September 22, 2026, 01:30:35 am
| | |-+  63 Turbo Notchback.
Pages: [1] 2 Print
Author Topic: 63 Turbo Notchback.  (Read 54126 times)
stussyrich
« on: October 20, 2015, 19:11:02 pm »
So i had these.
8 months and some work, now i have this.
Oh and it also does this. 11.94 @ 113mph 4th pass.  Grin
« Last Edit: June 20, 2017, 22:39:08 pm by stussyrich » Logged
Lil Stink Hound.. 2332 IDA. 11.78 @ 112mph.
Turbo Notch.. 2332 Turbo 10.2 @ 137mph.
dannyboy
« Reply #1 on: October 20, 2015, 19:18:29 pm »
good stuf mate you put everyone to shame with the timescale you turned this round in . cant wait to see the big engine in it or old faithfull on gas  Cheesy Cool
very cool car hope mine turns out as well.....
8.77@156.8mph
O/FF 60
« Reply #2 on: October 20, 2015, 20:09:34 pm »
Nice work. Did you convert the funny car cage to rhd use?
stussyrich
« Reply #3 on: October 20, 2015, 20:14:21 pm »
yes pretty much.
« Reply #4 on: October 20, 2015, 20:18:05 pm »
What car was the chassis originally from?
Does it feel different to the bug?
Lee
stussyrich
« Reply #5 on: October 20, 2015, 20:23:22 pm »
Lee
A new unused lummus chassis, it's been sitting around for a bit.
It feels a lot different from the bug.
« Reply #6 on: October 20, 2015, 20:26:18 pm »
Great stuff, well done it looks good
« Reply #7 on: October 20, 2015, 23:14:53 pm »
Rich
I think you did a fantastic job already, knowing 1st hand what it actually takes to go from a climbing frame to a full running driving car I would say you did really well Cool  the fact that you just got on with it and got it done in such short time makes it even better
Look forward to seeing it get a good work out with the turbo set up Cool
stussyrich
« Reply #8 on: December 06, 2015, 21:37:45 pm »
So after cooking the aspirated motor on the last outing to shakey it was time for a rebuild. was really happy with an 11.9 @ 113mph with a very unhealthy motor.
That done i turned my attention to getting the turbo motor together and into the notch. After swapping the cam and re checking everything looks like i need some new pushrods.
The compression came out at 9.1 so that should be ok.
Have a small order delay on the wastegates so as soon as they turn up i can finish off the header and pipe up the exhaust.
The motor is in and i'm now plumbing up the dry sump system and turbo oil feed and pressure light etc.  The fuel pump and reg has been swapped out for a larger one and all that is left is to pipe up the holley carb.
once the wastegates turn up i can pipe up all the boost stuff.
I've also added some micro switches to the clutch pedal and first gear for the 2 step and clutch management.
Sorted out re routing the accelerator cable and fitted the new brackets i made then adjusted it all up and it works perfectly.
« Last Edit: December 10, 2015, 21:59:34 pm by stussyrich » Logged
jamiep_jamiep
« Reply #9 on: December 07, 2015, 17:51:04 pm »
The NA motor was due a rebuild ummmmm probably two years ago Wink amazing its lasted as well as it has given how hard it is used, looking forward to seeing the turbo motor getting the same thrashing Wink
dannyboy
« Reply #10 on: December 07, 2015, 19:29:58 pm »
good work mate going to be a monster  Cool Cool Cool
8.77@156.8mph
O/FF 60
stussyrich
« Reply #11 on: December 10, 2015, 21:50:14 pm »
Yeh i do give it some stick..
stussyrich
« Reply #12 on: December 10, 2015, 21:58:27 pm »
Little bit of an update.
I've decided to mock up an oil catch tray. It seems only right as we all hate sitting around while the rack gets cleaned.
It's a fair size but i'd prefer it to work.
Bit tricky to get it to cover the valve covers and clear the rear caliper and tyres.
I might just take a bit off the top edge yet.
