September 22, 2026, 20:54:06 pm
My SPG has to go...... new low price! £1400.00 or trades....
Topic: My SPG has to go...... new low price! £1400.00 or trades.... (Read 4275 times)
June 09, 2015, 21:49:50 pm »
I am asking £1400 for the crank/rods/flywheel/clutch etc...
CASE SOLD!
A very sad day!
http://cal-look.no/lounge/index.php/topic,22058.0.html
I might also sell the heads for another £500...
And if someone wants the "Lot" then I will do a good deal....
Last Edit: November 25, 2015, 16:38:41 pm by Lee.C
Re: My SPG has to go......
June 18, 2015, 20:12:41 pm »
I really don't want to sell this but needs must.... This is a original 70's SPG roller bearing crank/rods that I have had COMPLETELY striped/modified/rebuilt/balanced/POLISHED! etc etc.... It has be professionally pressed apart, fitted with modified rollers, then pressed back together/indexed...... Then it has been "cross-drilled" across the 5 sections, threaded pins added then the pins welded into place! This SPG will NEVER twist!!!! It has also had an original German flywheel fitted/balanced and WEDGEMATED! The whole package was then balanced WITH the clutch!!! This little package is currently at Ian Clarke (WPS) workshop as I was getting him to build it up but I just can't afford.... There is over £2000 worth of "work" in this crank/rods/flywheels!!! I am asking £1600.00 ono....Collected or you can arrange a courier (it is HEAVY!)
Last Edit: August 20, 2015, 00:26:17 am by Lee.C
Re: My SPG has to go...... new low price! £1600.00!!!
August 20, 2015, 00:23:15 am »
New low price!!!
November 25, 2015, 16:37:42 pm »
