September 24, 2026, 03:30:10 am
| | |-+  Advantages of MSD ignition?
Pages: 1 [2] Print
Author Topic: Advantages of MSD ignition?  (Read 39707 times)
dth
« Reply #30 on: February 14, 2017, 21:25:25 pm »
Iv had this in the past with different set ups , all iv ever done is pull the plugs and either replace them or clean them and
it,ll fire right up , always after sitting for prolonged period over the winter .
« Reply #31 on: February 14, 2017, 21:50:12 pm »
Hi Donald,
Glad I am not the only one. When it's happened before fresh plugs has solved it as you describe but there has to be more to it than that surely? As I'm sure you can appreciate its a ball ache getting plugs out in an oval!
Lee
dangerous
« Reply #32 on: February 14, 2017, 23:13:53 pm »
These two most recent replies above are what I feel.
Keep it simple.
Always do your basics first before complicating basic fault finding.
As much as I love my MSD, if it fixes the problem, you probably had an underlying issue.
« Reply #33 on: February 14, 2017, 23:42:56 pm »
Completely agree, I want to keep my msd for the new race motor. But essentially I am running out of options to check. I still believe I lack voltage to the coil but have checked all the wiring and nothing obviously wrong. I also don't believe I shouldn't be able to leave it for a bit without running, then have to pull plugs to get it to start. My 1776cc in my 63 bug goes for months sometimes, then fires up.
But it's a lot milder in terms of spec.
Stumped to be honest
Lee
pupjoint
« Reply #34 on: February 15, 2017, 01:18:32 am »
Do you have Fred's reply, I'd be interested.
  thanks,
Andrew
pm me your email
RichardinNZ
« Reply #35 on: February 16, 2017, 06:17:34 am »
I see the Winterburn can be 6 volt, but does anyone know any other 6 volt options?  Thanks
Sent from my SM-N920I using Tapatalk
'58 Bug; NZ assembled
Dual Carb 36hp
Andrew
« Reply #36 on: February 17, 2017, 19:43:39 pm »
Not that I'm currently aware of.
I imagine, historically speaking, Winterburn had to cater for 6volt ignitions as well as 12volt, after all his patent is mid 60's and was granted in 71. One assumes he started work well before that, so plenty of 6 volt cars and probably other stuff like aero about then that might have been non-12v.
Looking at the circuit there's nothing on there that says "12v", if you see what I mean?
In fact, if your battery was in good condition then  the 'coils' on the Winterburn design could be wound in such a way that it would be as good as a 12v ignition, you just need to draw twice as much current on the primaries to get the same spark.
Andrew
RichardinNZ
« Reply #37 on: February 18, 2017, 20:53:15 pm »
Andrew
Thanks.
Yes it's the only option I can see too. I think I'll get the Winterburn in time....
I have a well behaved 6v system and good (optima) battery so as you say ultimately it could be as good as a 12v ignition system...if only I could expect the same from the headlights.
Dual Carb 36hp
« Reply #38 on: February 19, 2017, 01:23:07 am »
....if only I could expect the same from the headlights.
http://www.classicandvintagebulbs.com.
RichardinNZ
« Reply #39 on: February 19, 2017, 20:00:31 pm »
Thanks for the link!
Dual Carb 36hp
« Reply #40 on: April 02, 2017, 13:42:05 pm »
Just to deepen the mystery, it started on the button today. Have done/changed NOTHING!!
I give up with cars  Cheesy
DaveN
« Reply #41 on: April 02, 2017, 14:37:05 pm »
so no advantages then?  Grin
« Reply #42 on: April 02, 2017, 16:33:05 pm »
Made my day when it fired! Wished I could have gone out for a drive but I had no front wheel studs!
Lee
« Last Edit: April 02, 2017, 17:28:01 pm by leec » Logged
Andrew
« Reply #43 on: April 02, 2017, 17:30:42 pm »
Could it be moisture/damp related? Been a bit drier in the UK of late....
« Reply #44 on: April 02, 2017, 17:46:23 pm »
Exactly what dad and I thought. Certainly has warmed up recently as our new house (project) has no heating. Any positive temp change is noticed at the moment  Grin
Pages: 1 [2] Print
