September 22, 2026, 01:30:33 am
| | |-+  crazy frog full automatic turbo bug
Pages: 1 2 [3] 4 5 6 Print
Author Topic: crazy frog full automatic turbo bug  (Read 137185 times)
mr horsepower
« Reply #60 on: August 20, 2016, 18:09:54 pm »
So....
I hope this wil work
Now get the electronics in order...
Gr henri
mr horsepower
« Reply #61 on: August 21, 2016, 14:42:35 pm »
This switch wil make sure there is no power on the system once shifted into 2nd
You don t want the brake to engage when at speed
Gr henri
andy198712
« Reply #62 on: August 21, 2016, 18:15:46 pm »
thats gonna be great! should be a really solid brake right?!
mr horsepower
« Reply #63 on: September 15, 2016, 19:31:01 pm »
Hello loungers.
I have my ecu back from repair
And it works ok .
I also have the transbrake working
And i must say its quite a kick in the but when i realese the button.
I am amazed how good it works .
I did a few 3000 rpm test launches on the street
And it puls verry hard now and got a quicker spool up also.
Now i have to dail it in on the launch control button .
I decided to go to drachten this weekend .
I going to try to get the car in the 12s that would be my best et ever
Lets see.
Gr henri
« Reply #64 on: September 16, 2016, 06:25:03 am »
So coooool and such good news!
Now with this nice progress, soon we will see followers. If not, I would be surprised.
mr horsepower
« Reply #65 on: September 16, 2016, 07:50:01 am »
Thanx .
So the next problems arived.
Tue the hard acceleration.
The rear tyres are hitting the fender at high speed
And the breathertower is spirting
Oil .
So get that solved today
Gr henri
mr horsepower
« Reply #66 on: September 16, 2016, 17:40:02 pm »
Solved .
So now on are way to the dragstrip
fahrvergnugen
« Reply #67 on: September 16, 2016, 19:51:35 pm »
Drachten?
mr horsepower
« Reply #68 on: September 19, 2016, 11:45:06 am »
Hello
There are still ecu issues
Lack of power due misfires
But still did a 13.5 with bad start
And engine misfire on verry low boost.
Got a vid of the run
If that problem wasnt there
A 12 would be no problem
Wil post later.
And come back on it
The autobox and transbrake
Did a fantastic job.
The car is a blast to drive
Check the vid and judge
I
Gr henri
« Last Edit: September 19, 2016, 11:55:50 am by mr horsepower » Logged
mr horsepower
« Reply #69 on: September 19, 2016, 12:39:56 pm »
https://youtu.be/wEfXa1o7QnI
https://youtu.be/fpLQCj_WguM
Here you go
Gr henri
« Last Edit: September 19, 2016, 13:47:34 pm by mr horsepower » Logged
Berger
www.bugrent.no
« Reply #70 on: September 20, 2016, 20:27:41 pm »
Very nice! Will be interesting to see how much power the auto box can handle. I have been playing with the automatic trans thought, but the "experts" say the auto bus trans is not strong enough. Cool if you can share in details the upgrades you have done to the box.
I found the limit with stock wbx parts and turbo this season, 1,8bar boost, 412hp = bent one rod, cracked a liner and also cracked a piston (cast) at my 10,89 run  Cheesy
This is my simple religion:
-Be cool
-Don't be an asshole
Erlend / bug66
Global Moderator
SCC Event
« Reply #71 on: September 20, 2016, 21:00:34 pm »
What ECU are you running?
Sounds like you are really(!) soft on how to build boost on the line?
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
mr horsepower
« Reply #72 on: September 21, 2016, 07:28:56 am »
What ECU are you running? 2
There lays also the problem sometimes there is not enough power to get it in to high rpm on transbrake.
Due a faulty ecu
Sometimes it will lauch good .
Wil work on that.
The ecu is a kms system
Gr henri.
JeePee/DVK
« Reply #73 on: September 24, 2016, 08:00:56 am »
Good job Henri.
mr horsepower
« Reply #74 on: September 28, 2016, 17:05:05 pm »
That are good numbers
Hope you get it fixed for next year.
About the tranny its quite beef i most say and it deliver the power trough  the converter so the shockloads are
Way less than a manual set up
I am sure it can handle the power easy when propperly build .
In the audi 200 turbo and porsche 944 the use it to
And they are verry reliable .
