October 13, 2026, 20:19:43 pm
| | |-+  Hybrid Heads L5/L7 from Aircooled.net ???
Author Topic: Hybrid Heads L5/L7 from Aircooled.net ???  (Read 6674 times)
Motox166
« on: October 19, 2018, 07:26:33 am »
Well, my used used heads were different than I thought I was getting. I don't think th PO knew what he had. He sold them as a standard L5.
Specs that I have verified:
94mm bore
40x35 valves = L5
76 or 77cc intake runners = L7
64cc chambers
Aircooled.net CNC'd in large print on the bottom fin.
049 castings
Ports have not been touched since CNC'd from the looks of it.
Was this a mistake somehow that got out the door? Did someone install smaller valves after new?
Is this some secret racers trick: venturi effect with the medium size ports tapering down towards the smallish 40mm valve.
I'm told by the PO that these are circa 2014.
Should I go bigger valves to match the runners?
If so what size? Having a local a vw machinist do the work, so is it worth the cost over buying new Panchitos for $600-700 or Huh BTW, paid $400.
Building a:
2165
86c w/ 1.4s - thinking 106 LC?
10:1
Dual 44s
1 5/8 exhaust or 1 3/4?
7500 or 8000 max rpm
Vw650 springs, Ti retainers
As41 mag with bushed lifter bores, full flow
Bugpack crank, pauter rods
Shooting for 180hp+ at the crank
Use:
70 Baja Bug, mostly a fun after work/ weekend warrior.
Once in a while, play around in the Oregon sand dunes.
002 bus box, 30"x 13" sand paddles for sand drag racing and 32" for the street.
P.S. I posted this on theS*mba also. But I like the the answers I get here better.
Btw: Jim Ratto is my spirit animal. I like the way thinks!
Erlend / bug66
Global Moderator
SCC Event
« Reply #1 on: October 19, 2018, 07:32:56 am »
The cam and rockers (0n 108LC at least) is good for that RMP. Not too sure about the carbs and heads. If the heads were from JPM, I would not question it..
Change them out with 044 mini or regular wedge ports. GREAT head for the combo. My 2110 on old style wedge ports, 86C + 1,4 and 1 3/4 exhaust turned 200 hp at those RPMs. But on IDAs..  Smiley
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
Motox166
« Reply #2 on: October 19, 2018, 07:39:48 am »
Yes, that does sound like a good idea. What compression are you at?
Can you describe your power band? What rpm does it start pulling hard? 3500?
John @ aircooled.net said about the L5 heads:
"A test 2.0L engine with these heads made 186 HP with Dual 44 Webers. Web 86C and 10:1 compression. Cam pulls to 7500, but I recommend shifting at 7k"
Motox166
« Reply #3 on: October 19, 2018, 07:40:38 am »
Pics:
https://www.thesamba.com/vw/forum/viewtopic.php?t=708848
