July 24, 2026, 19:02:53 pm
| | |-+  Lifter bores
Author Topic: Lifter bores  (Read 42410 times)
max Der Bahnstormerz
« on: May 02, 2016, 08:03:31 am »
Reaming the bores straight, found a few tight, high spots in them
Then radiused the bore face
Final job was to give each bore a quick polish
These guys should appreciate their new home, next on to crank clearance and valve timing
« Last Edit: May 02, 2016, 08:16:28 am by max Der Bahnstormerz » Logged
« Reply #1 on: May 02, 2016, 10:10:23 am »
looks nice! what lifters are they?
« Reply #2 on: May 02, 2016, 10:28:32 am »
Schubecks
« Reply #3 on: May 03, 2016, 06:02:48 am »
nice work. may i ask what machine you use to do this?
i used a very old at work to do this (horizontal mill, don't really know the name in english), most certainly 50 years old.
« Reply #4 on: May 03, 2016, 08:30:30 am »
Just an adjustable hand reamer, a hand drill and a tool bought from Berg's 25 years ago to face the lifter bores.
Then finished off the bores with 120 grit loosely wrapped around a rod in a drill to hone the bores.
Nothing fancy, just lots of care taken not to remove too much material.
Paul Bahnstormerz
« Reply #5 on: May 03, 2016, 08:54:23 am »
Heads done 😊
« Reply #6 on: May 03, 2016, 19:57:10 pm »
cool, but i assumed you fitted the bushes yourself as well. it looks really good.
« Reply #7 on: May 03, 2016, 23:08:05 pm »
Clearance checks all done, should be able to button up the bottom end tomorrow  Grin
« Reply #8 on: May 04, 2016, 07:54:38 am »
Nice to see that you used the split bearing nr3
Paul Bahnstormerz
« Reply #9 on: May 04, 2016, 09:11:32 am »
That doesn't look like the cam we were looking at over the weekend!
Jeff68
« Reply #10 on: May 04, 2016, 13:02:04 pm »
Case assembly looks good.....What kind of crank is that?
« Reply #11 on: May 04, 2016, 15:13:04 pm »
That one was too gay abou the same as a 125!! Going to save it for the SPG motor. I decided to use the 86c on 112LC and aiming for just under 10 to 1 CR. Need to keep up with you nitrous boys.
« Reply #12 on: May 04, 2016, 15:15:29 pm »
Thanks. That's an 84mm crank with a wedge mated flywheel from Bergs.
« Last Edit: May 04, 2016, 15:21:29 pm by max Der Bahnstormerz » Logged
« Reply #13 on: May 06, 2016, 21:00:28 pm »
Oh no! Too much deck! Almost 100 thou without the copper head shim, need to get some thinner barrel spacers. Aiming for 10 to 20 thou plus a copper head gasket (0.040")
« Reply #14 on: May 06, 2016, 22:02:12 pm »
Aim for 40 th max. It will help reduce pre ignition.
Paul Bahnstormerz
« Reply #15 on: May 07, 2016, 11:52:25 am »
Do you want my spare solenoids? 😉
« Reply #16 on: May 07, 2016, 14:59:15 pm »
is that 40thou in total? or 40 thou excluding the copper head shim?
fish
« Reply #17 on: May 08, 2016, 10:02:03 am »
i would run .020 deck and .040 head gasket
« Reply #18 on: May 09, 2016, 17:04:09 pm »
Cool, that's about what i was aiming for, possibly a little tighter to improve the squish.
neil68
« Reply #19 on: May 09, 2016, 20:17:31 pm »
My 2332 cc is similar: 0.020" DH + 0.040" copper head gaskets.
If you have piston notches, you could probably tighten up to 0.040" like my earlier combo, but would need high octane fuel.
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
« Reply #20 on: May 10, 2016, 15:49:31 pm »
I meant .040" total deck including copper gasket. If you need to lower compression dish the piston or do chamber work instead of adding deck. You want all the combustion to happen in the chamber and not in the outside edges where the pre ignition starts. My 1776 has 9.4:1 CR and doesn't ping on regular gas as a daily driver. The timing doesn't need to be advanced to make power either. Back the timing off and it still makes power  Smiley
« Reply #21 on: May 10, 2016, 20:15:35 pm »
Cool, that's the sort of deck I was aiming for, I've tried to keep as much of the squish area intact in the chamber and just unshrouded the valves as much as possible.
« Reply #22 on: May 10, 2016, 21:49:03 pm »
For comparison, here's a pic of how mine were ported. Yours have even more of a squish area intact.
« Reply #23 on: May 11, 2016, 01:38:57 am »
Can I please ask what heads they are?
« Reply #24 on: May 11, 2016, 04:00:19 am »
they're CB comp eliminators
« Reply #25 on: May 11, 2016, 15:09:08 pm »
What cc are the chambers?
« Reply #26 on: May 11, 2016, 16:43:58 pm »
55cc's
« Reply #27 on: May 11, 2016, 16:56:44 pm »
So I get 10.4:1 CR, kinda high for pump gas but it might work. I think that's why my chambers are larger - he was trying to get the CR down for turbo. He also got 7cc's more out of dishing the pistons. The nice thing about the tight deck is that you don't have to run advanced timing to make power. Simply back off the timing until it doesn't ping and you're done.
https://www.cbperformance.com/v/enginecalc.html
« Last Edit: May 11, 2016, 16:58:27 pm by Martin S. » Logged
« Reply #28 on: May 11, 2016, 20:35:27 pm »
I've always wanted to try to copy the combustion chamber shape onto the piston and then machine the piston a little to gain cc's, thus also keeping the squish area intact. Or maybe just pocket the area in front of the inlet valve, I think that would give the best results without lowering the CR too much.
« Reply #29 on: May 11, 2016, 22:01:13 pm »
You mean like this? If you had more like 60cc instead of 55cc your CR would drop to just under 10:1
