October 12, 2026, 07:00:48 am
Project CFC#1, turbo, back halfed and light
5
Topic: Project CFC#1, turbo, back halfed and light (Read 142676 times)
Erlend / bug66
Global Moderator
SCC Event
Re: Project CFC#1, turbo, back halfed and light
Reply #90 on:
February 18, 2019, 22:05:29 pm »
Quote from: richie on February 18, 2019, 21:29:30 pm
With all that room you have over trans now seems stupid to not move turbo forward anyway to help with weight distribution
I know. Need to flip the centre in the IC then also, but should be easy enough..
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
Erlend / bug66
Global Moderator
SCC Event
Reply #91 on:
February 27, 2019, 22:17:23 pm »
More bars done from the Swedish wizard!
The '67:
The '59:
Not yet..
dragvw2180
Reply #92 on:
February 28, 2019, 05:11:46 am »
I really like what you have done with your chassis except using the torsion housing . Like Richie said shedding that would reduce some weight . I am working on my car right now, a 66 bug , back halved with ladder bars and a swingaxle . I cut mine off about an inch behind my ladder bar mount pipes. I plan to run everything inside my hollowed out tunnel, lines and wiring . Great work , keep it up, Mike McCarthy
Erlend / bug66
Global Moderator
SCC Event
Reply #93 on:
February 28, 2019, 07:31:34 am »
Quote from: dragvw2180 on February 28, 2019, 05:11:46 am
Look again
It’s not cut all the way yet.
The '67:
The '59:
Not yet..
Erlend / bug66
Global Moderator
SCC Event
Reply #94 on:
February 28, 2019, 13:04:54 pm »
Quote from: Erlend / bug66 on February 28, 2019, 07:31:34 am
Look again
Or did you actually mean the frame forks?
The '67:
The '59:
Not yet..
dragvw2180
Reply #95 on:
February 28, 2019, 22:25:41 pm »
exactly . I also raised mine 3.5 inches .
Erlend / bug66
Global Moderator
SCC Event
Reply #96 on:
March 01, 2019, 12:05:21 pm »
Quote from: dragvw2180 on February 28, 2019, 22:25:41 pm
Cost and time wise it was easier to just make 3 inch raised mounts.
Transmission is raised 3 inches
The '67:
The '59:
Not yet..
Reply #97 on:
March 03, 2019, 07:26:06 am »
Beautiful Work!!
http://selvedgeyard.com/
Erlend / bug66
Global Moderator
SCC Event
Reply #98 on:
March 04, 2019, 18:31:19 pm »
More done
The '67:
The '59:
Not yet..
Erlend / bug66
Global Moderator
SCC Event
Reply #99 on:
March 04, 2019, 18:32:43 pm »
The '67:
The '59:
Not yet..
Reply #100 on:
March 04, 2019, 18:53:45 pm »
Looking at pics of rear end, a pair of motor plates would attach easily then you could lose the frame horns
Erlend / bug66
Global Moderator
SCC Event
Reply #101 on:
March 04, 2019, 19:21:35 pm »
Quote from: leec on March 04, 2019, 18:53:45 pm
Yes, but then I would need new motor plates and placement of the new motor plates if I need a Mendy in the future
I think I'll stick to this plan for the time being. It will be a lot better than what I had..
The '67:
The '59:
Not yet..
Reply #102 on:
March 06, 2019, 04:09:58 am »
Looks very nice!
Are the rear coilovers going to mount to the bars across the top of the gearbox?
Is that a likely spot?
Erlend / bug66
Global Moderator
SCC Event
Reply #103 on:
March 06, 2019, 08:50:01 am »
Quote from: modnrod on March 06, 2019, 04:09:58 am
Looks very nice!
It will get some bars to the top mount. Not 100% where it will be in the pictures, but the math is done, and cage builder has angles and lengths to build from.
Some sort of triangulated top mount
The '67:
The '59:
Not yet..
