September 24, 2026, 23:30:18 pm
| | |-+  Keeping a "Type1" swingaxle case alive..?
Author Topic: Keeping a "Type1" swingaxle case alive..?  (Read 12811 times)
« on: August 20, 2017, 19:54:24 pm »
Is there a good thread out there?
Alunimium house I presume..
Big or small gussets?
Steel plates and bolts to hold the side plates?
Help wanted.. Snapped a gearbox in two..
« Last Edit: August 20, 2017, 22:28:25 pm by Erlend / bug66 » Logged
numbnuts
« Reply #1 on: August 20, 2017, 23:10:46 pm »
Wow that's some breakage Shocked
Been reading up on t2 boxes as they are stronger. What is the set up of the car?
2854cc 1956 cal looker coming to this space shortly
« Reply #2 on: August 21, 2017, 14:36:22 pm »
Let's see.
Full weight 67 bug.
400whp / 535nm to the wheels.
Stage 4 + black magic
hydraulic clutch management
KCR built box on gusseted mag case, full weddle internals included what was an Weddle R&P...
Rhino case and bolted sideplates next..
« Reply #3 on: August 21, 2017, 17:36:30 pm »
Might be time to step up to a bus box. I'm sure Richie will be along shortly, but he was in a similar place back in the early '00's and he did a box virtually identical to yours.
It does mean IRS, but thats no bad thing really!
« Reply #4 on: August 22, 2017, 12:57:12 pm »
For this you need a bus box with folts or rancho axles. We just got one from rancho. Complete with IRS to swing axles
« Reply #5 on: August 22, 2017, 13:24:27 pm »
Does Folts axles handle 400-500 ft.lbs to the tires and sub 1,4 60-foot times?
« Reply #6 on: August 22, 2017, 13:27:59 pm »
And I've got a lot of swingaxle spares, so not really keen on going IRS..
« Reply #7 on: August 23, 2017, 09:28:19 am »
New main gearbox will now be:
White Rhino main house
Weddle/Mendeola gear carrier housing + nosecone
Paul Guard diff
full Weddle race gear stack
Hopefully a Weddle R&P
Full circle sideplates with through bolt
Gearbox girdle/cradle thingy..
 Smiley
Dougy Dee
« Reply #8 on: August 23, 2017, 14:35:39 pm »
What were you using to control ring & pinion movement?
« Reply #9 on: August 23, 2017, 14:48:30 pm »
What do you mean? Gusseted mag case. But that did not hold..
« Reply #10 on: August 24, 2017, 06:25:49 am »
Paul Guard diff
 Smiley
You should use another clutch with this ...
« Reply #11 on: August 24, 2017, 06:53:19 am »
Paul Guard diff
 Smiley
As in what type?
« Reply #12 on: August 25, 2017, 13:19:13 pm »
Is there such a thing available as a staged lock-up clutch (like on my bike......  http://www.mtceng.com/index.php/technical-information/7-clutch-differences  )?
NoBars
« Reply #13 on: September 02, 2017, 01:22:39 am »
Rev6. It's actually more similar to a gen2 multistage than a lockup or multistage  as the weights are on the engine side of the clutch, not the input shaft side.
gkeeton@zbzoom.net
« Reply #14 on: September 03, 2017, 04:23:07 am »
http://www.shoptalkforums.com/viewtopic.php?f=50&t=89944&start=45
