October 13, 2026, 21:29:17 pm
| | |-+  Valve to piston clearance- lightweight spring?
Author Topic: Valve to piston clearance- lightweight spring?  (Read 4910 times)
Jonny Grigg
« on: June 24, 2014, 20:22:02 pm »
Hi,
I need to check my valve to piston clearance. Does anyone know where I'd get a lightweight spring to just hold the valve on the seat? I'd prefer to do this rather that use an outer Chevy spring if possible.
May sound like a stupid question, but what spring could I use? Is there something out there specific for this or is it another "make do"? I might be reaching in the loft for my old R/C car stuff from when I was a kid and use a cut down shocker spring unless there is anything better out there......
Thanks for the help.
Jonny
No Compromise. O/FF111
« Reply #1 on: June 24, 2014, 20:41:19 pm »
Hi,
Jonny
Spring loaded pushrod tube spring Wink
Jonny Grigg
« Reply #2 on: June 24, 2014, 20:49:59 pm »
Great idea! I have one of those Wink
Jamie mentioned the rear main to you? Hopefully Wayne will have that turned down in the morning and we're back on it......
Jonny Grigg
« Reply #3 on: June 24, 2014, 20:51:26 pm »
By turned down I meant shamfered... It has been a long day.
« Reply #4 on: June 24, 2014, 20:59:43 pm »
I thought you did Grin
Yep, heard about that, happens sometimes, have to check everything as anything could be not quite right Shocked
