October 15, 2026, 05:38:14 am
one piece window seals
Topic: one piece window seals (Read 16805 times)
beatnik beetle
July 23, 2018, 14:20:23 pm »
Sorry if this subject has been raised before but, where can you buy nice 1 piece window scrapers these days?...seems like the nice ones where you put the ali rods in the end to help them curl up at the ends are no longer available..I could really do with a set if anyone has any or knows where to get them
Thanks Lounge folk
Simon
RobtheManx
Re: one piece window seals
July 23, 2018, 20:42:39 pm »
https://www.woolies-trim.co.uk/product/1259/window-weatherstrip
https://www.woolies-trim.co.uk/product/1734/window-weatherstrip
Thats what I used . I used the larger one on the inside , smaller one bonded to black painted stock aluminium trim on the outside . I had to pie cut the ends to make them curl up , and trim the top part so it tapered out , but worked really well . They're made of plastic and rubber , so fore flexible than steel lined ones , and won't rust . I bonded them to the door with tiger seal , just scratched up the smooth plastic surface first .
Good smooth felt on the inside helps the glass rum smooth .
Also , their window channel is a million times better than the crap you used to get with one piece window kits .
I'll try post some pics of my results .
Rob
beatnik beetle
July 24, 2018, 09:16:07 am »
cheers Rob I will look into it...
RobtheManx
August 02, 2018, 21:12:43 pm »
One piece window seals
RobtheManx
August 02, 2018, 21:20:48 pm »
It was a pain in the arse job , but the seals hold the glass really tight , so way less rattle , and they roll up and down as smooth as a stock window .
Also from woolies , I got a pair of leather vintage car check straps . much better than those awful cable things .
Cheers , rob
August 04, 2018, 08:16:02 am »
Really nice work there Rob.
beatnik beetle
September 14, 2018, 12:16:19 pm »
Well guys..I managed to find that Vee Wee ( G.S & F) sell them over here ..they came from Empi..so I'll keep you posted how it goes....thanks for the help Lounge folk x
fish
September 17, 2018, 14:58:01 pm »
Following, let us know how it works out
Martin S.
September 18, 2018, 20:19:54 pm »
Quote from: RobtheManx on August 02, 2018, 21:20:48 pm
Cheers , rob
Can I see a pic of the check straps please?
Straight Time
October 02, 2018, 09:14:19 am »
Nice work Rob. Great info. Thanks for sharing.
No retreat, No surrender !
Tourist
October 14, 2019, 20:46:26 pm »
Quote from: RobtheManx on July 23, 2018, 20:42:39 pm
Rob
Good evening Rob,
I hope that you do not mind me asking (I know this probably quite an old topic now), but which of the Woolies window channels did you use?
There are few ones listed and am not sure which to go for....
Any help/further information greatly appreciated
Thank you in advance,
Martin
RobtheManx
October 18, 2019, 22:35:47 pm »
Hi Martin , I used this one . great quality .
https://www.woolies-trim.co.uk/product/1023/flexible-window-channel
cheers , Rob
RobtheManx
October 18, 2019, 22:36:20 pm »
Quote from: Martin S. on September 18, 2018, 20:19:54 pm
Cheers , rob
OK i'll get a pic this weekend
Tourist
October 21, 2019, 12:11:57 pm »
Quote from: RobtheManx on October 18, 2019, 22:35:47 pm
cheers , Rob
Good afternoon Rob
Thank you
All the best,
Martin
VWGlassee
November 26, 2019, 00:15:48 am »
I also used the woolies window seals. Grear great quality!
I used the large ones on the inside and outside
Yannick
RobtheManx
November 26, 2019, 20:39:45 pm »
Awesome ! looks great .
Rob
VWGlassee
November 26, 2019, 23:20:57 pm »
Quote from: RobtheManx on November 26, 2019, 20:39:45 pm
Rob
Thanks for tip Rob.
The large seal on the inside and outside was the perfect solution
Yannick
