September 23, 2026, 11:49:56 am
| |-+  Technical stuff
| | |-+  Piston to valve clearance
Pages: 1 [2] Print
Author Topic: Piston to valve clearance  (Read 27668 times)
« Reply #30 on: April 12, 2020, 17:00:53 pm »
I don’t know about pushrods changing, but this noise is the pistons hitting the heads. I just thought it was interesting how the engine runs fine when it warms a little vs cold (like on your engine stand). Referencing the rally engine experience above.
samotorsport
« Reply #31 on: April 12, 2020, 17:44:52 pm »
Wow if i would have heard such a noise i would never haf the balls to let it heat up to find out if the noise goes away , i guess i would have stripped it straight away Wink
« Reply #32 on: April 12, 2020, 17:50:27 pm »
He said on rally engine it doesn't hit so not sure what you mean there? , and i am with Sam, I wouldn't run it if it hit ever, just build it right.
« Reply #33 on: April 12, 2020, 20:35:54 pm »
I’ll get around to fixing the noise but it can wait. That engine was built like that in 2013 and has thousands of miles on it being used every year as a daily. The bottom end wasn’t touched at the time of the tight deck heads. Bottom end was done with a Berg cw 69 crank back in 1998. Bearings are original from 1998 and seem fine even today with little racket thru the shifter and makes plenty of power still.
« Last Edit: April 12, 2020, 20:58:21 pm by Martin S. » Logged
brewsy
« Reply #34 on: April 13, 2020, 11:31:58 am »
Martin is that one of those anti pre-ignition slots that you've put into the head?
« Reply #35 on: April 13, 2020, 12:29:28 pm »
Yes, it adds turbulence along with the tight deck.
« Reply #36 on: April 14, 2020, 09:51:43 am »
Just looked through all my bits and I don’t have any valves Richie.
If you have an old one that would be fantastic. Really appreciate the help
One gone in mail to you now, already cut down and ready to use Smiley
« Reply #37 on: April 14, 2020, 10:04:47 am »
I always tought the rule of thumb was 1.5 mm on the inlet and 2.0mm on the exhaust.??
« Last Edit: April 14, 2020, 10:47:36 am by Eddie » Logged
jay c
« Reply #38 on: April 14, 2020, 10:51:27 am »
thanks Richie. Legend
Going to do at least that , probably a fraction more. Thanks Ed
jay c
« Reply #39 on: April 18, 2020, 13:18:32 pm »
all received. Thank so much. And thanks for sharpening it too. I owe you a beer
« Reply #40 on: April 18, 2020, 13:22:40 pm »
I have found this thread really interesting. My new motor will need valve notches.
Please can you post some pics of what you do with the sharpened valve Richie sent you
DaveN
« Reply #41 on: April 19, 2020, 20:56:40 pm »
It says on the first page what to do with it. It’s put in the valve guide to mark the center of the piston.  You can then use this to mark where the notches will be on the piston.
« Reply #42 on: April 21, 2020, 10:30:22 am »
Thanks Dave,
I do get that bit  Grin
It's how the angle of the guide in relation to the piston that translates to the relief cut that interests me.
« Last Edit: April 21, 2020, 15:04:10 pm by leec » Logged
Pages: 1 [2] Print
