October 01, 2026, 19:48:10 pm
| | |-+  Engine Combo in Pro stock
Author Topic: Engine Combo in Pro stock  (Read 5897 times)
ottobros
« on: September 18, 2016, 11:41:19 am »
what is the best or most common engine combo to run in pro stock ?
10,5 pounds per Cubic inch ?
« Reply #1 on: September 18, 2016, 15:02:13 pm »
Lenard? not sure which Otto brother it is?  Grin
Pretty sure they use East coast Pro stock rules, and its 9lbs/CI with minimum weight of 1300lbs for stock head stud pattern and 1350lbs for non stock head stud pattern[WBX/Autocraft/ pauter etc 4inch bore & bigger]
Found this link might help you
http://ecpra.com/WP/pro-stock-rules/
Most of what I have seen is 4inch bore and bigger, roller cam and vacuum pump
ottobros
« Reply #2 on: September 18, 2016, 15:27:39 pm »
Thanks Richie for the info
« Reply #3 on: September 19, 2016, 18:27:52 pm »
.  On 4" bore most only may have 78 stroke .   And I like the flat Tappert cams more to run lightweight lifters😀
