August 12, 2026, 22:39:37 pm
| | |-+  '70 cal look project
Author Topic: '70 cal look project  (Read 63205 times)
Gwar72
« on: March 21, 2016, 15:04:18 pm »
Well where do I start. Been into VW's for the last 6 years and I have a always fancied doing a Cal Look project (sharing a unit with one beauty for 4 years) So a mate was selling a 1970 1300 beetle which was in my price range and look like the perfect starting block.
So I knew that I had some welding to do (heater channels) but after stripping her apart I knew that the was more to be done. So the decision was made to do it once and do it properly (well as properly as I could manage myself)  Wink
So started to strip down the interior so I could get to see more of the body and floor...
Passengers (Left) side foot well
A post
Heater channel toast..!!  Roll Eyes
So I could see that it would be a full heater channel panel needed so I started to brace it up before going any further..!!  Wink
Door off which was a swine @#*...!! Had to use an impact screw driver to loosen and then to drill out lower inner A post screw as that was rusted in..
These picture were taken over the last few months and more to follow (playing catch up on loading) so more to follow if you want..!!??  Wink Cheesy Smiley
vwhelmot
« Reply #1 on: March 21, 2016, 16:41:39 pm »
Keep going. What's the overall look going to be? Big or small motor?
Gwar72
« Reply #2 on: March 21, 2016, 17:25:42 pm »
Original motor tidied up and back in but looking to build a bigger motor along they way, all depends on time scale, money of build..!!??  Cheesy
This is the Beauty Unit that has inspired me.  Cool
« Last Edit: March 21, 2016, 17:33:24 pm by Gwar72 » Logged
AngelzDD
« Reply #3 on: March 21, 2016, 20:04:34 pm »
I hope you return to the original 1970 style !
« Reply #4 on: March 21, 2016, 21:44:42 pm »
Good choice on inspiration! As you've probably noticed, we're not embarrassed by late models here, in fact quite the opposite! I'd go back to late panels but 1200-spec ones, just to be a little closer to Stoo's car. Use the same colour, the Lucas L488 indicators and the same lack of un-necessary chrome, just on a later car. Wheels are where it gets tricky - you need something a bit obscure but cool. Rivieras? Cosmics? Keep it 4 bolt!
Gwar72
« Reply #5 on: March 21, 2016, 22:16:54 pm »
Still undecided yet as need to replace front clip
Cheers  Smiley Yeah Stoo's car is ace but inspiration only not colour. My bug looks like it's Chinchilla grey on the dash so thinking of going along that colour route  Wink
Gwar72
« Reply #6 on: March 21, 2016, 22:26:50 pm »
So started to attack the heater channel/floor bolts. Some came straight out but others just spun round in the rotten channel so had to cut holes and angle cut bolts out...
Removing piece by piece..
Gwar72
« Reply #7 on: March 22, 2016, 14:56:11 pm »
Getting rid of the old heater channel...
Rear corner is shot so will get new cross members. Patch's on Patch here..!!  Shocked
Front foot well...
Front Outer....
So cut it out to see more....
So made the decision that it would have to be body off to get to it all..!! (Not done this before..!!)   Huh Shocked
So wings off, Bonnet and deck lid, other door...!!!  Wink
So undid all floor bolts were I could and cut out those I couldn't...!! And with a mates help we build a frame and separated the two....!!!! Smiley Grin
Extra bracing to be sure was put in before separation...
Bought some new metal. Not happy with the front lower member as it is a different style so now trying to source the correct one..!!??  Huh
Now this is up to date so pictures will be slowly added...
Cheers for now  Grin
« Last Edit: March 22, 2016, 17:30:33 pm by Gwar72 » Logged
56BLITZ
« Reply #8 on: March 22, 2016, 23:49:09 pm »
That front cross-member looked unfamiliar to me . . . until I went out to look at my '70 . . . it's the same!
FWIW . . . I'm with the other guys . . . go with '70 wings/panels!
All the best on yer project!
Gwar72
« Reply #9 on: March 26, 2016, 21:45:18 pm »
Engine off.......
And little bit of investigation on the rear crossmember today.....
Lets see whats under patch number 1....
It's like picking at a scab..!!?? You know you shouldn't but you can't help to..!! LoL  Grin
Nothing found under there then..!!  Roll Eyes
Lets see what i can find tomorrow....
vwhelmot
« Reply #10 on: March 27, 2016, 11:09:45 am »
Lots of work there. Smiley
Gwar72
« Reply #11 on: March 29, 2016, 14:08:17 pm »
YEP..!!  Cheesy
« Last Edit: March 29, 2016, 14:16:03 pm by Gwar72 » Logged
Gwar72
« Reply #12 on: March 29, 2016, 14:11:56 pm »
Cheers  Smiley
Full bulkhead Panel sorted from VW Heritage  Cool
Gwar72
« Reply #13 on: March 29, 2016, 14:40:21 pm »
Well had a look at the Hooky's A pillar repair post (which looks top quality) and using the alignment tool (works a treat) I mocked up how it would go...
Then cut out the rot....
And trial fit again...
