bum would even begin to fit in it LOL
Frenchy Dehoux
« Reply #13 on: March 15, 2014, 23:11:10 pm »
    I have the belly tank in the back yard and I did some measurements. First I will have to finish my 1929 Hot Rod than the NSU than the Belly Tank. But it is OK to do multiple projects at once.
Frenchy
PIP
« Reply #14 on: March 16, 2014, 03:26:48 am »
Hank young is building a sweet salt flatter, on his Instagram @hankyougchoppers
#247 ROMETSCH BEESKOW RESTO
http://www.dbkvw.com/photos/rometsch_beeskow_247_rest/
Dbkvw.com
« Reply #15 on: March 16, 2014, 07:32:54 am »
Frenchy
And the Ghia?
Frenchy Dehoux
« Reply #16 on: March 17, 2014, 04:01:38 am »
   Thank You for reminding me Zach.
Frenchy
lawrence
« Reply #17 on: March 18, 2014, 01:57:51 am »
Cool stuff, Frenchy. Did you have any powerplants in mind yet. If it were me I would build a hopped-up 36hp engine with a new, speedwell blower. Or a 2165 with all the go-fast stuff and IDA-style injection. Or a 1914 with a small turbo.
"Happiness is a Hot VW!"
Frenchy Dehoux
« Reply #18 on: March 18, 2014, 06:44:39 am »
     I was looking to build a 2165 or 1900 cc with IDA'S sticking out from the side and doing a mid engine using swing axle transmission reversing the ring gear etc .... and maybe a set of BRM'S as well
Frenchy
RichardinNZ
« Reply #19 on: March 18, 2014, 10:25:57 am »
May be worth making contact with Burly and the 36hp land speed guys on the vintage speed forum on The Samba.  They may have more information for you.
Richard
'58 Bug; NZ assembled
Dual Carb 36hp
Frenchy Dehoux
« Reply #20 on: April 21, 2014, 05:36:40 am »
   I was hoping to find more pictures from the inside of the belly tank so I have an idea on the placement of the engine and transmission.
 Frenchy
Frenchy Dehoux
« Reply #21 on: April 21, 2014, 22:53:15 pm »
   Here are a few pictures of the Belly Pan before and as of today what has been done to it.
Frenchy
Frenchy Dehoux
« Reply #22 on: April 21, 2014, 22:57:24 pm »
   A few more this was as of 4/20/14
Frenchy
« Reply #23 on: April 23, 2014, 00:24:46 am »
 Frenchy
These were all I found. I'll keep looking,
Dave Rosique
nobodyouno
« Reply #24 on: April 23, 2014, 02:23:48 am »
Very cool Frenchy!
Frenchy Dehoux
« Reply #25 on: April 23, 2014, 05:08:05 am »
   Thanks Rick no problem just wanted to have an idea on the inside how the frame was made to support the engine and transmission. I am planning to use a squirrel cage style fan and no fan shroud also using a magneto and oil sump and many other ideas etc .... I am still working on my 1931 track t roadster / NSU I just needed another project .
   Frenchy
« Reply #26 on: April 23, 2014, 05:37:43 am »
You can never have too many projects.
I can search while I wait for software to install which is how I spend most of my day Wink
« Reply #27 on: April 23, 2014, 17:04:16 pm »
possible suggestions -- one is put the engine to the rear and leave it into the air stream and use air scoops to cool rather than a fan -- HP gained there -- and weight is your friend when your on the salt too!!!
Here is an old belly I found for sale a few years ago -- figured I'd post so you could see some old school thinking -- i want to point out the rear vertical stabilizer too -- sorry, could only find this pic -- had more but they are gone -- didn't want to get to close and leave any foot prints in the dust because I thought was part of the coolness of this find LOL
« Last Edit: April 23, 2014, 17:16:58 pm by Fiatdude » Logged
