September 22, 2026, 12:50:42 pm
| | |-+  Aftermarket pulley issue
Author Topic: Aftermarket pulley issue  (Read 6002 times)
stretch
« on: April 17, 2016, 17:04:07 pm »
Has anyone had an issue installing an aftermarket crank pulley and have it touching the case causing it to bind?  It's a power pulley and I'm using it to clear a CB dry sump pump.  Can I just space the pulley away from the case using a spacer kit?  Thanks.
dth
« Reply #1 on: April 17, 2016, 17:13:14 pm »
It would be worth comparing the stub on the pulley to another one , see what the difference is,
if there is a difference then i dont see a problem running a spacer , or if there is enough material
on the back of the pulley get it clearenced ?
stretch
« Reply #2 on: April 17, 2016, 17:22:20 pm »
Cheers Donald.  I'll compare it to the old pulley I was using.  I just wondered if it was a common problem.
« Reply #3 on: April 17, 2016, 17:31:14 pm »
Some pulleys come with a spacer in the packaging now so guessing its a common problem Wink  As long as your pulley bolt has plenty of threads still then will be fine,  Is it an Ally case?
stretch
« Reply #4 on: April 17, 2016, 20:39:18 pm »
Thanks for the info Richie.  I was beginning to wonder if I'd done something catastrophically wrong.
Yes, it's an ally case.
fish
« Reply #5 on: April 19, 2016, 12:29:15 pm »
A local guy had an engine lock solid caused by the binding of Ally case and Ally pulley.
kb
« Reply #6 on: April 20, 2016, 12:35:57 pm »
I've had that myself on an AutoLinea case and EMPI laser engraved pulley.
Upon disassembly, the brand new engine case cracked a bit at the pulley-end. Had to get it welded, and then "line bored" the pulley hole again.. Not fun, 2-3 days before the race.. But got it fixed in time Shocked
Roman
« Reply #7 on: April 22, 2016, 11:49:50 am »
I had that problem too. Now I only use steel center pulleys.
