November 02, 2026, 11:49:19 am
2332 cc single carburettor will it work
Topic: 2332 cc single carburettor will it work (Read 40876 times)
bang
June 09, 2016, 09:42:47 am »
hey. i bought a 2332 motor with a fk10 cam in. it is for a bus and i like the original look. my thoughts was to put on a single carburator and modify original airfilter and tin and i want heat in the car.
any one run a single 48ida with that wild cam or do i have to step down on the cam.
or do i have to run 2.
Re: 2332 cc single carburettor will it work
June 09, 2016, 10:22:00 am »
The engine will run but it will idle terribly, get awful mileage, and make a lot less power.
mr horsepower
June 09, 2016, 16:55:39 pm »
Just try it and tune it.
Then you know if it wil work.
Seen a lot single carb engines in autocros
Some ran like shit others verry smooth
Its al about the rigth tunning.
Gr henri.
June 09, 2016, 17:40:50 pm »
I know its not 100% comparable but I run a single throttle body in middle on my turbo engine with more cam than that and off boost it cruises around fine, getting a single carb tuned right will be more difficult but a big single barrel should be able to work with a plenum under it, is it worth the effort though?
June 09, 2016, 23:56:36 pm »
I've run a small Solex on a smaller cc engine with a bigger cam than that..........and it was HUGE fun!
Spits and snarls and lumps and farts, then for about 2000rpm all hell broke loose, hahaha!
A single 2BBL makes a big difference to both idle and driveability over a single, makes it almost nice, an engine that big could use a plenum like Ritchie said I rekn too, but the choice of carb to make tuning nice and easy and forgiving probably won't have a "W" at the start of the name (can I say H0ll3y without getting excommunicated?).
Centremounts with a decent cam don't have to be terrible at everything if you set it up right.
RhoadsVW
June 10, 2016, 05:06:39 am »
It will run very hot
Der Renwagen Fuhrers
Dalland
June 10, 2016, 06:21:51 am »
Quote from: Zach Gomulka on June 09, 2016, 10:22:00 am
A high vacuum at idle will make the engine easier to tune for idle.
Mileage might be lower but at a bare minimum.
Lott less power? O Yes!
RhoadsVW writes:
It will run very hot.
Please give me a good reason why, because that sounds just like a guess.
RhoadsVW
June 10, 2016, 09:31:27 am »
OOps, I read again and I miss that it was a single 48. Was thinking a smaller carb.
bang
June 10, 2016, 10:12:50 am »
i want it to be as original and oldschool as possible. most likely to fit in a bus or my 71 carbrio. i was thinking single 48 idf or single ida.
know fat performance has used single cap on there dune engine might worth asking greg.
fish
June 10, 2016, 11:15:43 am »
You will do best with single 45 Dellorto, heated manifold and vaccuum dizzy
June 10, 2016, 16:01:17 pm »
Quote from: bang on June 10, 2016, 10:12:50 am
I don't see how a single two barrel is either original or old school?
In a bus application it will require a very short air filter, not good.
Comparing your engine to a Fat off road race engine is totally apples to oranges. Massively different application and they have class rules to adhere to.
The sensible choice would be a pair of 48 IDF's, but if we were sensible we would all be driving a Honda
Berger
www.bugrent.no
June 10, 2016, 20:19:47 pm »
Not as big engine, but some ideas to get from this maybe.
http://www.youtube.com/v/Stjxa_6bszI
This is my simple religion:
-Be cool
-Don't be an asshole
June 10, 2016, 20:53:44 pm »
Quote from: Berger on June 10, 2016, 20:19:47 pm
June 10, 2016, 21:39:55 pm »
I remember tuning a WW Stromberg (small 2-BBL) on a VW in the late 70s here in Oz, and how many pics do you see of Bugsprays and Zenith carbs from "back in the day"?
That's old-school enough for me, we still even had B&W TV out here!
My favourite carbs for this type of application are Holley 7448/4412, WW Stromberg, Carter BBD (as long as the piston chambers aren't stuffed), but my all-time favourite is the Bendix-Stromberg single barrel.
All of these carbs have excellent transition ccts that can supply heaps, cruise on mains economically, and have a power valve cct which means very simple part-throttle tuning. These carbs are all designed to happily run a big engine through small diameter long manifold runners with great throttle response and cruise manners, while pushing big un-aero lumps of cast iron (sound familiar?). Put a stock OEM 70s-type air cleaner assembly on it, complete with snorkel, and it would definitely have "stock looking" appearance to anyone but a VW person.
