July 25, 2026, 12:01:19 pm
| | |-+  Show Us Your Cal-Look Type 3 Engines
Author Topic: Show Us Your Cal-Look Type 3 Engines  (Read 8562 times)
« on: March 20, 2014, 04:21:10 am »
Like it says, lets see some Cal-Look Type 3 engines!!  Grin
« Reply #1 on: March 20, 2014, 05:10:26 am »
That's a tough one! I think a properly hot rodded type one is a thing of beauty, right up there with a flathead V8. A type three, especially if it all remains under the deck, is a form follows function thing. My old T3 1776's looks didn't reflect any of the money I had spent on it Roll Eyes
« Reply #2 on: March 20, 2014, 08:00:07 am »
both Felix and Georg from DFL there engines come to mind. if you are talking street engines
here is a link to Felix engine/trans and in the end car rebuild: http://cal-look.no/lounge/index.php/topic,12030.msg262841.html#msg262841
Georg was/is building a 2276 all under the lid and his 1776 looked the part.
one other person that comes to mind is Anthony from ISP west, he had a 2276 type3 in his square back, i have seen pictures/video of it moons ago, maybe you can hang him down and post them. he's on your side of the pond.
PIMPPRIDE
« Reply #3 on: March 20, 2014, 18:54:12 pm »
HA ! I just happened to check in The Lounge today...
yes, here is a photo of my 2276cc w/48-dells stuffed under the engine lid
an an oldie... an a little old video - http://www.vwispwest.com/ebay/type3.WMV
Anthony / ISP WEST
volksnut
« Reply #4 on: March 20, 2014, 21:33:16 pm »
Okay...it has DCNF's, cam, and headers and some Fiat parts thrown in...that's cal-look right?
« Reply #5 on: March 21, 2014, 13:49:33 pm »
 Shocked Shocked Shocked
Details, where to start?
My favourite is the transverse leaf with double A-arms, very cool!  Cool
« Reply #6 on: March 22, 2014, 19:08:01 pm »
Anthony, you guy's have a step stud or 8mm to 6mm insert, to mount the oil cooler? Building a new Type III motor using a new Aleania case, it has an 8mm stud. No one seems to have anything I need, There step studs are to short.
Ted
Anthony / ISP WEST
volksnut
« Reply #7 on: March 23, 2014, 01:00:55 am »
So I don't clog up the works, you can follow along here
http://bucketbuilder.bb3host.com/viewtopic.php?f=34&t=515
« Reply #8 on: March 23, 2014, 20:32:21 pm »
That was the video Anthony! still love it very much. could you share some specs of the engine. if memory serves me right it had a W120 cam,… but i can't remember more about it.
PIMPPRIDE
« Reply #9 on: March 26, 2014, 00:40:27 am »
yes, it was & is highly influenced by Mark Herbert's street motor, that seen street time in almost everything he owned  SSB, Quaife Test Bug and his Bay Bus even...  Cheesy
AS41 CASE  fully machined, full flow ect all the typical machine work done to a mag case
the complete engine assembly was balanced dynamically from pressure plate to the type 3 two fans... a big help for harmonics
the fan is fully welded, on veins and center and gets buzzed to 7500 rpm frequently
82mm Demello Crank, welded stroker, Porsche journal ( started as a stock 1500 fish )
stock flywheel, slightly lightened to 14½ lbs, 8 dowel ect
94 JE pistons w/old Mahle barrels ( cut, chamfer removed ect )
5.325 Carrillo rods, Porsche journal
040 heads by Jeff Denham - 44x37.5 fully welded, big ol' ports, moved spark plug locations, stainless valves, dual springs, all the goodies & tricks you can do to a stock type head...
30mm Schadek oil pump
120 Engle cam
1.1 ratio on the rockers, stock vw, solid shafts ect...
48mm dellortors tri-jets on CB manifolds that were also welded up and fully port matched...
I've had 3 to 4 different exhaust systems over the years, currently I have upgraded to a CSP with full heater boxes, it's dyno'd the same numbers with a old Berg 1-5/8" 4 tune header as it did with a A-1 sidewinder ( one of the first batch of type 3 sidewinders )
as for the trans, today's standards you could call it a pro street plus plus, built by Mike Herbert at his old shop MPH Transmissions, it received the best of the best, everything hand picked...  its a 12V late case, klinkenberg 412 R/P - 3.78/2.06/1.21/0.89 Berg super beetle main shaft, dual snap ring super diff, welded 3rd/4th steel shift forks, all german bearings, old school cast iron side cover, Berg short axles, only the best of the best, homage to Clyde Berg with a " Big Nuts " on the trans ect...
near future plan is upgrade to IRS as I recently scored a IRS Quaife diff and install that nice CSP exhaust w/heat... once I figure out a new location for the full flow oil filter, the CSP exhaust wants my left bumper bracket mounting point... currently my OC47 filter is hanging on to this spot
and I almost forgot a restored / reconditioned Bosch 010 done up by Glenn for me... should be a great fit with the short rods !
Anthony / ISP WEST
« Last Edit: March 26, 2014, 00:44:56 am by PIMPPRIDE » Logged
Taylor
« Reply #10 on: March 26, 2014, 09:24:21 am »
For later Ted,  McFadden Dale sells step studs.
« Reply #11 on: March 31, 2014, 02:32:38 am »
Hi Taylor, had called them, did not have the long ones I needed, BUT, Dave Rhoades got ahold of me, he had them, worked out good thanks to Dave.
Ted
