September 26, 2026, 12:54:21 pm
CSP/JPM Wasp header and Muffler ( Images Wanted)
Topic: CSP/JPM Wasp header and Muffler ( Images Wanted) (Read 169596 times)
Re: CSP/JPM Wasp header and Muffler ( Images Wanted)
Reply #30 on:
December 14, 2014, 00:41:22 am »
Quote from: old dub lover on December 14, 2014, 00:24:41 am
Would I be wrong in assuming that the advantage of this header is that it has equal length primary's ?
Thanks in advance
Yes
Many headers are equal length. This is also a step header (tubing gets progressively larger).
old dub lover
Reply #31 on:
December 14, 2014, 01:37:34 am »
From what size to what size, if that makes sense
thanks
neil68
Reply #32 on:
December 14, 2014, 01:54:03 am »
The Stage 2 starts at 1.625" (41 mm) OD at the exhaust port, and then increases to 1.875" (48 mm) and finally to 2" (51 mm)...checked again and corrected the numbers. My digital calliper quit working, so I measured with the ruler calliper, and my readings are approximate.
Not sure what the steps are for the Stage 1 & 3.
Last Edit: December 14, 2014, 20:54:20 pm by neil68
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
Dynojet Test:
pupjoint
Reply #33 on:
December 24, 2014, 05:00:51 am »
ok, CSP has revised the description. sled tins/ heater channel tins cannot be used.
http://www.csp-shop.com/cgi-bin/cshop2/front/shop_main.cgi?func=detail&artnr=26006a&wkid=91643699368
let me try and fabricate something.
neil68
Reply #34 on:
February 09, 2015, 04:31:48 am »
I notched my Berg engine support (traction bar) to clear the #3 pipe, but the notch ended up being larger than I anticipated. I had a piece of simliar bar stock handy and had it welded underneath the notch to add strength. Hopefully, this will do the job.
The Berg oil hoses are contacting the Wasp pipes, so I'll have to either move the oil filter mount, or add longer oil hoses.
Neil
Dynojet Test:
Reply #35 on:
February 09, 2015, 07:10:06 am »
change the oil filter mounting bracket to a different hand. they do lhd, rhd and top entry.
Reply #36 on:
February 09, 2015, 07:17:33 am »
Quote from: Lids on February 09, 2015, 07:10:06 am
Good call. Get the one that will point the inlet/outlet towards the front of the car. Cheap solution.
neil68
Reply #37 on:
February 09, 2015, 21:18:41 pm »
Good suggestion...the "forward-facing port" filter mount should provide enough slack for the hoses to clear the exhaust pipes
Neil
Dynojet Test:
neil68
Reply #38 on:
February 15, 2015, 04:37:32 am »
Well, switching to the filter mount with "left ports" did the trick. The Berg oil lines now clear the exhaust pipes nicely:
Last Edit: February 15, 2015, 04:40:44 am by neil68
Neil
Dynojet Test:
neil68
Reply #39 on:
February 17, 2015, 01:19:39 am »
To keep this all in one thread, here are a couple of pictures showing how I had to slightly trim the "sled tin" to fit the Wasp J-pipes. It was certainly less material than I've had to trim for other headers in years gone by, approximately 15 mm.
Another option would be to bend the outer lip of the sleds, and then add industrial tin to close everything in. I may still install some industrial tin in the future, or make by own. For now, the sled tin should do it's job of routing warm air out to the rear of the engine.
Here is the right side sled tin:
Left side:
Neil
Dynojet Test:
pupjoint
Reply #40 on:
April 25, 2015, 18:02:59 pm »
bump. anymore Wasp users?
Neil, any feedback from running the Wasp so far? i barely drive mine and will be opening the engine soon for some upgrades.
neil68
Reply #41 on:
April 25, 2015, 19:39:32 pm »
I haven't driven much, as the weather has been up and down...still snowing and raining. First race of the season was cancelled yesterday:
Last Edit: April 25, 2015, 20:24:10 pm by neil68
Neil
Dynojet Test:
Greg Ward
Reply #42 on:
April 27, 2015, 10:33:09 am »
Here's mine,
Still waiting on a few items for the carbs so haven't driven it yet.
Greg Ward
Reply #43 on:
April 27, 2015, 10:38:07 am »
And of the muffler setup.
Last Edit: April 27, 2015, 10:44:35 am by Greg Ward
neil68
Reply #44 on:
April 28, 2015, 05:33:04 am »
Quote from: Greg Ward on April 27, 2015, 10:38:07 am
Is that a custom flange sleeve in image 5? Does it just slide over the collector and use a clamp to secure it? I like it!
Last Edit: April 28, 2015, 05:34:59 am by neil68
Neil
Dynojet Test:
Greg Ward
Reply #45 on:
April 28, 2015, 10:23:11 am »
Hi Neil,
Yes, it is, I never wanted to interfere with the original stainless header.
