October 12, 2026, 15:53:10 pm
Show pictures of your very own Cal Lookers guys
5
6
7
8
92
Topic: Show pictures of your very own Cal Lookers guys (Read 3713677 times)
Peter Roberts
Re: Show pictures of your very own Cal Lookers guys
Reply #150 on:
October 04, 2006, 20:44:34 pm »
Quote from: BeetleBug on October 04, 2006, 20:21:26 pm
220+ hp is pretty neat! Are you using the CNC version as a base and add a little fluff`n buff? And which springs have you used?
Thank you for sharing, it`s always interesting to read about other people engines.
I am using the CNC version , and am aware that they do not flow as well as they should out of the box , so I have done a lot of chamber and port matching work , which will improve things hopefully .
The heads came with the CB springs , I may go up to K-motions , but may run the CB springs to start with . I have found that the valve seats settle a lot after some use , so we will be having the heads off after some run time , and assessing the situation .
It should be a Ripper for sure .
Denis Spencer's 67...
Last Edit: October 04, 2006, 21:05:11 pm by Peter Roberts
Reply #151 on:
October 04, 2006, 21:04:07 pm »
Damn... where are you guys getting those '67 'vert deck lids?
I'd kill for one!
Peter Roberts
Reply #152 on:
October 04, 2006, 21:32:20 pm »
James Dore's 61...
New motor going in now , 2276 44x37.5 Wedgeport Head ( Longer valves 1 3/8" Springs )
CB 2289 ( FK87 )
11 to 1 Compression
Last Edit: October 04, 2006, 21:46:39 pm by Peter Roberts
Reply #153 on:
October 04, 2006, 21:38:41 pm »
Yes there is for sure some discussions going on the flow # of those CE heads, 270 something according to the homepage is far from the truth.
Have you used the special split Scat #1 bearing with the flange crank? Will the engine be used on the street?
Peter Roberts
Reply #154 on:
October 04, 2006, 21:43:32 pm »
Oh yes , all our cars are street , that's what Cal-Look is about , no race cars please .
The bearings have come from VW Speedshop , I think they are BugPack ones , I have used them before with no problems .
67Screamer
Reply #155 on:
October 04, 2006, 21:48:17 pm »
Quote from: Peter Roberts on October 04, 2006, 15:03:07 pm
Thanks very much
Reply #156 on:
October 04, 2006, 21:54:25 pm »
Quote from: Peter Roberts on October 04, 2006, 21:43:32 pm
Wow, a flange crank in a street engine - how cool is that!! And this is not even the first one if I understand you correctly? Does the bearing cope well with the extra wear?
Hmmmm, maybe I will try a flange crank instead of a wedged one on my next engine
Tim C
Reply #157 on:
October 04, 2006, 21:55:12 pm »
Where's Wally in the photo above...
I spy Max, Simon and Roberts online....
Evening...
JG54 Greenhearts
Roman
Reply #158 on:
October 04, 2006, 22:39:40 pm »
What has happened to the tan -55 that one of you guys bought from my friend Otto? Is it a looker yet?
Reply #159 on:
October 05, 2006, 10:33:03 am »
Quote from: Peter Roberts on October 04, 2006, 20:44:34 pm
Now, i can dig this as a 67 owner with towel rails
Nice one! What engine does he have? Stock?
P.s. but tell denis to get chrome bolts for the front wheels as well
Last Edit: October 05, 2006, 10:36:58 am by 67-indeed
DVK ~
Peter Roberts
Reply #160 on:
October 05, 2006, 11:37:21 am »
Quote from: BeetleBug on October 04, 2006, 21:54:25 pm
I have one other customer running one on the street , and Paul Hamilton at VWSpeedshop , has one in his 12.5 second Bay window panel , that he drives 100 miles to York raceway , runs mid 12's all day , then drives home .
I think the trick is to not hang about at all on the clutch , shift as quick as possible to minimise wear on the thrust surface .
We only go over to the flange cranks , for M&H treads or slicks .
Peter Roberts
Reply #161 on:
October 05, 2006, 11:38:54 am »
Quote from: Roman on October 04, 2006, 22:39:40 pm
It's coming in to the workshop very shortly , I had hoped to be into it by now , but the work is stacked up against me , fortunately I have a friend helping me now , so we can gradually catch up .
I'll post pic's as it goes .
Peter Roberts
Reply #162 on:
October 05, 2006, 11:41:05 am »
Quote from: 67-indeed on October 05, 2006, 10:33:03 am
It has a stock 1500 at the moment , but is having the 1835 motor out of the Coral 54 Rag , when his new 2276 IDA motor goes in . I am waiting for the gearbox for the Coral rag , before I can do that , so it's holding things up a little , but we have plenty of other work to do .