Erlend / bug66
Global Moderator
SCC Event
Reply #104 on:
March 09, 2019, 13:12:14 pm »
And the «D-bars» for a pan car
The '67:
The '59:
Not yet..
PPRMicke
Reply #105 on:
March 09, 2019, 13:32:50 pm »
Det blir bra när Ola tillverkar
/// M
Erlend / bug66
Global Moderator
SCC Event
Reply #106 on:
March 13, 2019, 08:36:14 am »
Quote from: PPRMicke on March 09, 2019, 13:32:50 pm
/// M
Yes! Really good so far. Can't wait to get it back to Norway and start on the rest
The '67:
The '59:
Not yet..
Erlend / bug66
Global Moderator
SCC Event
Reply #107 on:
March 26, 2019, 18:27:48 pm »
Planning to pick up the car on the 13th of April. Can’t wait.
It will need a few patches of new metal in the body before I start on the rest
The '67:
The '59:
Not yet..
Erlend / bug66
Global Moderator
SCC Event
Reply #108 on:
April 13, 2019, 17:44:23 pm »
Hello there
The '67:
The '59:
Not yet..
Reply #109 on:
April 13, 2019, 18:03:33 pm »
Nice
Erlend / bug66
Global Moderator
SCC Event
Reply #110 on:
April 15, 2019, 07:28:44 am »
I might need a new jack. A low one
The '67:
The '59:
Not yet..
Erlend / bug66
Global Moderator
SCC Event
Reply #111 on:
April 15, 2019, 20:48:23 pm »
Having a beer and drawing up the wheel/tire combo.
Have 11,5’’ of room behind the fender.
Going Hoosier 9.5 DOT tires on a 8’’ rim I think. But need to remeasure again before ordering
The '67:
The '59:
Not yet..
UltraOrange67-2443
Reply #112 on:
April 16, 2019, 21:41:49 pm »
Measure twice, order wheels once
1967 1200 2920cc EFI
Erlend / bug66
Global Moderator
SCC Event
Reply #113 on:
April 17, 2019, 14:46:28 pm »
Did a mockup with brakes yesterday. 8’’ rims with 3,5” backspace will do the trick. I have 9,5” Hoosier dot slicks lying around, but I’ll have room for 11,5” slicks also. The Hoosier DOT slicks are measured at the sidewall.
Brakes are ordered. Wheels and tires will be ordered ASAP
The '67:
The '59:
Not yet..
Erlend / bug66
Global Moderator
SCC Event
Reply #114 on:
April 22, 2019, 18:41:40 pm »
While waiting for parts, one can only tinker with other stuff.
Longblock is back together. Need to re-gasket the transmission, before I swap that in to the car.
Then engine and the start of the new exhaust and intake
The '67:
The '59:
Not yet..
Erlend / bug66
Global Moderator
SCC Event
Reply #115 on:
May 01, 2019, 20:25:44 pm »
Too tall throttle bodies
Solution
Need some more welding and porting
The new plenum placement
Last Edit: May 02, 2019, 11:02:38 am by Erlend / bug66
The '67:
The '59:
Not yet..
Erlend / bug66
Global Moderator
SCC Event
Reply #116 on:
May 09, 2019, 07:53:36 am »
Both manifolds are welded together.
Needed some added material for porting.
This aluminium sucks(!) pretty easy to weld, but dirty as hell
The '67:
The '59:
Not yet..
Trond Dahl
Reply #117 on:
May 09, 2019, 09:29:16 am »
contamination, clean it with acid after welding :-)
Race car 9.49/236kmt@SCC 2017
Erlend / bug66
Global Moderator
SCC Event
Reply #118 on:
May 09, 2019, 09:33:27 am »
Quote from: Trond Dahl on May 09, 2019, 09:29:16 am
It pulled so much junk up from the aluminium when welding. And it's pourus also.
1 runner done, 3 to go.
The '67:
The '59:
Not yet..
mikko k
Reply #119 on:
May 09, 2019, 12:04:46 pm »
Last Edit: January 19, 2020, 23:49:04 pm by mikko k
5
