November 03, 2026, 01:46:55 am
Lifter rotation
Topic: Lifter rotation (Read 7833 times)
baz
Lifter rotation
May 28, 2016, 12:33:12 pm »
I'm looking at my cam and lifters to make sure they are useable, I've measured lobe taper and lift both seem good. I've checked the lifter crowns and they have a convex surface all measure out the same or very close. They spin ok in the bores and fall under their own weight.
What they don't all do is rotate as the cam is turning. The exhausts rotate but the inlets don't. I just have the crankcase bolted up with only cam and lifters installed. Do the lifters need the pressure from the valve springs before they follow the cam properly and rotate? Or should they rotate just under gravity with the case on its side on an engine stand?
I will prevail.
baz
Re: Lifter rotation
May 29, 2016, 20:46:09 pm »
Well after a day messing about trying to see why my lifters weren't turning I tried some cam shield on the lobes and found this makes the lifters all turn. I had just been lightly oiling the lobes and lifters.
So when the engine is running and the cam shield has washed away, the oil will do the same job of allowing the lifters to turn?
I will prevail.
Re: Lifter rotation
May 31, 2016, 20:41:31 pm »
Most lifters have no or the wrong radius , so they can not turn right . And yes they need some pressure
www.Udobeckertuning.de
baz
Re: Lifter rotation
May 31, 2016, 22:41:52 pm »
These are jpm cam and lifters, the lifters have a crown of .05mm and the taper on the lobes measures .03mm around the circumference. All are turning sweetly with cam shield applied and just using gravity with the case on its side.
I'm thinking of switching to tp lightweights while the engine is apart. I've read they will work with the raptor cam.
I will prevail.
Re: Lifter rotation
June 04, 2016, 13:09:04 pm »
JPM lifters radius is correct
Re: Lifter rotation
June 05, 2016, 09:06:04 am »
....and so are TP lifters. I gave Johannes the specs of TP lifters and he gave me thumbs up with his JPM cam.
So this is what is running in one of my engines.
Some of my cars:
RobbyKo
Re: Lifter rotation
June 15, 2016, 18:07:21 pm »
Hello Udo, would JPM cams also fit to your lightweight 59g lifters?