Reply #163 on:
October 05, 2006, 12:32:59 pm »
Quote from: Peter Roberts on October 05, 2006, 11:37:21 am
Soooo easy to say - so hard to do
Will any of the beatiful looking lookers on the pics be attending the Sunset Bracket & German Car Day at Shakespeare County Raceway in October? I`m coming over and was hoping to see as many nice cars as possible....
BB
Peter Roberts
Reply #164 on:
October 05, 2006, 13:08:19 pm »
I didn't even know about that one , maybe if the weather is ok .
Some more club cars ( although the Heb has now been sold ) ...
Max'x Cab with 2110 IDA motor...
Winter wheels ...
Summer wheels...
Street Eliminators ( 42x37.5 )
Last Edit: October 05, 2006, 14:34:53 pm by Peter Roberts
Turtle001
Reply #165 on:
October 05, 2006, 13:42:59 pm »
fingerlickin
http://turtle.skynetblogs.be
Peter Roberts
Reply #166 on:
October 05, 2006, 15:14:02 pm »
Max's 2110 on running stand...
I dynamatted the engine bay , to make a quiet ( ish ) ride for Max...
Last Edit: October 05, 2006, 15:18:51 pm by Peter Roberts
eh
Reply #167 on:
October 05, 2006, 15:39:06 pm »
Here 's my first post..
62 ragtop from Bangkok,Thailand..
Tim C
Reply #168 on:
October 05, 2006, 15:43:38 pm »
Cool car eh, great to see lookers from other parts of the world.
JG54 Greenhearts
eh
Reply #169 on:
October 05, 2006, 16:19:01 pm »
Thanks Tim..
My English is very poor..
My green 62 with Flat4 rims..
Front & rear tyres , Nankang 135/15 , Bridgestone 215/65/15..
Superior formula vee , steering wheel and shifter..
Inside , I've keep in stock look..
Last Edit: October 05, 2006, 16:46:37 pm by eh
Reply #170 on:
October 05, 2006, 16:22:31 pm »
greenhearts, i really envy you for your fingerlicking engines and luxury of choice between fuchs and gasburners
DVK ~
eh
Reply #171 on:
October 05, 2006, 16:45:00 pm »
For the engine ..
1600 cc. 8.2 : 1CR. with Empi Speedwell sprint kit..
Ported & polished s/p heads w/ 39*32 mm...
Engle W130 camshaft..
Bosch 010 dist with blue coil..
1 3/8 custom Stainless dual queit pack..
Reply #172 on:
October 05, 2006, 16:52:49 pm »
Quote from: eh on October 05, 2006, 16:45:00 pm
For the engine ..
Great sprint kit! Gotta love that old speed!
But a W130 cam? Wow! Don't you get off cam all the time? And then you have to shift back?
DVK ~
eh
Reply #173 on:
October 05, 2006, 17:10:23 pm »
Hi 67-indeed,
I'll get W130 off for the future..
It's 1400 rpm idle speed , too high..
My new project is 2332 FK87 & s/e heads..
Now I'm waiting for new CB case..
eh
Reply #174 on:
October 05, 2006, 17:23:22 pm »
More pictures..
Bangkok cruise night, 21 .09 .2006..
Our new Bangkok airport " SUVARNABHUMI AIRPORT"..
Last Edit: October 05, 2006, 17:31:54 pm by eh
Peter Roberts
Reply #175 on:
October 05, 2006, 17:36:20 pm »
Some shot's from our club photoshoot...
Last Edit: October 05, 2006, 17:54:19 pm by Peter Roberts
Peter Roberts
Reply #176 on:
October 05, 2006, 18:14:06 pm »
Me ,l warming Neal's tyres a little...
Last Edit: October 05, 2006, 18:44:57 pm by Peter Roberts
Peter Roberts
Reply #177 on:
October 05, 2006, 18:43:39 pm »
James warming his tyres a lot...
Last Edit: October 05, 2006, 20:34:45 pm by Peter Roberts
Reply #178 on:
October 05, 2006, 19:05:41 pm »
enough with the porn, it's turning into a show off now
just kidding
your cars look fab! you should consider fabricating a book of your club, seriously!! have you?
p.s. the burn out pics of the oval look wicked, reminds me of some vid of 2332cc oval rippin the streets that used to be online on cal-look.COM
DVK ~
Engine Builder
Reply #179 on:
October 05, 2006, 19:10:51 pm »
Ok you have lost me you do not know what make are the bearings. I think they are BugPack because you have used them before. If i was to take $5000+ for a motor that i was putting together for someone. They would get a list of all the parts used lets see (what bearings do i have in my motor). (Dont know but they are ok i have used them before) ok can i have my money back now.
5
6
7
8
92
