November 02, 2026, 13:23:51 pm
Show pictures of your very own Cal Lookers guys
50
51
52
53
92
Topic: Show pictures of your very own Cal Lookers guys (Read 3744233 times)
Re: Show pictures of your very own Cal Lookers guys
Reply #1500 on:
September 27, 2010, 18:58:43 pm »
I finally have a (sorta) cal look engine in my 68
I build it months ago and never dare to start it as I feared to make something wrong and break it.
I put around 1.000km last month on it without any troubles. I still have some tune up to do on, but as summer is over, I'll do that during winter time.
It's just a very mild 1600cc with lightly ported heads, stainless steel valves, ~8.5cr, VZ14 cam, stock balanced crank and flywheel and a pair of Kadron.
It's a nice driver that is able to surprise some modern diesel car at stop light
Reply #1501 on:
September 27, 2010, 19:51:05 pm »
Cool JF ! And it's looking good too.
Reply #1502 on:
September 27, 2010, 20:14:04 pm »
I like that j-f.
Jim R.
Reply #1503 on:
September 27, 2010, 20:23:06 pm »
Thanks guy's.
I'm quite proud of it as it the first engine I completely build. Now I will see how long it will last.
lowfastbus
WUNDERWAFFE
Reply #1504 on:
September 27, 2010, 21:13:46 pm »
Picture taken at DDD8, on my way to a new PB off 13.21secs
Drove it over to Bitburg on saterday morning doing about 120km/h on the freeway.
Then did 3 passes on the Bitburg strip, drove back home on saterday evening and went to a party in it...
True streetcar
All this with a relatively small engine, completely stock gearbox and street tires.
I was happy about my weekend
http://dragvws.skynetblogs.be
WUNDERWAFFE
The Knuckle Buster
Reply #1505 on:
September 27, 2010, 21:50:50 pm »
yup, cool car jelle and congrats on the new PB! all you need now is some carpeting
j-f, nice engine, very similar to my brother's engine!! only he has a 100cc more.
good job!
DVK ~
Reply #1506 on:
September 28, 2010, 00:56:07 am »
Quote from: lowfastbus on September 27, 2010, 21:13:46 pm
True streetcar
yeah but have you changes the oil yet
Seriously though congrats dude
Reply #1507 on:
September 28, 2010, 01:30:14 am »
Sanitary engine bay.
Reply #1508 on:
September 28, 2010, 06:47:50 am »
Thanks again Mark and Did
it's far from a show car as all the engine bay paint is still original. I also need to sort some cosmetic issues as the rubber that seals engine bay, also original and well worn. But, as I said, I just want to enjoy by now before store it for winter.
CHR!S/DVK
Reply #1509 on:
September 28, 2010, 08:48:31 am »
Quote from: j-f on September 27, 2010, 18:58:43 pm
just like my brother said: that engine is just like what i am building, except for that i have 1679cc.
the engine looks really nice with the original filters and linkage! just like the stuff i have ready for assembly, oldschool dude!
i like the clean look of your engine bay as well! does the breather box run to both valve covers?
and distributor are you running?
what kind of valve springs and pushrods? that was a major consideration point because of the specs of the vz14.
i will be running dual springs and chromoly pushrods with my lightweight lifters, and had to enlarge the combustionchambers to keep the CR under 1:9
sorry for spoiling the topic..
Last Edit: September 28, 2010, 13:45:51 pm by CHR!S/DVK
Member of
DVK
- Der Vollgas Kreuzers
lowfastbus
WUNDERWAFFE
Reply #1510 on:
September 28, 2010, 10:16:58 am »
Quote from: monkiboy on September 28, 2010, 00:56:07 am
Changed the oil? Damn I knew I forgot something
Checked it when I arrived at Bitburg though, there seemed to be some in it, so everything was good to go and race!
Grtz,
Jelle
WUNDERWAFFE
The Knuckle Buster
Reply #1511 on:
September 28, 2010, 20:15:20 pm »
Quote from: CHR!S/DVK on September 28, 2010, 08:48:31 am
I have use hydraulic oil hose for the breather box and route them to the valve covers through the rear engine tin.
Distributor is a 009 with an Hot spark breakerless ignition kit. I know that it is recommended to use a SVDA vacuum dizzy with Kadron, but it works. I enlarge main jet to 60 to reduce flat spot.
Well, for valve springs, I use single HD with stock pushrods. I know that VZ serie has lot's of valve acceleration, but I follow the advice of the guy where I buy my stuff. He's a reknown engine builder in France (Loïc Charpentier for those who know him.).
heads are 1mm fly cut, deck height are 1.2mm. I have calculate a CR of 8.3, I write it somewhere but can't find my notebook.