Just want to see how it went it, got a bit low cutting stuff out so wanted to see how it would look with something in place (if only as a mock)..!!??  Smiley Smiley
So then went back to cutting out the rot on the rear cross member....
Going to see if I can find some body cuts of these areas..!!?? Left and Right sides.. Huh Roll Eyes
And a rear luggage panel small cut to replace this gash..!!
« Last Edit: March 30, 2016, 11:28:29 am by Gwar72 » Logged
Gwar72
« Reply #14 on: March 29, 2016, 14:43:30 pm »
Attack the birds nest wire in the boot.....
Looking a lot tidier..!! LoL  Grin
Going to re-loom it with fresh....
And then thought, why stop there so out came everything..!!!
Then decided to replace the whole front bulk head as there were patches on patch's here to..!!  Roll Eyes
So spot weld drilling done and a bit of persuading out it came...
Plenty of hidden rust in between panels
And out it came, you can see the patch's clearly here..!!!  Roll Eyes Roll Eyes
So that's a full Easter weekend taken up.....!!!!  Grin Grin Grin
Volksworld next weekend so that's your fill of pictures for now..!!  Wink Wink
« Last Edit: March 29, 2016, 14:47:03 pm by Gwar72 » Logged
« Reply #15 on: March 30, 2016, 19:29:07 pm »
Great work! Can't wait to see more (:
Gwar72
« Reply #16 on: March 31, 2016, 16:12:11 pm »
Thanks  Smiley A lot more to come..!!  Wink Grin
Packaged arrive today...... Grin Grin Grin Cool Cool
Not sure why there are screws coming through..!!??  Huh Roll Eyes
56BLITZ
« Reply #17 on: March 31, 2016, 18:31:41 pm »
WOW . . . looks O.E.M.!  Cool
Was it made in Mexico?
Gwar72
« Reply #18 on: April 05, 2016, 09:39:43 am »
It's a genuine part but not sure where it was made?? Very good quality, heavy and solid..!!  Smiley Cool
« Reply #19 on: April 05, 2016, 10:14:37 am »
Looks like the VW Mexico part that I fitted to my car many years ago. Not strictly correct for a 60s beetle but fits so much better than the repro. The threaded studs are for a push fit clip that holds wiring in place - quite common on New cars. Whip them off with the grinder!
Gwar72
« Reply #20 on: April 05, 2016, 12:29:31 pm »
Cheers  Smiley
Gwar72
« Reply #21 on: April 11, 2016, 13:56:42 pm »
Trial fit of the new bulkhead... Wink Grin
Then drilled out spot weld on steering column collar so ready to move to the correct side (Right)  Wink
Where there should be a hole....
And hole (51mm) cut out....  Wink
Also tidied up the front chassis/pan...
Pedal assembly removed and brake master cylinder. Also scraped off under seal to make media blasting easier...
Now just got to wait till I have a compressor set up in the workshop then I can media blast areas around bulkhead before it can go in.....  Smiley Wink Grin
jamiep_jamiep
« Reply #22 on: April 13, 2016, 10:00:59 am »
You have your work cut out for you there... excellent progress though, keep the pictures coming.
Gwar72
« Reply #23 on: April 13, 2016, 13:57:54 pm »
Cheers  Smiley   "cut out" is quite true..!!  Grin Grin
Blasted pedal assembly and etch primed...
mr horsepower
« Reply #24 on: April 13, 2016, 18:31:34 pm »
Wow man memory lane for me
There is  a lot of work to do
Reminds me my car that was total crispy
I was lucky to find an other verry good body
With almost no welding needed
But that was 20 years ago
You don t find them so easy annymore these days
Good luck with the build.
Gr
Gwar72
« Reply #25 on: November 16, 2016, 15:02:55 pm »
Finally managed some time up the unit since April..!!  Roll Eyes Roll Eyes
Scraped off the wax oil off the outer front wheel arches to see how it looked underneath. Not to bad so a little vertical patching strip where the bulkhead spot welds to on both arches and then start to look at some local media cleaning and priming before bulkhead goes in.
Going to be replacing front clip to
Going to be cutting out previous lower repair panel.
Gwar72
« Reply #26 on: December 07, 2016, 12:59:06 pm »
Well did my first bit of welding for a year..!!  Shocked Grin
Swopped over steering column hole...
Made up a blanking plate..
Not to bad  Grin
And ground down..
Media blasted lip to where bulkhead spot welds up under so not trapping any rust and then sprayed weld trough primer. Then started to weld in new metal into inner front arch to where bulkhead sides will spot weld to but then ran out of gas..!!  Roll Eyes  (pic to follow)  Smiley
Gwar72
« Reply #27 on: January 28, 2017, 20:32:26 pm »
I was going to weld up the front quarters but as there was so much to repair like wing nut mounts, lips etc so decided to replace whole panel...
So off with the old  Smiley Smiley
« Reply #28 on: January 28, 2017, 22:49:30 pm »
Sensible move - if they need more than the bumper mount and lower repair its not worth fixing them. Get the genuine quarters tho - the repro ones aren't worth bothering with.
Gwar72
« Reply #29 on: January 28, 2017, 23:52:20 pm »
Funds may not stretch to genuine?? Roll Eyes Roll Eyes
