November 03, 2026, 10:45:32 am
| | |-+  Berg 5 in an early car?
Author Topic: Berg 5 in an early car?  (Read 5405 times)
Trent B
« on: September 02, 2015, 23:20:28 pm »
Looking for suggestions on mounting a Berg 5 into a '59 Ghia. As we know, when mounting a later transaxle into an early (split case) car, we use the bus nose cone to maintain the gear lever (hockey stick) location. So, with the Berg 5 nose cone modeled after the later type 1 piece, how do I fit it in the car? Enlarge the hole or tilt the trans down or? I'm planning to mount it with a weld in intermediate mount and a solid rear mount.....
Huh?
« Reply #1 on: September 02, 2015, 23:53:56 pm »
Change the front mount to the later type.
Rocket-Racing
« Reply #2 on: September 03, 2015, 00:30:49 am »
Not quite that easy..
What the T2 nosecone does is not just making the trans bolt up to an older car but also lowering the hockey stick considerably so it comes out in just about the right place to match up with the gear rod in the newer tunnel.
Welding in a later mount will get the trans to sit in the right place but the hockey stick will be way off. And this is where the Berg 5 trouble comes in.. I have several friends that have tried mounting one in their 50's cars and there really isn't a way to get the trans to sit right without butchering the car/tunnel. It can be done but only as a half assed solution where both the trans and the shifter mechanism sits at the wrong angle (trans low, stick high).
Mounting the Berg 5 in the correct angle will make the hockey stick way to high, aditionally the front end of the trans (where it is bigger than a standard trans) will actually hit the car.
« Reply #3 on: September 03, 2015, 00:53:44 am »
A little off topic , But part of the install . Clearance between body and trans . Something I did on a customer car. not perfectly metal finished , But its under seat . Right !
« Last Edit: September 03, 2015, 00:55:55 am by danny gabbard » Logged
drgouk
« Reply #4 on: September 03, 2015, 02:12:36 am »
It Might pay to call bergs as I know they are working on an early nose cone to fit the berg 5.
Trent B
« Reply #5 on: September 06, 2015, 03:15:59 am »
Talked to Tim at Bergs, they are looking at making a housing to suit the early cars, no ETA right now...
