October 01, 2026, 19:47:26 pm
| | |-+  electric fuel pump advice
Author Topic: electric fuel pump advice  (Read 7711 times)
andy54
« on: May 24, 2016, 22:19:28 pm »
hi people
looking to up grade my electric fuel pump as the ol cb 3.5lb is not up to the job as its not keeping up with the carbs.was looking at getting a mallory with areomotive reg or something along those lines.
motor is 2276cc clay smith cam like fk89 44/37 heads not sure the compression 10/1.. 48 i.d.a's any advice would be very good
thanks for looking andy
« Reply #1 on: May 25, 2016, 06:54:32 am »
I run a cb pump with very similar motor spec. Why do you think it's not keeping up with the carbs?
« Reply #2 on: May 25, 2016, 07:03:21 am »
hi people
Andy
have the carbs had the float bowl mod to enlarge it? if not that is where I would start, its simple enough mod
67_looker
« Reply #3 on: May 25, 2016, 20:48:07 pm »
The CB 3 1/2 lbs. rotary fuel pump #3193 supports 250hp with no problems. My friend and I have tested it at the Autobahn…  Grin 140mph with 3.0 Needle Valves and enlarged float bowls.
« Last Edit: May 25, 2016, 20:56:42 pm by 67_looker » Logged
andy54
« Reply #4 on: May 25, 2016, 23:09:42 pm »
hi people
Andy
hi richie and others
no the only mods to the carbs are 3rd progression hole and jpm stacks and vents.there is a 8mm hard line from the tank to the reg.when the car was on the rollers jim said the fuel pressure was dropping right off at high rpm range.also he seemed to think the float bowls were emptying too.
also the reg is just now a flash t pice as it was a cheap holly one..
cheers andy
dragvw2180
« Reply #5 on: May 26, 2016, 01:47:10 am »
 Hey Andy,
             The float bowl mod is merely opening the well that looks like another accelerator pump well to gain a few more cc's of fuel storage. I have used Holley fuel pressure regulators with no problems , in fact I have one on my turbo car now .  Make sure your fuel tank vent system is working properly also. Mike McCarthy
« Reply #6 on: May 26, 2016, 07:12:58 am »
Replace the reg with just a normal tee piece?
kever65
« Reply #7 on: May 26, 2016, 19:11:53 pm »
Make sure your fuel tank vent system is working properly, had same issue before.
andy54
« Reply #8 on: May 29, 2016, 13:55:16 pm »
thanks guys for the info.the old reg is now just a flash t pice as the cb pump i think has a built in reg.my fuel tank in the car is a stock 54oval tank with the 100mm cap so thats the only vent is there.
so you would say leave the pump at just get the float bowels made bigger???
cheers andy
