July 22, 2026, 03:57:01 am
Technical stuff
BMW conversion bearings
Topic: BMW conversion bearings (Read 6780 times)
July 16, 2018, 22:35:25 pm »
Hi guys,
Quick question. I know people are using BMW bearings to run a type 4 journal crank in a standard line bore type 1 case.
Are these bearings available for a type 4 mains crank that has had a grind to first undersized?
dragvw2180
Re: BMW conversion bearings
July 17, 2018, 00:34:59 am »
They do not make them for the O/D but do make them for the I/D of the bearings from what I have seen. Mike
UltraOrange67-2443
July 17, 2018, 09:10:21 am »
I got some spare ones in standard size from King Bearing.
I will check the part number and you could ask the supplier about it.
You also need to narrow the bearing.
Cheers, Nick
1967 1200 2920cc EFI
July 17, 2018, 09:33:17 am »
Quote from: dragvw2180 on July 17, 2018, 00:34:59 am
Inside diameter would be crank size?
Last Edit: July 17, 2018, 09:39:04 am by leec
Tufty65
July 17, 2018, 22:38:56 pm »
Loads on eBay, bmw m30 bearings, from .25mm oversize bearing up to .75mm (for .25mm to .75mm undersized crank)
Need to narrow them tho as said.
Outlaw Flat Four 35
12.64 @ 106.25mph
UltraOrange67-2443
July 23, 2018, 15:07:22 pm »
Don't forget to add the notch for the Bearing tang!
That thrust Bearing are you using?
July 23, 2018, 17:36:35 pm »
I haven't got that far with this yet. I have bought the crank now and will wait for it to arrive and go from there
bedjo78
July 24, 2018, 05:27:02 am »
How about Crysler bearings ? Are they have outer oversize main ?
Last Edit: July 24, 2018, 06:53:50 am by bedjo78
