October 04, 2026, 04:00:39 am
352313 Posts in 28957 Topics by 6925 Members
| | |-+  S/A Spring Plate mod - for racing
Author Topic: S/A Spring Plate mod - for racing  (Read 11075 times)
Black_65
« on: January 24, 2016, 18:55:00 pm »
Hi guy's
Not sure if this is on the right section or if it's a load of crap then I'll delete it  Smiley.
I've got a 65 swing axle beetle and I really need to sort the rear suspension out with me going faster this season and coming off the power and not wanting the car to go into positive camber and lose control and crash...!.
Just for piece of mind I need some advice and maybe pictures of what people do. I've been told to mark a line when the car is on the for in its ride height and then jack it up slightly then mark it again. Drill a hole on the 2nd hole and bolt a m10 bolt.
To stop the car and plates going into positive camber. Any advice on how to do this properly and pictures would be a great help.
Clarke
« Reply #1 on: January 24, 2016, 21:02:20 pm »
Another option is straps next to your rear shocks to limit the droop.
hotstreetvw
« Reply #2 on: January 24, 2016, 21:16:43 pm »
Limit straps for sure.  They will stretch, which will be progressive.  You can twist the strap for adjustability.
Black_65
« Reply #3 on: January 24, 2016, 21:21:05 pm »
What length do the straps need to be or is that custom to the car?
melvin
OFF/83
« Reply #4 on: January 24, 2016, 21:33:28 pm »
mine have the same distance of the car when it's standing still , i have to racecars from the same year and one is 32cm and the other is 36cm . lay down under your cars and look what distance you need to have Wink
OFF/83
neil68
« Reply #5 on: January 24, 2016, 22:22:11 pm »
I was experiencing similar issues and ended up installing 35.5 cm (14") limiting straps.  It certainly reduced the drama, when lifting at the end of the drag strip:
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
« Reply #6 on: January 24, 2016, 22:42:30 pm »
How do the limit straps behave on a street(/strip) car? I would think a camber compensator would be more beneficial on a dual purpose machine?
Black_65
« Reply #7 on: January 24, 2016, 22:43:16 pm »
Wow thanks for the help guys,
I'll measure up and try the straps as a quick and easy fix
Dave Harryman
« Reply #8 on: January 25, 2016, 22:16:18 pm »
[ Attachment: You are not allowed to view attachments ] I made these inserts that limit drop , they don't change like straps
Jonny Grigg
« Reply #9 on: February 09, 2016, 23:02:59 pm »
Do you need limit straps? I have a spare set 13" long.
No Compromise. O/FF111
dragvw2180
« Reply #10 on: February 16, 2016, 18:56:18 pm »
 I would also replace the rubber pieces on your torsion bars with something like this,
http://www.piersideparts.net/JC1028.html      The rubber originals will move which changes the suspension settings. I actually have these on my street / race car. Just a suggestion . Mike McCarthy
