October 13, 2026, 23:41:27 pm
A winter warmer, Cabrio on the dyno..........
Topic: A winter warmer, Cabrio on the dyno.......... (Read 22670 times)
Jo Clifford
February 13, 2015, 17:00:21 pm »
Video is a couple of years old now, but we thought some of you might enjoy a little winter warmer, with some Methanol flames, also motivation to get all those cars ready for the race season, which for us will start at Easter.
This year we hope to be running it at this horsepower level, plus some more as we haven't used this much yet
Enjoy!!!
https://www.youtube.com/watch?v=eynl5azFFz4
https://linktr.ee/Redheadautoupholstery?utm_source=linktree_profile_share
http://www.rjvolksperformance.com/
Living the dream, not just talking about it ;o)
"Don't talk, just bring it" - Hector Urias
Re: A winter warmer, Cabrio on the dyno..........
February 13, 2015, 20:19:21 pm »
What hp did it make?
Lee
Maplesyrup
February 13, 2015, 20:26:06 pm »
Can't wait to see it run this season
Jo Clifford
February 13, 2015, 20:39:42 pm »
Quote from: leec on February 13, 2015, 20:19:21 pm
Lee
Just over 890 at the wheels, at 2 bar boost.
Jo
February 13, 2015, 20:53:09 pm »
Thanks Jo,
That's great numbers
February 14, 2015, 02:59:03 am »
What's 2 bar?
About 29psi?
February 14, 2015, 04:43:58 am »
Quote from: Rick Meredith on February 14, 2015, 02:59:03 am
What's 2 bar?
About 29psi?
29.4
robkong
February 14, 2015, 09:13:53 am »
Nice!
tikimadness
February 14, 2015, 09:14:34 am »
Imagine what it will do with 35-40 pounds of boost
Michael
GASSER GARAGE a few friends creating history.
NIDGAFWYT
dannyboy
February 14, 2015, 09:15:25 am »
its about time he put his foot down and did a full pass
8.77@156.8mph
O/FF 60
February 14, 2015, 09:52:02 am »
Quote from: tikimadness on February 14, 2015, 09:14:34 am
Michael
To calculate you need to find the base engine:
890 @ 2 bar = 295 without boost or NA if you like. 295 x 1 bar = 590 x 1 more bar = 885hp. If you then add one more bar of boost you have 1180 WHP at 3 bar or 40 psi. Nice!
It is not 100% accurate since you will have some pressue loss, higher intake temperature at higher boost etc. But it is usually not that far away from the truth.
So it is basically true, a good NA engine will make a super turbo engine. And it also shows you why a V8 is making almost 1000hp as soon as you unpack the turbo from the box. Very overbuilt, very low output and they just scream TURBO!.
Best rgs
BB
February 14, 2015, 10:08:12 am »
The best 1/4 mile calculator I have found says the 8.02 equates to 747whp and the 169mph equates to 753whp so both seem close enough to each other to be correct, that's at the current 1950lbs, at the 890whp level it guesstimates
7.57@178.63mph
, seems a good number to aim for
, realistically you need a higher hp figure as you cant leave the line with all the hp, so I bring it in progressively in each gear which affects the calculation somewhat
At the level Kalle mentioned I think I would need a completely revised car both chassis,gearbox and suspension wise to have any chance of getting it all the way down the track[ calc says
6.89@196.24mph
which is pure fantasy
Its fun to dream though
Calculator I use if anyone wants to try it is
http://www.wallaceracing.com/et-hp-mph.php
February 14, 2015, 10:26:13 am »
Quote from: richie on February 14, 2015, 10:08:12 am
7.57@178.63mph
6.89@196.24mph
Thanks Richie,
Only you and your computer knows the boost levels (and also the actual HP) you used when you managed your 8.02 run. Your speed over the line can usually give you a good HP estimate.
So basically you are saying that you are
cruising
along on "low boost" and have more in stock if needed
Thats cool! And thats the beauty of having a really good base engine. Someone would also claim that it is a lot easier getting the power down on a dyno compared to a strip. So we could ask ourselves if we should build a big, strong base engine and keep the boost at a decent level or build a less impressive base engine and boost the hell out of it.
Best rgs
BB
February 14, 2015, 10:34:54 am »
Just forgot;
I would also question most ET calculators when it comes to our cars and our ET. Very very few of our cars are able to reach the calculated ET. Then you have the choice to either reduce your HP accordingly until you get the calculated numbers alligned or question the calculation or the dyno results.