Reply #1512 on:
September 28, 2010, 21:54:15 pm »
hey JF that engine looks good. all i want to add/change is the wiring and put that a bit nicer in the car. but if you have fun that is the most important part.
and speaking of fun. congrats Jelle, if i had know you went to a party, you could have borrowed the helmet for that as well
it is also a very good partyhelmet and attractionmagnet.
sofaking
Reply #1513 on:
November 08, 2010, 06:14:04 am »
Done.......
http://www.derblitzkriegkafers.com/
Dirk / DFL
Reply #1514 on:
November 08, 2010, 08:33:29 am »
Quote from: sofaking on November 08, 2010, 06:14:04 am
Done.......
Wow, everything red? Looks great!
Reply #1515 on:
November 08, 2010, 16:13:24 pm »
'Atta boy, Karl... lookin' GOOD!!
Stefan Rossi
Reply #1516 on:
November 08, 2010, 16:19:33 pm »
My 67 daily driver also
needs a clean but i use it every day...
took it to france the week after i finished it
Aircooled Engineering. Birmingham, England
www.ace-vw.com
Check us out on FB,
www.facebook.com/aircooledengineering
www.dtavw.com
'67 vert
'67 Chevelle PT106mm turbo
'66 Lincoln
The Action Is Go
Reply #1517 on:
November 09, 2010, 00:22:43 am »
Reply #1518 on:
November 09, 2010, 01:00:52 am »
My try at the look
The Action Is Go
Reply #1519 on:
November 09, 2010, 01:15:20 am »
Quote from: danny gabbard on November 09, 2010, 01:00:52 am
My try at the look
Decided on interior color?
Reply #1520 on:
November 09, 2010, 01:34:26 am »
It between red, grays or light brown, AHHHHHH-NO! It al depends on how nice or how close to original I can get on the door panels. I like the pressed beads in the TMI brand door panels. If I go that direction, Very few choices.
Reply #1521 on:
November 09, 2010, 01:59:56 am »
I vote for light gray or brown, Danny.
And to keep this thread on topic:
Reply #1522 on:
November 09, 2010, 02:28:20 am »
Ya, I am kinda leaning towards grey of some sort. Been looking at some grey wool material from some splitwindows I have seen or grey vinal tmi door panels and have lenny sew up and build the seats, I was very happy with lenny when he did my double cab a few years back.
Jason Foster
7.69 87mph 12.35 106 mph
Reply #1523 on:
November 09, 2010, 04:17:54 am »
Quote from: DKK_Fred on November 09, 2010, 01:59:56 am
UMMMM......SWEET!!!
low oval
Reply #1524 on:
November 09, 2010, 09:26:29 am »
Done.......
saw your car at Nick's, awesome job! especially liked the idiot lights, great job again.
jim
LuftsickTero
Reply #1525 on:
November 09, 2010, 10:31:19 am »
Quote from: danny gabbard on November 09, 2010, 02:28:20 am
Not sure about Split stuff but the dotted fabric found in late Ovals is my favourite in cloth materials:
Cal&Resto
| Publishing own mediocre Cal Look photos since 1995 in interwebs.
LuftsickTero
Reply #1526 on:
November 09, 2010, 10:35:30 am »
Also, I don't think off the shelf TMI stuff does justice to your own work/ideas in the car
Door panels don't get much more boring than the original '61-'65 gray panels which TMI is reproing. IMHO, the best vinyl interior is the '58/'59 style (if it has to be OEM-like).
Cal&Resto
Reply #1527 on:
November 09, 2010, 14:38:04 pm »
Quote from: LuftsickTero on November 09, 2010, 10:35:30 am
.... "I don't think off the shelf TMI stuff does justice to your own work/ideas in the car."
I agree!! I'm thinking beige/brown tones with Lotus White rather then grey, too. Save your bucks and go see Lenny. My $.02.
Reply #1528 on:
November 09, 2010, 18:07:25 pm »
Very nice stuff, Ya I have been thinking of the split type cloth or wool , Like the original. Last time in OC I ran out of time to get by lenny's to get some samples. Only thing is for sure is the rubber floor mat's . so that will direct the color a little bit. I have gray, But will get some type of light brown ones if I can find. Thanks again for any input.
Reply #1529 on:
November 10, 2010, 01:30:11 am »
Quote from: Jason Foster on November 09, 2010, 04:17:54 am
UMMMM......SWEET!!!
Thanks, Jason.
50
51
52
53
92
