September 28, 2026, 12:18:32 pm
| | |-+  Running IDAs the wrong way round
Author Topic: Running IDAs the wrong way round  (Read 7633 times)
vwhelmot
« on: October 02, 2015, 19:47:44 pm »
I've had to buy another set of manifolds as my tall skat traks were too tall and now the shorter set means that the carbs are turned around (the fuel inlets face the engine bay sides).
      What linkage is the best to use, I've fabricated a berg style one but not sure if I will use it. Will a csp bell crank one do the job, the levers on the carbs are now facing outwards.
RobtheManx
« Reply #1 on: October 02, 2015, 20:48:18 pm »
My IDAs run that way round too . I use a copy of the old Deano centre pull linkage , so I guess a csp one would work . Or get a Deano one .
Rob
dth
« Reply #2 on: October 02, 2015, 21:15:28 pm »
I,v got a CSP on short reversed manifolds , had to mess with it a bit , but works good , im sure i just switched the
levers.  Smiley
free photo hosting
kever65
« Reply #3 on: October 03, 2015, 22:06:38 pm »
I ve got a csp center mount and it woks with the same manifolds as yours.
good luck
K-Roc
« Reply #4 on: October 06, 2015, 16:54:52 pm »
Short manifolds that keep the carbs right way around.
http://www.thesamba.com/vw/classifieds/detail.php?id=1777495
RichardinNZ
« Reply #5 on: October 06, 2015, 19:17:00 pm »
Has anyone tried the Vintage Speed linkage; not sure from their description whether it works with short manifolds or not?
http://shop.vintagespeed.com.tw/s.nl/it.A/id.556/.f
http://shop.vintagespeed.com.tw/s.nl/it.A/id.710/.f
Richard
'58 Bug; NZ assembled
Dual Carb 36hp
vwhelmot
« Reply #6 on: October 06, 2015, 21:37:54 pm »
Thanks guys, I've been busy with engine mock up and decided to get a csp linkage as so I've read it clears the vertex mag I've got and should work with the short manifolds too.  It's a bit of a shame really, I spent a tonne of time fabricating a berg style linkage out of aluminium and it will work with the manifolds too but it doesn't look right.  The mount is very close to the stack on the left side and it looks too busy. I'm building the motor to look fairy minimal so the csp will work out great.
vwhelmot
« Reply #7 on: October 06, 2015, 21:40:29 pm »
just finished plumbing the carbs in, that was difficult enough;)
« Last Edit: October 06, 2015, 21:59:06 pm by vwhelmot » Logged