I'll warn you though, you won't get any street cred whatsoever at the next get-together, no matter how nicely it drives.........
PS: the cam will suit torquey highway cruising perfectly with stock rockers.
Last Edit: June 10, 2016, 21:43:32 pm by modnrod
June 10, 2016, 23:18:42 pm »
Sure a Zenith, etc is "old school", but that doesn't mean all single two barrel carbs are. IDF/DRLA are far too new, and a single IDA was not a common sight.
I still say a 2.3L single carb with that large of a cam will not have good manners, will net bad mileage, and will leave a lot of power on the table compared to a set of duals. If you're ok with that, do it.
June 11, 2016, 09:52:33 am »
How about gutting a stock carb and using it as a throttle body? Or even one step further, hide a turbo in the big oil bath air cleaner and blow through a single in the stock location?
June 11, 2016, 11:18:06 am »
I have a single IDA manifold if you want to go that route Peter
All old school looking and chromed
RMS Boxer Service
June 11, 2016, 12:16:36 pm »
A lot less cam and less compression, it will be possible.
/Rolf
JPS aircooled
September 01, 2016, 11:26:49 am »
If have a 2276cc Engine with Single Carb in my Oval, it works
Here is the link:
http://jpsaircooled.blogspot.ch/2015/09/jps-single-carburetor-rd-project.html
and the upgrade with 39 PICT-3
http://jpsaircooled.blogspot.ch/2015/09/limbach-l2000-assembly-and-upgrade-jps.html
Have 122hp at 4700rpm and 210Nm at 2600rpm torque
Regards,
Pit
September 01, 2016, 19:27:12 pm »
Quote from: JPS aircooled on September 01, 2016, 11:26:49 am
Here is the link:
Regards,
Pit
Yeah, 120 hp 200 Nm from a 2275 sgl. carb. (Modified 34 mm Solex) split duration split lift cam, but not even close to the FK10. Idles like a stock engine.
A sgl. 44IDF or 45 Dell could work OK with the right manifold and the right work to the end pieces.
Jesse Wens
September 07, 2016, 08:24:02 am »
are these modifications also possible on a 34PICT5 from a vanagon?
Got a high compression 1.9 in the makings.
karl h
September 08, 2016, 07:23:02 am »
is it possible to use a 36/40 solex from a Type 4 dual carb set as a single in the middle? i took a look, you have to modify the linkage, but the rest seems to work with an adapter to the maniflold. it even has a choke and the vacuum port
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
September 08, 2016, 10:42:33 am »
For a while in the late 1980s, some of the PRA Pro Stock guys tried running a single four-barrel Holley on a fabricated manifold. It worked, but as soon as the big-bore IDAs became commonplace, they all went back to dual carbs.
karl h
September 08, 2016, 10:54:03 am »
i rember a plenum with twin 40 dells they claimed made more hp than IDAs
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
September 09, 2016, 00:24:57 am »
Tunnel rams make more power than stacks, and a larger overall power as well.
Idle like crap, but that's 1/2 the appeal.
malec 300
September 09, 2016, 08:02:48 am »
Hallo
Typ 1 engine 94-78 with 39 PICT 3 A1Header and 123 USB Ignition,
malec 300
September 12, 2016, 09:04:54 am »
2.165 typ 1 and 39 PICT Carb, 40-35,5 Valves, SLR Cam, A1 Header, 123 USB Ignition,
Last Edit: September 13, 2016, 05:54:15 am by malec 300
September 12, 2016, 15:44:06 pm »
Some things are not for me to understand.
malec 300
September 12, 2016, 19:27:29 pm »
Login , and you can See the Dynotest and Pictures,
Regards,
Last Edit: September 13, 2016, 05:52:27 am by malec 300
JPS aircooled
September 13, 2016, 20:17:39 pm »
This is how my Engine look now:
I have changed the exhaust from CSP supercomp to CSP Wasp Stage 1, the improvement in torque was about 8-10Nm the Sound of the engine with this exhaust is even more impressive.
The biggest improvemnt was the Change from 37 PICT-3 to 39 PCIT-3, better idle and great throttle response.
On Malec`s engine and mine you can see that this configuration works nice!
BTW: Congratulation Malec for your nice build!