-BB-
February 14, 2015, 11:40:45 am »
Quote from: BeetleBug on February 14, 2015, 10:26:13 am
Thanks Richie,
100% agree, mph is the best tuning tool we have
cruising
Best rgs
BB
I highlighted what I think is the best route in red
Budget though is really most peoples limitation to what they build
spanners
February 15, 2015, 18:28:47 pm »
Gentlemen, One word is the key, drag, There are about 4 types ganging up to stop us going 200 mph with a Beetle, 200mph is possible with only 450/500 hp in a purpose built vehicle, at over 100 mph, Roughly half of the total power needed to go 150 is used up just overcoming the drag factor, the problem is, it won't go away and builds with the air speed, in reality, we have lift drag building, skin drag building, rolling risistance building, tyres are a big part of this and have aero drag also, adding to un controlled vortices and eddy forms, ie more drag, F1 is using tiny vanes at the front of the side pod to put the front wheel wakes were they want them, and turn them into a vortex form they can use, I'm not sure where they are placing them, I guess adding a curtain effect along the floor edge, small guide vanes can often be used if regs or silhouette rules ban obvious aero add ons, first time out last year I ran some small fairings ty wrapped to the front torsion arms and practice saw a 8*C drop in oil temperature, the cooler is in the spare wheel well, so what happened?. Well more air got pulled through the cooler for sure, I taped the duct up to compensate, now if I can get the rad to do the same? Well I've gone to much bigger front wing gills and altered the coolant system, looking to reduce coolant temp, thereby smaller rad duct size, -ve drag, well less anyway, small gains make the difference..regards, spanner.
Best regards, spanners.
February 15, 2015, 22:22:22 pm »
Quote from: Jo Clifford on February 13, 2015, 20:39:42 pm
Lee
Jo
Whow, that are great numbers.But I have a question:
Till how much boost can you go on this engine (as it has now 2 bar)
jick
February 15, 2015, 22:58:58 pm »
Damn those are some impressive numbers!
www.custommotorbodies.co.uk
Trond Dahl
February 16, 2015, 09:19:19 am »
What do you think sounds more fun!?? :-)
Race car 9.49/236kmt@SCC 2017
February 16, 2015, 09:33:45 am »
Quote from: Trond Dahl on February 16, 2015, 09:19:19 am
Me? I would build something that does not need the service or the parts from one of the "high end" US suppliers.
-BB-
February 16, 2015, 09:57:45 am »
Quote from: vwcab on February 15, 2015, 22:22:22 pm
Lee
Jo
I figure 3-3.5, but wont know till I try it
Basti
February 16, 2015, 10:44:57 am »
are we talking about 3 bar absolut or 3 bar plus atmospheric?
Cheers,
Basti
- black 62 cal look beetle
- Pro Mod Race car
February 16, 2015, 10:47:34 am »
Quote from: Basti on February 16, 2015, 10:44:57 am
Cheers,
Basti
Since he is already at 3 bar absolute I think we are talking 3 bar (40 psi) + atmo.
-BB-
February 16, 2015, 11:15:51 am »
Yes 3 bar over atmo
jamiep_jamiep
February 16, 2015, 12:33:33 pm »
Thats amazing Richie, thanks for sharing.
Happiness is a Hot VW.
My 1960 Bug
SAS RENN-WAGENS
CAL LOOK DRAG DAY
February 16, 2015, 17:56:00 pm »
Quote from: richie on February 16, 2015, 11:15:51 am
Yes 3 bar over atmo
Hey Richie, what is your guess how much hp it will make at 3bar?
And do you also know how much hp you lose in gears etc....I mean you have now
890hp at the wheels, but how much is that on the engine?
Just curious.........
February 16, 2015, 18:48:32 pm »
Quote from: vwcab on February 16, 2015, 17:56:00 pm
Yes 3 bar over atmo
A VW trans typically uses 15-17% in my estimation so about 1030flywheel hp using 16% average loss =890whp, at 3bar I would guess just short of 1150whp is realistic, above that it would live but be on a very short fuse
February 16, 2015, 20:26:04 pm »
Impressive numbers!!!!!
Thanks for the info and much fun with it.
Dead Dog
March 03, 2015, 21:21:19 pm »
Well this has just had me watching a load of your vids
Can't wait to see what FOP brings
VWDRC PRO 102 - 11.85 @ 107mph
T1 1914 omex 600 t3/4 turbo
WRP Paint & Restoration - VWDRC Sponsor 2012 & 2013
