September 23, 2026, 15:52:25 pm
2165 type1 long block
Topic: 2165 type1 long block (Read 5157 times)
bang
April 17, 2020, 07:00:13 am »
[ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ] hey. longblock 2165cc. all new parts. only case is used.
will be assambled within the next 2 weeks.
build for 145-150hp and for highway cruise.
new dpr crank with flywheels and clutch. all ballanced
new cp performance pancitos heads with idf manifolds
as41 case comes from a industrial plant with -10 hours of run
new aa cylinder and pistons
magnum cam gear
csp studs 8mm
alu pushrod tubes
jpm pushrods
all case hardware in black
h beam rods
etc.
i will take some pictures this weekend.
5000 euro
Last Edit: September 23, 2020, 08:07:12 am by bang
bang
Re: 2165 type engine parts.
June 02, 2020, 21:29:13 pm »
Can spilt if anyone can use some of it.
CB Pantitos heads with match port manifold. 850 euro
dpr crank new with match ballanced flywheel, and stage 1 pressure plate. 1450 ready to drop in
have a look on the pictures and see if there is something you need.
also have a lot of other engine parts plus some boxes of LAT Racing oil
bang
June 02, 2020, 21:31:06 pm »
more pictures
bang
Re: 2165 type1 long block
September 23, 2020, 08:07:40 am »
now as a longblock.
alex d
September 23, 2020, 08:50:25 am »
What are the rest of the specs? Camshaft, compression ratio? Where is it located?
bang
September 23, 2020, 11:15:18 am »
hey alex.
cam is a web#163
cb lifters
sedek 26mm oli pump
case is full flow and done with "Hover mods"
magnum cam gear
jay cee pushrod tubes
jaycee oil pump cover with returns.
match port idf manifolds
stage 1 kennedy pressure plate with delkin disc
deck hight is 1,17mm
cc in heads is 61cc
so comt is set to round 9:1
the engine is located in denmark.
i want to build an engine to run in the swedish 1600 challange that is why i sell this.
was ment for my bus, but i sold it and how this has to go.
bang
November 14, 2020, 19:50:55 pm »
taking offer.....
