September 23, 2026, 12:25:44 pm
| | |-+  Cal look tire size?
Author Topic: Cal look tire size?  (Read 15380 times)
jy334769
« on: April 07, 2019, 17:02:28 pm »
I just bought a decent '62. I'd like to do a Cal-look style build. I'd like to lower the rear one spline though and am looking for input on rear tire sizes. For the front I'm planning on 145/15 tires with dropped spindles. From what I've seen here and other places, the 205/65 or 70 is a popular size for the rear of a true Cal-look car. I'm wondering though if I should go with a 195 on the rear since I want to drop it one spline. ยูฟ่าเบท
Any info is appreciated.
AZOfftheWall
« Reply #1 on: April 08, 2019, 21:46:03 pm »
205/70 with a short axle and standard wheel offsets is perfect
brewsy
« Reply #2 on: April 10, 2019, 21:24:29 pm »
Heres 205/65 on my '67 [ Attachment: You are not allowed to view attachments ]
slowsixtyseven
« Reply #3 on: May 10, 2019, 05:10:35 am »
It may depend on your wheel offset/size, but a 205/65 should do the trick, even with it slightly lowered. I personally run a 215/65 on the back of my car with Flat Four BRM's. I am lowered about a spline now (not in the images below) and have no issues. Personally, a 70 series tire is too tall for my taste and gearing.
dustyuk
« Reply #4 on: August 11, 2019, 08:29:24 am »
Hi all, my first post here, no doubt of many, thought I'd add on to a post rather than starting another.
So I have a 71 1300 and looking for the same advice as the OP.
My 'plan' is to add a disc kit at the front with drop spindles - this kit - https://tinyurl.com/yykejsu9
I plan to drop the rear 1 or 2 clicks but more than happy to take advice on this.
For wheels I want to go with SSP Empi 8 which are 5.5j X 15 - https://tinyurl.com/yy32e44t
So, my question is, what size tyres should I be using?  I would prefer a more compliant ride  Smiley
« Reply #5 on: August 11, 2019, 11:07:22 am »
Welcome to The Lounge! Sounds like you're building a driver with a Cal Look style, which makes sense. No point in building a strip monster that never gets used.
The dropped spindle kits can add width, so you may need to factor a narrowed beam in to the equation. I think the SSP 8s are a reasonable offset though, so you might get away with it as long as you don't go too wide on the front tyres. I don't think you can beat the look of a 145, but you can find tyre calculators online which compare tyre heights. Put the 145 in as a 145/82r15 and look for something in a 165.
As for the back, lowered 2 splines is far too much. One is too much in my opinion - 4 inner and 4 outer the other way should be enough to drop the back a little but still keep that nose down look. A 205 won't fit under the back with long axles - depending on brand a 185 should be plenty, but the tricky bit is getting the height. A 70 profile is good but hard to get. 65 is too low. Check out the late model thread for ideas!
volkskris
« Reply #6 on: August 17, 2019, 12:20:38 pm »
I run drop spindles with ventilated kerscher brakes, ssp 8spokes and 165/65 tires. No narrowed beam. It fits, but only just.
« Last Edit: August 17, 2019, 12:31:12 pm by volkskris » Logged
