September 24, 2026, 06:44:32 am
Technical stuff
Pistons: Hypereutectic or forged
Topic: Pistons: Hypereutectic or forged (Read 14346 times)
Mike Cott
March 12, 2017, 22:29:23 pm »
what are the pros and cons of each option
Forged double the costs are they worth it?
Re: Pistons: Hypereutectic or forged
March 12, 2017, 23:21:31 pm »
Forged can take more abuse.
fish
March 17, 2017, 11:07:28 am »
I've heard arguments for and against both, having spoken to a very good, big HP drag engine builder creating massive Chev engines. He uses both "forged" and "hypereutectic" for different requirements and recons hypers can handle 1.5 - 2 HP per cubic inch easilly.
There is more to just the process of manufacturing and materials used.
Weight, pin height, skirt design, friction coating, heat treatment, engine set up, rpm, ignition timing, rod ratio, piston speed and many more factors come into choosing the right piston. For a streeter both will work.
Mike Cott
March 17, 2017, 12:02:16 pm »
Thanks for info there fish, I think I'll try the hypers can upgrade whenever.
March 24, 2017, 20:44:03 pm »
Only use forged on high perf . engines
www.Udobeckertuning.de
Mike Cott
March 24, 2017, 20:59:58 pm »
Udo, would you class a 94x76 as a performance engine?? I suppose it depends on what I put on it really
March 25, 2017, 20:03:00 pm »
Quote from: Mike Cott on March 24, 2017, 20:59:58 pm
Really? I wouldn't classify it as stock.
benlawrence
March 25, 2017, 22:55:48 pm »
I think udo means " High " performance, big rpm big compression motors ( or force fed ), ive run AA hypers for 5 years now and beat the sh*t out of them, i run the car hard, 8k+ rpm always shows up on the tach recall
for a 200 hp street car theres no need to go forged ( imo )
Last Edit: March 25, 2017, 23:02:19 pm by benlawrence
March 25, 2017, 22:56:35 pm »
I prefer cast or hypers for their low thermal expansion and weight, but my engines usually don't rev past 7 and I tend to keep any boost under 1 Bar usually, so I haven't found the need for forged on my street stuff for any of my toys, ACVW or otherwise.
Mike Cott
March 26, 2017, 09:35:42 am »
Thanks Ben and Modrod, this info is what I was looking for. On bens recommendation think I'll go the Hypers for now it's not a really big performance engine is turboed etc certainly not stock tho Zac
March 29, 2017, 15:20:10 pm »
Yes definitly high performance
