September 22, 2026, 09:51:39 am
| | |-+  Clearancing case for stroker crank
Author Topic: Clearancing case for stroker crank  (Read 11255 times)
Endre D
« on: October 17, 2007, 12:00:38 pm »
Hi Guys,
Does anybody know of a good guide on how to clearance an engine case for a stroker crank? The crank in question is 84mm stroke with chevy journals and is going into a new AS41 mexico case. Any tips on proper tools and procedures would be appreciated!  Smiley
benssp
www.callookvw.com
« Reply #1 on: October 17, 2007, 12:42:34 pm »
http://www.shoptalkforums.com/viewtopic.php?t=102663   it's a stick, so i guess it gets asked alot Grin
www.vwheritage.com  My Job
YMCA
« Reply #2 on: October 17, 2007, 13:18:48 pm »
Hi Guys,
Send it out and have it Clearenced you will be glad you did There are alot of places to clearence on that big of stroke you dont want to screw up a New Case by grinding it to thin in places  most VW machine shops have a setup already made up the clearence a case it dose not ost that much to do and is well worth it. just my 2 cents  Grin Grin
« Reply #3 on: October 17, 2007, 13:59:31 pm »
Hi Guys,
Usually that would have been my answer as well if it was not for the fact that Endre lives on the West Coast of Norway where there is no machine shops. Yes he could pack it and send it to the US but I do believe he is on a thight budget and on top of that he would like to learn how to do things. Endre, what about asking EBB and Ungdommens Motorsenter? They do have quite a impressive machine park and EBB sure nows alot about VW`s. Or you could also send it to JPM and he can do it for you if you do not wish to attack the case yourselves looking at pictures. There is also some very good engine builders here on The Lounge and it would be nice if they could post some comments or even better, some pictures.
Best rgs
BB
Endre D
« Reply #4 on: October 17, 2007, 14:26:03 pm »
Hi Guys,
Best rgs
BB
Thanks Kalle. You're absolutely right, no good machine shops around. I actually had a long chat with EBB yesterday, but he's very busy these days and could'nt make any promises on a timeframe for this work. (The good thing is that he can do dynamic balancing of my rotating assembly on short notice Smiley ). Like you said, I would really like to learn how to do most things myself (and my budget that used to be so fat is getting skinny...), so it's the "tips of the trade" I'm hoping for. Any, and I mean ANY, other tips on engine building in general is greatly appreciated.
Cheers, Endre
Trond Dahl
« Reply #5 on: October 17, 2007, 18:34:08 pm »
Endre, how about if you find a ruined old case, and use that to make a practice run on. Then you can make your own recipie without ruining a $550 case.
Alternatively put the case for sale on vw2you and order a new one from vwparts where I got the other one (rimco machine work) with all the specs you need. I'm sure you will get the same for it as you paied.
If you can break even with a sale, It will probably be both faster and cheaper then waiting for EBB to do the job. I'm sure Rimco will do a good enough job for you :-)
« Last Edit: October 17, 2007, 20:52:36 pm by Trond Dahl » Logged
Race car 9.49/236kmt@SCC 2017
« Reply #6 on: October 17, 2007, 21:12:28 pm »
Or he could borrow yours to copy Smiley
cheers richie,uk
Trond Dahl
« Reply #7 on: October 17, 2007, 21:24:46 pm »
cheers richie,uk
I wrote a bit wrong, what I ment was "where I got THAT one" ... he bought mine richie, or else I would offcourse have offered him to look at mine considering he lives about 15 minutes away :-)
« Reply #8 on: October 17, 2007, 21:29:23 pm »
No worries,i will see if I can dig out some pics to help then,cheers richie
Endre D
« Reply #9 on: October 18, 2007, 12:04:51 pm »
That's right, its Trond's old case. Any picures you can come up with would be of great help!
Thanks! Endre
Kotten
« Reply #10 on: October 20, 2007, 22:09:29 pm »
Clearancing a case is not that big a deal! Just time consuming.
If you have access to compressed air and a grinding tool just take one half of the crankcase at a time.
Put one connecting rod, piston and cylinder into the crankcase, rotate the assembly and grind little by little until it runs freely with about one millimeter of clearance between the assembly and the crankcase.
You do not have to use the piston rings during this procedure.
When one cylinder is done just move on to the next one.
Do remember that when rotating the assembly to put some pressure on the pulley end if you do not have the flywheel installed, otherwise you will remove excess material in unnecessary locations.
This method works with crankshafts up to at least 86 mm stoke with Porsche journals without any problems and fear of cutting holes in the case.
If you do it without the rods and pistons in the cylinders you will not know exactly how much to remove and probably remove  too much!
Done many times by
Kotten
