August 13, 2026, 03:38:40 am
352259 Posts in 28945 Topics by 6923 Members
Latest Member: Lotus67
| | |-+  Vertical shifter and dog ring gears
Author Topic: Vertical shifter and dog ring gears  (Read 5020 times)
Elnef
« on: April 26, 2016, 07:19:18 am »
Last time at race I made a big bummer got it in first gear instead of third around 8000 rpm gearbox did not like it
Now some says I could run with vertical shifter problem solved
But I have always heard it will shift to fast
So I will like to know is there anybody out there running with dog ring and vertical shifter ?
Thanks John
« Reply #1 on: April 26, 2016, 07:39:40 am »
John
I have used vertigate with syncros Shocked Worked fine and didn't chew them up, lasted all season without any problems, then just freshened them up during winter, now I have pro rings/slick shift and go a season at least without needing anything, the thing for me is adjust the stops correctly on shifter, it takes time and most problems I see are from over shifting and banging past were it needs to be. I do always use clutch to shift though
Basti
« Reply #2 on: April 26, 2016, 10:09:10 am »
John,
i had dog rings and vertigate on my old car and it worked very nice for me.
Cheers,
Basti
- black 62 cal look beetle
- Pro Mod Race car
Tufty65
« Reply #3 on: April 26, 2016, 13:44:03 pm »
I've just installed a vertigate and run pro rings and it works nicely
Outlaw Flat Four 35
12.64 @ 106.25mph
