September 21, 2026, 19:50:01 pm
Off Topic
6v - 12v conversion on a 1965 Beetle - Hints, Tips, Parts needed? Who's done it?
Topic: 6v - 12v conversion on a 1965 Beetle - Hints, Tips, Parts needed? Who's done it? (Read 19359 times)
December 15, 2014, 14:50:47 pm »
Well as the title says guys......
I need to drop a later 12v 1600cc "single port" Bus engine into my 65 beetle so I can get it home to the UK.....
I know
most
of the things I need to do but there are a few small details I am not sure of like the STARTER MOTOR & FLYWHEELS.......
Also is there any
"Clearancing"
needed doing to the original 65 gearbox???
I know this is not really a "Cal Look" issue but I thought it best to ask more experienced people rather than the other Interweb "Experts"
Re: 6v - 12v conversion on a 1965 Beetle - Hints, Tips, Parts needed? Who's done it?
December 15, 2014, 15:36:48 pm »
Fabian has been telling me that there is a 6volt starter that "Works" with a 12v flywheel
Anyone know which starter this is??? Anyone know the part no:
Erlend / bug66
Global Moderator
SCC Event
December 15, 2014, 18:48:46 pm »
67 1500 6volt I would guess
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
December 15, 2014, 20:36:02 pm »
Quote from: Erlend / bug66 on December 15, 2014, 18:48:46 pm
Yep thats what I was thinking.....
Anyone got one??
December 15, 2014, 20:43:12 pm »
wouldn't it be easier just to swap the dynamo?
December 15, 2014, 21:40:30 pm »
No cos its not just the dynamo.....
There is the fan to consider and if I went that route then I would have to swap the flywheel on the 1600sp and I am not to keen on doing that..... its kinda "Easyier" to go this 12v route
Plus there is the fact that I need a new battery and 6volts Batteries are nearly 3 times the price of 12volt ones in norway!
henk
December 15, 2014, 22:01:09 pm »
Not sure it is only the 1500 starter that fit on a 12 volt flywheel.
I changed my 6volt '67 to 12volt as well,and it is a 1300 car.
I just left the 6volt starter in it and it fits on the 12v flywheel.
So it is on a 12volt 2110 now for two years or so all ready.
Henk!!!
December 15, 2014, 22:01:55 pm »
OK Here's what I remember.
2 Options;
1. Use the 6 volt flywheel and starter. You'll get the smaller 180mm clutch. 6volt starter will work if you put on a 12v solenoid.
2. Use a 12 volt flywheel. You'll need to clearance the trans case for the larger flywheel. You can use 2 different starters. the SR15x which is the standard 12v starter. To use it, you'll need to swap out the starter bushing for a special adapter bushing that has the O.D. of the 6 volt one and the I.D. of the 12 volt one. Alternative is to use the SR17x starter. More expensive but doesn't require a bushing in the case.
Dave Rosique
nobodyouno
December 15, 2014, 22:16:16 pm »
^^^ What Rick said ^^^
One other thing, If you wanted to stay with a 6v flywheel & starter but prefer a 200mm clutch you would need a flywheel from a 66 or earlier type III.
December 15, 2014, 22:21:24 pm »
Thanks guys......
I kinda want to go with the larger 12v flywheel thats already on the 1600sp engine, I am gonna need to clearance the Gearbox anyhow when I fit the SPG engine so I might as well do it now..... I will also be able to use this starter on that engine (when its done!)
So I guess I am looking for a 1967 13/1500 Starter motor
Again thanks for the hints & tips guys
December 15, 2014, 22:26:01 pm »
Just wanna check.....
The SR15x is the standard "Late model" 12v starter
The SR17x is the "67" model 6v item
December 15, 2014, 22:49:49 pm »
Quote from: henk on December 15, 2014, 22:01:09 pm
Henk!!!
In theory, a normal 6v starter wont mesh with a 12v flywheel. 6v flywheels have 109 teeth with 180mm clutch and 12v are 132 teeth with a 200mm clutch. There was a flywheel that had a 180mm clutch with 132 teeth and that's probably what you had henk. It may have been '67 euro 1300 only as we don't have such a set up in the US.
December 15, 2014, 22:51:41 pm »
Quote from: Lee.C on December 15, 2014, 22:26:01 pm
The SR15x is the Standard late model starter.
The SR17x is a 914 starter or T1/T3 Autostick starter. 12 volt but doesn't need a bushing. It's self supporting. Also if I remember it's a little stronger than the 15. I always used a 17 in my'67 for that reason.
Last Edit: December 15, 2014, 22:56:07 pm by Rick Meredith
December 15, 2014, 23:08:12 pm »
Hmmmm ok so any ideas where I could get one of these SR17x 914/T1/T3 Autostick starters
December 15, 2014, 23:14:05 pm »
You may be able to find them closer or cheaper but Summit Racing has it for $90USD and they ship international.
http://www.summitracing.com/parts/bch-sr17x?seid=srese1&gclid=CjwKEAiAqrqkBRCep-rKnt_r_lkSJAArVUBcZ8ohKbp7RBsRMFC32lad9bBY2lFfaHg2bNFCJXTMVxoC-qPw_wcB
December 15, 2014, 23:41:28 pm »
Yeah thanks dude, I have just been checking and you can get these starter in the UK but they are around £150.00 (Thats over $250!!!)
I think I might go for this "Semi-Auto" style starter...... Seems like a Simple way to do it and I can get replacments if needed
volkskris
December 15, 2014, 23:47:04 pm »
There is also a Skoda starter that works.
http://cal-look.no/lounge/index.php/topic,5293.msg229177.html#msg229177
http://cal-look.no/lounge/index.php/topic,6655.msg187097.html#msg187097
Maybe that one is easier to find?
December 16, 2014, 00:06:22 am »
So.........
With THESE starters all I need to do is "Clearance the bellhousing"
December 16, 2014, 01:14:22 am »
Yes... that's a result of running the 200mm/132 tooth flywheel. I think the Skoda starter is self supporting as well so no bushing is needed.
December 16, 2014, 01:30:00 am »
Cool I just wanna be sure.....
Thanks for all the help everyone
alex d
December 16, 2014, 13:20:48 pm »
I would just swap everything to 12 volts, change the bushing in the trans and then you can use the cheap 12v starters
December 16, 2014, 13:59:03 pm »
Yeah its probably the easy option......
I just wanted to get all the info I could then I can Mix & match ideas/parts
I am probably gonna use the "Semi-Auto" self surporting 12v starters......