« Reply #13 on: December 11, 2015, 08:01:08 am »
Well done mate, good to see Cool  The NHRA requirement for size is to have a 2inch lip so if you can go with that then you are good for when these things are needed everywhere
Ragtop
8.93 at SCC 2012
« Reply #14 on: December 11, 2015, 15:32:29 pm »
Awesome looking car! I really like how it looks. Great to see another Notch on the track.
stussyrich
« Reply #15 on: December 11, 2015, 20:26:54 pm »
Cheers.
I must say i have followed your build on here and have tried to buy the mag with the feature in. Great car.
I did want a beige notch to match my bug but you beat me to it, and Richie beat me to matching cars so the original red it is.
Maybe we could race heads up some time. Although i will need to improve my times..
Rich.
andy198712
« Reply #16 on: December 13, 2015, 11:18:40 am »
There's a picture of this in this months be mag, volks world maybe? Got the ruby red bug on the front... In a show section Smiley encase you hadnt seen it!
DRAG-DAY
« Reply #17 on: January 08, 2016, 21:13:29 pm »
 Grin
stussyrich
« Reply #18 on: January 08, 2016, 21:15:15 pm »
Not a massive amount to report as i have been waiting on parts.
Got a bit done thought.
Modified the collector to allow me to fit the wastegates, then made both of the exhaust.
Moved and made a new oil filter mount  so it now sits inside the oil catch pan.
Have trimmed the exhaust pipes down a bit closer to the body now, i'll take a pic soon.
Spent some time re wiring parts of the car to make the mail control panel removable and also added some more switches and relays to the panel.
The 2 step, clutch management inc the new valve ( cheers richie ) are now sorted.
I know it looks untidy but it's all hidden under the panel and i can get to each wire individually to repair or swap out if i have any issues instead of digging through layers of bundled cables.
« Last Edit: January 09, 2016, 19:52:13 pm by stussyrich » Logged
stussyrich
« Reply #19 on: January 09, 2016, 19:56:09 pm »
Little bit more done today.
Finished off the wiring connections so i can now remove the whole panel from the car with ease.
andy198712
« Reply #20 on: January 09, 2016, 21:27:51 pm »
That's a great idea, looks really neat!!
Black_65
« Reply #21 on: January 09, 2016, 22:09:10 pm »
That looks awesome dude
dannyboy
« Reply #22 on: January 10, 2016, 10:40:36 am »
Good stuff  Cool
8.77@156.8mph
O/FF 60
stussyrich
« Reply #23 on: February 09, 2016, 20:10:38 pm »
Well it's running, dyno next.
https://www.youtube.com/watch?v=TQqJ0aLf1Yc
no idea how to show the video on here sorry
« Last Edit: February 09, 2016, 20:18:09 pm by stussyrich » Logged
« Reply #24 on: February 09, 2016, 20:39:44 pm »
Nice sound  Grin
stussyrich
« Reply #25 on: February 12, 2016, 21:37:10 pm »
Cheers dude.
Nice sound  Grin
stussyrich
« Reply #26 on: February 12, 2016, 21:39:16 pm »
Looks like everything is ok now it's been run for a bit, so it's ready for the dyno next week.
A nice safe tune at 14 psi will do perfect for now.
« Last Edit: February 12, 2016, 21:52:31 pm by stussyrich » Logged
jamiep_jamiep
« Reply #27 on: February 12, 2016, 23:26:21 pm »
Now when I leave my wings off my car I get the piss taken out of me  Undecided Roll Eyes Cheesy Cheesy Cheesy
Can't wait to here how it does Rich.
stussyrich
« Reply #28 on: March 12, 2016, 15:55:35 pm »
After 2 trips to the dyno due to clutch problems it's ready for the track.
Got a nice safe tune so it's time to go and have some fun.
Just need to make the chute mount.
Youtube link..don't know how the embed the video onto here.
https://www.youtube.com/watch?v=Oozs6L9N_UA
dannyboy
« Reply #29 on: March 12, 2016, 19:35:21 pm »
good stuff  Cool
8.77@156.8mph
O/FF 60
Pages: [1] 2 Print
