November 15, 2026, 19:37:28 pm
352349 Posts in 28966 Topics by 6931 Members
| | |-+  Clutch cable arm
Author Topic: Clutch cable arm  (Read 8618 times)
Garrick Clark
« on: May 03, 2018, 19:57:15 pm »
So. I've got a couple of gearboxes with NEW clutch cross shafts and cable arms, the cross shafts and the arms have splines and only fit 1 way, When the cable arms are fitted to the cross shafts they are not a good fit, They wiggle about. I'm using a stage 2 Pressure plate, I think after some use the arm could start to spin on the cross shaft.
Anyone else seen this.
What's the solution, put a little high heat spot weld on it.
Thanks.
Air cooled Engine builder
« Reply #1 on: May 04, 2018, 08:57:15 am »
With clean genuine VW parts, the fit is a bit loose.  The fit is only tight if the parts start to rust together.
If you have an aftermarket cross shaft, it might be on the small side.  Can you measure it and compare to the original one?
Erlend / bug66
Global Moderator
SCC Event
« Reply #2 on: May 04, 2018, 19:56:35 pm »
I spot welded mine. Shortened arm with stage 4..
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
Garrick Clark
« Reply #3 on: May 04, 2018, 20:23:39 pm »
Hey thanks guys, seeing as I have 2 boxes both with new shafts and arms and both are wobbly I recon its a production flaw, think I'll  do a little weld on it. Those 3 or 4 splines are no way strong enough.
« Reply #4 on: May 05, 2018, 23:45:04 pm »
You're solving a problem that doesn't exist.
