September 22, 2026, 03:39:23 am
| | |-+  guided or non guided trow-out bearing?
Author Topic: guided or non guided trow-out bearing?  (Read 5402 times)
« on: September 23, 2018, 10:12:52 am »
I ask this as a newer box I have has been installed with a non guided bearing and it got me thinking what would be best. what are the pros and cons?
« Reply #1 on: September 23, 2018, 23:46:15 pm »
Guided, never have to worry about clips coming off and bearing dropping into clutch, VW made improvements for a reason Wink
Iryanu
« Reply #2 on: September 24, 2018, 18:32:04 pm »
This x1000
If you've ever had a release bearing drop off the clips after wrestling the engine in and starting it up. I had one drop twice before it held. The "high strength" clips are bobbins too. Guided all the way.
« Reply #3 on: September 29, 2018, 12:01:57 pm »
I suspected it. but as this box has the guide removed and a non guided bearing fitted I found it curious... hence the question.