I wil try to run the pro et series next year with the car and change some things in the winter
Get a new ecu and make a bump box for the tranny
Also have to change to diskbrakes as i am on the limit now on the drums with the heavy car
Gr henri
Berger
www.bugrent.no
« Reply #75 on: September 29, 2016, 07:52:21 am »
Gr henri
Thanks, yes it will be fixed and upgraded for the 2017 season. Gowesty have forged 96mm WBX pistons from JE and Westwood Cylinders will make me ductile liners. Also Pauter rods are in the plan Smiley
Looking forward to see your upgrades and results next year!
(please pad your cage, your helmet is dangerously close to it  Shocked )
« Last Edit: September 29, 2016, 09:26:18 am by Berger » Logged
-Be cool
mr horsepower
« Reply #76 on: December 11, 2016, 12:17:28 pm »
so as the winter started .
i first getting some disk brakes on the car .
as the plan is to go faster in 2017
i was looking for the rigth set up for me
and made it 5x4,75 around
so i can swithc from street to strip easy as i have 2 sets wheels now...
 then  i wil take the transmission out to get it a firm check and
change where neccecery i wil post pics from that ..
the converter is getting a different stall speed so it has to be opened ..
for the rest i will change little things or improve smal thingz
i think this is verry doable for this winter
and i can put the car at the lights in 2017 again..
gr henri
mr horsepower
« Reply #77 on: December 24, 2016, 15:52:47 pm »
so the wheels are on got it sorted...
this wheel are a perfect fit for my car
drilled to 5x4.75 patern
merry xmas everybody
gr henri
« Last Edit: December 24, 2016, 15:54:59 pm by mr horsepower » Logged
mr horsepower
« Reply #78 on: December 24, 2016, 16:24:46 pm »
nice only have to remove some decals...
andy198712
« Reply #79 on: December 24, 2016, 20:04:08 pm »
cool, what are they spares from?
i like the look of steel wheels personally!  Cool
mr horsepower
« Reply #80 on: December 24, 2016, 21:11:38 pm »
bmw 3/5series andy.
gr henri
« Reply #81 on: December 25, 2016, 13:54:57 pm »
Aluminium and mine weigh 5,9 kg each
6,5" X 15"
Good stuff att the right price.
andy198712
« Reply #82 on: December 25, 2016, 15:13:29 pm »
bmw 3/5series andy.
gr henri
Cool, and ally too? what sort of years are they from?
cheers
Andy
« Reply #83 on: December 26, 2016, 18:17:15 pm »
I am just guessing but 15-20 years old.
Pop in to any scrap yard with BMW 3 and 5 series older cars.
Do not mention alloy or price will go up. just have a look at them.
You see that they are thicker.
I have two different off-set versions.  Both are 6,5 x 15 but slightly different. One with fully round holes and one with a slightly oval type of hole.
Most of my wheels have a small sticker warning about just that they are alloy and if I recall right, to torque correctly.
andy198712
« Reply #84 on: December 26, 2016, 21:21:03 pm »
Cool! if they work on your car and Crazy frogs they'll be fine on mine  Grin
mr horsepower
« Reply #85 on: December 26, 2016, 23:25:11 pm »
verry true...
but if you use like i do the 120.3 bolt patern instead of the 120 or 120.6
you can also use the jaguar spare aloy wheels and they are verry llight
gr henri
« Reply #86 on: December 28, 2016, 15:20:13 pm »
Ahh, by the way, the BMW ones are not spares.
Regular mounted on all four Wheels.
andy198712
« Reply #87 on: December 28, 2016, 19:16:29 pm »
cool so its there "basic" wheel then i guess... will scan eBay Smiley
mr horsepower
« Reply #88 on: January 12, 2017, 19:39:19 pm »
hi i did get the brakes sorted.
disk at front and drum at rear.
is this good enough for my car ??.
the car goes 200 kmh easy .
or do i have to fit disks at the rear to.
can someone advise me
gr henri
« Last Edit: January 12, 2017, 19:41:42 pm by mr horsepower » Logged
« Reply #89 on: January 12, 2017, 19:46:23 pm »
Hi Henri
Stock discs and drums on old cabrio still, stops ok from 158mph[255kmh]  Wink
https://www.youtube.com/watch?v=TVtjQQcIoFg
