October 13, 2026, 08:15:38 am
| | |-+  Puncture in slick
Author Topic: Puncture in slick  (Read 8126 times)
big d chop
O/FF 16
« on: May 10, 2015, 20:52:02 pm »
Hi,
This might be a stupid question but I've just found a piece of mig wire in one of my slicks . My question is can you get it repaired or use inner tubes or are they scrap now
OFF 16
WPS
« Reply #1 on: May 10, 2015, 21:08:30 pm »
Hi mate.....we've repaired them before just get it balanced when it's plugged.....unless it's getting old anyway in which case scrap it :-)
See you at the weekend hopefully!!
   WolfsburgPerformance.co.uk
      Instagram:  wpsengines
             07880-311850.
stretch
« Reply #2 on: May 11, 2015, 09:42:53 am »
I run tubes in my M&H dots.  I also used to run tubes when I ran 8.5" wide Mickey Thompson slicks.
WPS
« Reply #3 on: May 11, 2015, 10:08:36 am »
Tubes are ok but if you run low psi they can spin round inside the tyre.....
             07880-311850.
big d chop
O/FF 16
« Reply #4 on: May 11, 2015, 11:52:10 am »
I think I will try and get it repaired , I blew it up to 11psi yesterday dinner time and i checked earlier and it is softer  but not flat , its such a small hole
OFF 16
WPS
« Reply #5 on: May 11, 2015, 15:43:58 pm »
Some 'Crow's Snot' and a patch on the inside should fix it then!!
See ya at the weekend.....
             07880-311850.
Phil West
« Reply #6 on: May 11, 2015, 18:42:07 pm »
Hi,
Hi Darren I had one repaired in my old slick.  From memory they used a small rubbery plug type of thing and it worked just fine,
Phil
dragvw2180
« Reply #7 on: July 18, 2015, 16:38:53 pm »
 JMHO      I run tubes in my slicks , so your answer is yes you can. I install screws in the lips of the rim so the tire cannot spin on the rim. I have always run tubes because they keep my air pressure more consistant and do not go flat between races LOL  . On my new "Street " car I added screws and to the rear tires because I spun them on the rims also, 2387 Turbo . I would never plug or patch a slick because of the heat and flexibility normal with them .  Mike McCarthy
NoBars
« Reply #8 on: July 18, 2015, 18:29:21 pm »
I wouldn't have a slick plugged, I would have it patched.
« Reply #9 on: July 18, 2015, 19:25:12 pm »
X2 -- but putting screws into your rims is always a good idea