And, I'm not a welder but my engine builder is, ( I cut up all the bits to the right angles but he expertly brazed it all together for me ) except for stainless, so, I thought, if I can make a transition flange piece in mild steel, then I don't destroy what it came with, but can add anything I like (stinger) in the future... just through the flange section.
So that's what we did, and if I welded a flange onto the end of the exhaust as it sits, then that's all I can have, I may want to change this 10 times (you know how it goes) so it's perfect I think, the only thing I may do as per other Suzuki hayabusa and other exhausts is a pin so if the clamp fails it still won't fall off.
Not convinced it will ever fall off the way it is until I try it, and there is another strap to the bumper bracket I made to hold the body of the yoshimura muffler (which I've repacked in a 3 stage arrangement) and made sure it is 2 1/2" all the way through. If it doesn't look straight through, it is.
I then of course thought, well I don't want to paint this, or keep painting it, so it got plated...
Soon to see how it all works anyway... just need to tune in the new IDA's...
Greg
mac68
Reply #46 on:
April 28, 2015, 19:19:12 pm »
hi greg. That is a small power pulley! are you running e85?
Greg Ward
Reply #47 on:
May 12, 2015, 07:19:23 am »
No E85, just BP 98 Octane
volkskris
Reply #48 on:
July 16, 2015, 13:10:23 pm »
Well CSP posted this today on their FB page:
http://www.csp-shop.com/products/Products/Exhaust_System%2CComplete_Exhaust_System%2CBug/26005a/det/
Reubs
Reply #49 on:
July 17, 2015, 09:32:28 am »
Anyone know what the cylinder is on the pipe before the muffler? [ Attachment: You are not allowed to view attachments ]
Erlend / bug66
Global Moderator
SCC Event
Reply #50 on:
July 17, 2015, 10:34:36 am »
I would guess a resonator?
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
vwhelmot
Reply #51 on:
July 17, 2015, 10:51:44 am »
Extra weight. Needs cutting off
Sloppy wrench
Reply #52 on:
July 19, 2015, 11:52:00 am »
Can CSP come with numbers as far as decibel loss with that little device?
or was it intended to help with drone/vibrations at a given RPM range..
SuperBeetle73
Reply #53 on:
July 22, 2015, 17:28:17 pm »
Apparently this is the street legal design to give max hp, I cannot see how a pipe being bent 180 degrees on its self will out perform a turbo style muffler like posted above.
Wondering if it will be better to change an existing muffler to fit as Greg has done above, its cheaper and may produce more power.
Street Legal 1303S - 11.5 @ 115 on treads
JS
Reply #54 on:
July 22, 2015, 18:47:09 pm »
Quote from: SuperBeetle73 on July 22, 2015, 17:28:17 pm
I believe thatīs because tuned length is more important than a bend.
Signature.
SuperBeetle73
Reply #55 on:
July 22, 2015, 19:51:21 pm »
Quote from: JS on July 22, 2015, 18:47:09 pm
Yes understand. But as we know the most efficient exhaust is the stinger - straight through exit. So is a Turbo style muffler going to be that different in performance than the JSP Muffler? A question rather than a statement, been waiting a while for these images and trying to justify the extra expense of buying the muffler. Be interested to see how much the muffler takes from the stinger in HP.
JS
Reply #56 on:
July 22, 2015, 21:11:24 pm »
Quote from: SuperBeetle73 on July 22, 2015, 19:51:21 pm
From my own experience Iīm not sure if thatīs knowledge or myth.
On the Wasp prototype stage I tested the muffler vs. the stinger at the track.
Of about 10-15 runs we ended up with 3 stinger runs and 3 muffler runs where the top speed was identical down to 1/100th of a mile.
Same day, car, driver, weather, track conditions, etc. This was at DDD #11 in 2013.
The difference to the production muffler from mine is that we used an off the shelf muffler for the prototype, but the production one is made for the Wasp from Scratch.
I have not heard the noise level of the production, but the prototype was extremely loud. If all goes well I will do some back to back testing on the production model at SCC this year.
To give an idea how important tuned length is, we tested two Wasp stinger versions on the dyno. One calculated from 3rd order pulse and one 2nd order. Same in and outlet diameter.
We lost 7hp with the shorter 3rd order stinger. That obviously had to be wrong, so we changed back and forth two or three times. 7hp difference every time.
Signature.
Reply #57 on:
July 23, 2015, 01:14:47 am »
Quote from: JS on July 22, 2015, 21:11:24 pm
7HP.
About 3%.
That sounds about right.
Erlend / bug66
Global Moderator
SCC Event
Reply #58 on:
July 23, 2015, 08:13:02 am »
Johnny: Calculations for the exhaust, is that after the collector?
Could you post it, or is it a program that does it?
The '67:
The '59:
Not yet..
Reply #59 on:
July 23, 2015, 08:27:34 am »
Quote from: Erlend / bug66 on July 23, 2015, 08:13:02 am
........ or is it a program that does it?
One option........
http://www.maxracesoftware.com/PIPE395.htm
